RTEMS master LEON test status
Tue Jan 24 13:07:04 UTC 2017
On 24/01/17 13:51, Sebastian Huber wrote:
> On 24/01/17 13:25, Daniel Hellstrom wrote:
>> GR712RC, RTEMS Single-core configuration results:
>>   # RTEMS TESTSUITE FAILURE SUMMARY
>>   # Result Test ExecRes ConsoleRes ExitCode1 ExitCode2
>>   # FAIL: ./fstests/fsdosfsname01 OK FAIL 5 0
Probably a tool chain issue.
>>   # FAIL: ./psxtests/psxsem01 OK FAIL 5 11
I don't see a failure in the attached log.
>>   # FAIL: ./sptests/spinternalerror01 OK N/A -559038737 1611526157
This test intentionally results in an exception. I guess this is not
covered by your test script.
>>   # FAIL: ./sptests/sptimecounter01 OK N/A 5 0
This is likely a problem with the test and a missing system initialization.
>>   # SUMMARY
>>   #  Tests failing:    4
>>   #  Tests successful: 528
> It would be good to investigate these issues.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
