Unable to build rtems-docs Was: Re: [PATCH] Update RMS documentation for overrun handling
Joel Sherrill
joel at rtems.org
Tue Jan 17 15:39:08 UTC 2017
On Tue, Jan 17, 2017 at 9:30 AM, Gedare Bloom <gedare at rtems.org> wrote:
> On Fri, Jan 13, 2017 at 5:51 PM, Chris Johns <chrisj at rtems.org> wrote:
> > On 14/1/17 8:21 am, Gedare Bloom wrote:
> >> I was unable to compile rtems-docs (cleanly), so I have not committed
> >> this patch yet.
> > What is the problem?
> It appears to be a problem in my distribution's texlive / latex
> support I guess. I'm on an aging Ubuntu here. :)
> I don't recall my exact failure on CentOS and Fedora but it turned out that
they didn't package the complete TexLive contents. I ended up removing
what came with the distribution and using the TexLive master distribution.
The README.txt file has details.
https://git.rtems.org/rtems-docs/tree/README.txt
I can now build the docs even on CentOS 6 which is as old a distribution
as anyone should be made to use. :)
> $ uname -a
> Linux gedare-pc 3.13.0-24-generic #47-Ubuntu SMP Fri May 2 23:30:00
> UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
> $ sphinx-build --version
> Sphinx (sphinx-build) 1.5.1
> $ python --version
> Python 2.7.6
> Relevant-seeming shell output below:
> [ 24/101] Processing
> /home/gedare/work/rtems/rtems-docs/build/c-user/html/index.html:
> c-user/barrier_manager.rst c-user/board_support_packages.rst
> c-user/chains.rst c-user/clock_manager.rst
> c-user/configuring_a_system.rst c-user/constant_bandwidth_server.rst
> c-user/cpu_usage_statistics.rst c-user/directive_status_codes.rst
> c-user/dual_ports_memory_manager.rst c-user/event_manager.rst
> c-user/example_application.rst c-user/fatal_error.rst
> c-user/glossary.rst c-user/index.rst c-user/initialization.rst
> c-user/interrupt_manager.rst c-user/io_manager.rst
> c-user/key_concepts.rst c-user/linker_sets.rst
> c-user/message_manager.rst c-user/multiprocessing.rst
> c-user/object_services.rst c-user/overview.rst
> c-user/partition_manager.rst c-user/pci_library.rst c-user/preface.rst
> c-user/rate_monotonic_manager.rst c-user/red_black_trees.rst
> c-user/region_manager.rst c-user/rtems_data_types.rst
> c-user/scheduling_concepts.rst c-user/semaphore_manager.rst
> c-user/signal_manager.rst c-user/stack_bounds_checker.rst
> c-user/symmetric_multiprocessing_services.rst c-user/task_manager.rst
> c-user/timer_manager.rst c-user/timespec_helpers.rst
> c-user/user_extensions.rst -> build/c-user/html/index.html
> 16:19:18 runner ' /usr/local/bin/sphinx-build -Q -b html -c . -d
> /home/gedare/work/rtems/rtems-docs/build/c-user/doctrees/html .
> /home/gedare/work/rtems/rtems-docs/build/c-user/html '
> /usr/local/lib/python2.7/dist-packages/sphinx/util/requests.py:33:
> UserWarning: Some links may return broken results due to being unable
> to check the Server Name Indication (SNI) in the returned SSL cert
> against the hostname in the url requested. Recommended to install
> "requests[security]" as a dependency or upgrade to a python version
> with SNI support (Python 3 and Python 2.7.9+).
> 'Some links may return broken results due to being unable to '
> Exception occurred:
> File "/usr/local/lib/python2.7/dist-packages/sphinx/writers/latex.py",
> line 366, in __init__
> self.sectionnames.index(builder.config.latex_toplevel_sectioning)
> ValueError: 'parts' is not in list
> The full traceback has been saved in /tmp/sphinx-err-sQHg09.log, if
> you want to report the issue to the developers.
> Please also report this if it was a user error, so that a better error
> message can be provided next time.
> A bug report can be filed in the tracker at
> <https://github.com/sphinx-doc/sphinx/issues>. Thanks!
> Above warning and exception repeat 3 more times.
> Traceback from /tmp/sphinx-err-sQHg09.log
> Traceback (most recent call last):
> File "/usr/local/lib/python2.7/dist-packages/sphinx/cmdline.py",
> line 296, in main
> app.build(opts.force_all, filenames)
> File "/usr/local/lib/python2.7/dist-packages/sphinx/application.py",
> line 333, in build
> self.builder.build_update()
> File "/usr/local/lib/python2.7/dist-packages/sphinx/builders/
> __init__.py",
> line 246, in build_update
> self.build(['__all__'], to_build)
> __init__.py",
> line 322, in build
> self.write(docnames, list(updated_docnames), method)
> File "/usr/local/lib/python2.7/dist-packages/sphinx/builders/latex.py",
> line 130, in write
> docwriter.write(doctree, destination)
> File "/usr/local/lib/python2.7/dist-packages/docutils/
> writers/__init__.py",
> line 80, in write
> self.translate()
> line 159, in translate
> visitor = self.translator_class(self.document, self.builder)
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170117/3a9053c6/attachment-0001.html>
