[PATCH] rtems-test-check: Make exclude work again.
Mon Jan 16 23:12:27 UTC 2017
This change looks wrong. Moving test loop out of the if testdata block
means variables in the test loop are not defined. I consider it a script
bug to assume it is ok to reference a variable that is not declared
because it is ambiguous if this intended behavior or a bug.
Starvos sent me this change a few days ago and it looks good. I am
hoping he will make a patch we can merge so he can have the credit ..
diff --git a/tools/build/rtems-test-check b/tools/build/rtems-test-check
index e02f8e9..108b788 100755
--- a/tools/build/rtems-test-check
+++ b/tools/build/rtems-test-check
@@ -32,7 +32,11 @@ done
 case ${mode} in
  exclude)
-   output=${tests}
+   if test -f $testdata; then
+     output=""
+   else
+     output="${tests}"
+   fi
  flags)
    if [ $test_count != 1 ]; then
Are you in a position to test this change?
On 17/1/17 6:24 am, Joel Sherrill wrote:
> closes #2867.
>  tools/build/rtems-test-check | 90 ++++++++++++++++++++++----------------------
>  1 file changed, 45 insertions(+), 45 deletions(-)
> index e02f8e9..e8acde0 100755
> @@ -32,7 +32,6 @@ done
>  case ${mode} in
>   exclude)
> -   output=${tests}
>   flags)
> @@ -99,52 +98,53 @@ if test -f $testdata; then
>      testdata=$ntd
>    done
> -  for t in ${tests};
> -  do
> -    case ${mode} in
> -      exclude)
> -        allow="yes"
> -        for dt in ${excluded_tests};
> -        do
> -          if test ${t} = ${dt}; then
> -            allow="no"
> -          fi
> -        done
> -        if test ${allow} = yes; then
> -          output="${output} ${t}"
> -        fi
> -      flags)
> -        allow="no"
> -        for et in ${expected_fails};
> -        do
> -          if test ${t} = ${et}; then
> -            allow="yes"
> -          fi
> -        done
> -          output="-DTEST_STATE_EXPECTED_FAIL=1"
> -        fi
> -        allow="no"
> -        for it in ${indeterminates};
> -        do
> -          if test ${t} = ${it}; then
> -            allow="yes"
> -          fi
> -        done
> -          output="${output} -DTEST_STATE_INDETERMINATE=1"
> -        fi
> -        echo "error: invalid mode" 1>&2
> -        echo "INVALID-TEST-DATA"
> -        exit 1
> -    esac
> -  done
>  fi
> +for t in ${tests};
> +do
> +  case ${mode} in
> +    exclude)
> +      allow="yes"
> +      for dt in ${excluded_tests};
> +      do
> +	if test ${t} = ${dt}; then
> +	  allow="no"
> +	fi
> +      done
> +      if test ${allow} = yes; then
> +	output="${output} ${t}"
> +      fi
> +    flags)
> +      allow="no"
> +      for et in ${expected_fails};
> +      do
> +	if test ${t} = ${et}; then
> +	  allow="yes"
> +	fi
> +      done
> +	output="-DTEST_STATE_EXPECTED_FAIL=1"
> +      fi
> +      allow="no"
> +      for it in ${indeterminates};
> +      do
> +	if test ${t} = ${it}; then
> +	  allow="yes"
> +	fi
> +      done
> +	output="${output} -DTEST_STATE_INDETERMINATE=1"
> +      fi
> +      echo "error: invalid mode" 1>&2
> +      echo "INVALID-TEST-DATA"
> +      exit 1
> +  esac
> +done
>  echo ${output}
>  exit 0
