[PATCH 3/3] Remove CPU_BIG_ENDIAN and CPU_LITTLE_ENDIAN
Joel Sherrill
joel at rtems.org
Wed Jan 25 16:45:59 UTC 2017
On Wed, Jan 25, 2017 at 10:35 AM, Gedare Bloom <gedare at rtems.org> wrote:
> On Mon, Jan 23, 2017 at 2:14 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
> > Use de-facto standard BYTE_ORDER instead.
> Just one nit that de-facto here means glibc right?
It is older than gcc. As far as I can tell, it is from the original BSD
TCP/IP headers
and is still around.
It is not in POSIX as best I can tell.
defacto = ancient BSD and common.
__BYTE_ORDER__ appears to be defined by gcc in some cases. I checked
our powerpc and i386 gcc's but my native gcc 4.4.7 didn't define anything
related
to endianness that I spotted.
> > Close #2803.
> > cpukit/score/cpu/arm/rtems/score/cpu.h | 10 --------
> > cpukit/score/cpu/bfin/rtems/score/cpu.h | 40
> > cpukit/score/cpu/epiphany/rtems/score/cpu.h | 2 --
> > cpukit/score/cpu/i386/rtems/score/cpu.h | 8 ------
> > cpukit/score/cpu/lm32/rtems/score/cpu.h | 40
> > cpukit/score/cpu/m32c/rtems/score/cpu.h | 40
> > cpukit/score/cpu/m68k/rtems/score/cpu.h | 8 ------
> > cpukit/score/cpu/mips/rtems/score/cpu.h | 16 ------------
> > cpukit/score/cpu/moxie/rtems/score/cpu.h | 7 -----
> > cpukit/score/cpu/nios2/rtems/score/cpu.h | 4 ---
> > cpukit/score/cpu/no_cpu/rtems/score/cpu.h | 40
> > cpukit/score/cpu/or1k/rtems/score/cpu.h | 2 --
> > cpukit/score/cpu/powerpc/rtems/score/cpu.h | 13 ----------
> > cpukit/score/cpu/sh/rtems/score/cpu.h | 16 ------------
> > cpukit/score/cpu/sparc/rtems/score/cpu.h | 16 ------------
> > cpukit/score/cpu/sparc64/rtems/score/cpu.h | 8 ------
> > cpukit/score/cpu/v850/rtems/score/cpu.h | 40
> > 17 files changed, 310 deletions(-)
> > diff --git a/cpukit/score/cpu/arm/rtems/score/cpu.h
> b/cpukit/score/cpu/arm/rtems/score/cpu.h
> > index 0a9ca26..cdffc9c 100644
> > --- a/cpukit/score/cpu/arm/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/arm/rtems/score/cpu.h
> > @@ -97,16 +97,6 @@
> > -#if defined(__ARMEL__)
> > - #define CPU_BIG_ENDIAN FALSE
> > - #define CPU_LITTLE_ENDIAN TRUE
> > -#elif defined(__ARMEB__)
> > - #define CPU_BIG_ENDIAN TRUE
> > - #define CPU_LITTLE_ENDIAN FALSE
> > -#else
> > - #error "unknown endianness"
> > -#endif
> > * The ARM uses the PIC interrupt model.
> > diff --git a/cpukit/score/cpu/bfin/rtems/score/cpu.h
> b/cpukit/score/cpu/bfin/rtems/score/cpu.h
> > index 9b54d6c..cdefedf 100644
> > --- a/cpukit/score/cpu/bfin/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/bfin/rtems/score/cpu.h
> > @@ -280,46 +280,6 @@ extern "C" {
> > #define CPU_STRUCTURE_ALIGNMENT
> > - * @defgroup CPUEndian Processor Dependent Endianness Support
> > - * This group assists in issues related to processor endianness.
> > - * Define what is required to specify how the network to host conversion
> > - * routines are handled.
> > - * @note @a CPU_BIG_ENDIAN and @a CPU_LITTLE_ENDIAN should NOT have the
> > - * same values.
> > - * @see CPU_LITTLE_ENDIAN
> > - * Port Specific Information:
> > - * XXX document implementation including references if appropriate
> > -#define CPU_BIG_ENDIAN FALSE
> > - * @note @ref CPU_BIG_ENDIAN and @ref CPU_LITTLE_ENDIAN should NOT have
> the
> > - * same values.
