[PATCH] rtems-test-check: Make exclude work again.
Mon Jan 16 19:24:39 UTC 2017
closes #2867.
 tools/build/rtems-test-check | 90 ++++++++++++++++++++++----------------------
 1 file changed, 45 insertions(+), 45 deletions(-)
diff --git a/tools/build/rtems-test-check b/tools/build/rtems-test-check
index e02f8e9..e8acde0 100755
--- a/tools/build/rtems-test-check
+++ b/tools/build/rtems-test-check
@@ -32,7 +32,6 @@ done
 case ${mode} in
  exclude)
-   output=${tests}
  flags)
    if [ $test_count != 1 ]; then
@@ -99,52 +98,53 @@ if test -f $testdata; then
     testdata=$ntd
   done
-  for t in ${tests};
-  do
-    case ${mode} in
-      exclude)
-        allow="yes"
-        for dt in ${excluded_tests};
-        do
-          if test ${t} = ${dt}; then
-            allow="no"
-          fi
-        done
-        if test ${allow} = yes; then
-          output="${output} ${t}"
-        fi
-      flags)
-        allow="no"
-        for et in ${expected_fails};
-        do
-          if test ${t} = ${et}; then
-            allow="yes"
-          fi
-        done
-          output="-DTEST_STATE_EXPECTED_FAIL=1"
-        fi
-        allow="no"
-        for it in ${indeterminates};
-        do
-          if test ${t} = ${it}; then
-            allow="yes"
-          fi
-        done
-          output="${output} -DTEST_STATE_INDETERMINATE=1"
-        fi
-        echo "error: invalid mode" 1>&2
-        echo "INVALID-TEST-DATA"
-        exit 1
-    esac
-  done
 fi
+for t in ${tests};
+do
+  case ${mode} in
+    exclude)
+      allow="yes"
+      for dt in ${excluded_tests};
+      do
+	if test ${t} = ${dt}; then
+	  allow="no"
+	fi
+      done
+      if test ${allow} = yes; then
+	output="${output} ${t}"
+      fi
+    flags)
+      allow="no"
+      for et in ${expected_fails};
+      do
+	if test ${t} = ${et}; then
+	  allow="yes"
+	fi
+      done
+	output="-DTEST_STATE_EXPECTED_FAIL=1"
+      fi
+      allow="no"
+      for it in ${indeterminates};
+      do
+	if test ${t} = ${it}; then
+	  allow="yes"
+	fi
+      done
+	output="${output} -DTEST_STATE_INDETERMINATE=1"
+      fi
+      echo "error: invalid mode" 1>&2
+      echo "INVALID-TEST-DATA"
+      exit 1
+  esac
+done
 echo ${output}
 exit 0
1.8.3.1