> > - * @see CPU_BIG_ENDIAN
> > -#define CPU_LITTLE_ENDIAN TRUE
> > * @ingroup CPUInterrupt
> > * The following defines the number of bits actually used in the
> > * interrupt field of the task mode. How those bits map to the
> > diff --git a/cpukit/score/cpu/epiphany/rtems/score/cpu.h
> b/cpukit/score/cpu/epiphany/rtems/score/cpu.h
> > index 4319203..55faefa 100644
> > --- a/cpukit/score/cpu/epiphany/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/epiphany/rtems/score/cpu.h
> > @@ -261,8 +261,6 @@ extern "C" {
> > #define CPU_HAS_OWN_HOST_TO_NETWORK_ROUTINES FALSE
> > diff --git a/cpukit/score/cpu/i386/rtems/score/cpu.h
> b/cpukit/score/cpu/i386/rtems/score/cpu.h
> > index c45d914..052e53f 100644
> > --- a/cpukit/score/cpu/i386/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/i386/rtems/score/cpu.h
> > @@ -114,14 +114,6 @@ extern "C" {
> > #define CPU_PROVIDES_IDLE_THREAD_BODY FALSE
> conversion
> > #define CPU_MAXIMUM_PROCESSORS 32
> > #define I386_CONTEXT_CONTROL_EFLAGS_OFFSET 0
> > diff --git a/cpukit/score/cpu/lm32/rtems/score/cpu.h
> b/cpukit/score/cpu/lm32/rtems/score/cpu.h
> > index e6f6c51..87cfd9e 100644
> > --- a/cpukit/score/cpu/lm32/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/lm32/rtems/score/cpu.h
> > @@ -274,46 +274,6 @@ extern "C" {
> > #define CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES )
> > - * NOTE: @a CPU_BIG_ENDIAN and @a CPU_LITTLE_ENDIAN should NOT have the
> > - * same values.
> > -#define CPU_BIG_ENDIAN TRUE
> > - * NOTE: @ref CPU_BIG_ENDIAN and @ref CPU_LITTLE_ENDIAN should NOT have
> the
> > - * same values.
> > -#define CPU_LITTLE_ENDIAN FALSE
> > diff --git a/cpukit/score/cpu/m32c/rtems/score/cpu.h
> b/cpukit/score/cpu/m32c/rtems/score/cpu.h
> > index b1ef486..8dd8c41 100644
> > --- a/cpukit/score/cpu/m32c/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/m32c/rtems/score/cpu.h
> > @@ -296,46 +296,6 @@ extern "C" {
> > - * same values.
> the
> > - * same values.
> > diff --git a/cpukit/score/cpu/m68k/rtems/score/cpu.h
> b/cpukit/score/cpu/m68k/rtems/score/cpu.h
> > index 0e3cd81..0b9aa2d 100644
> > --- a/cpukit/score/cpu/m68k/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/m68k/rtems/score/cpu.h
> > @@ -104,14 +104,6 @@ extern "C" {
> conversion
> > #if ( CPU_HARDWARE_FP == TRUE ) && !defined( __mcoldfire__ )
> > diff --git a/cpukit/score/cpu/mips/rtems/score/cpu.h
> b/cpukit/score/cpu/mips/rtems/score/cpu.h
> > index 60bec59..9a45d0b 100644
> > --- a/cpukit/score/cpu/mips/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/mips/rtems/score/cpu.h
> > @@ -269,22 +269,6 @@ extern "C" {
> conversion
> > -/* __MIPSEB__ or __MIPSEL__ is defined by GCC based on -EB or -EL
> command line options */
> > -#if defined(__MIPSEB__)
> > -#elif defined(__MIPSEL__)
> > -#else
> > -#error "Unknown endianness"
> > -#endif
> > * CPU interrupt levels is defined by the routine _CPU_ISR_Set_level().
> > diff --git a/cpukit/score/cpu/moxie/rtems/score/cpu.h
> b/cpukit/score/cpu/moxie/rtems/score/cpu.h
> > index a85b199..b77083d 100644
> > --- a/cpukit/score/cpu/moxie/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/moxie/rtems/score/cpu.h
> > @@ -246,13 +246,6 @@ extern "C" {
> conversion
> > diff --git a/cpukit/score/cpu/nios2/rtems/score/cpu.h
> b/cpukit/score/cpu/nios2/rtems/score/cpu.h
> > index 902b209..a3f2f03 100644
> > --- a/cpukit/score/cpu/nios2/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/nios2/rtems/score/cpu.h
> > @@ -67,10 +67,6 @@ extern "C" {
> > #define CPU_STRUCTURE_ALIGNMENT \
> > RTEMS_SECTION( ".sdata" ) RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES )
> > #define CPU_STACK_MINIMUM_SIZE (4 * 1024)
> > #define CPU_SIZEOF_POINTER 4
> > diff --git a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
> b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
> > index 5608147..372b01f 100644
> > --- a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
> > @@ -320,46 +320,6 @@ extern "C" {
> > - * same values.
> the
> > - * same values.
> > diff --git a/cpukit/score/cpu/or1k/rtems/score/cpu.h
> b/cpukit/score/cpu/or1k/rtems/score/cpu.h
> > index 13dd334..4a643c7 100644
> > --- a/cpukit/score/cpu/or1k/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/or1k/rtems/score/cpu.h
> > @@ -253,8 +253,6 @@ extern "C" {
> > diff --git a/cpukit/score/cpu/powerpc/rtems/score/cpu.h
> b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
> > index 91f8f63..93d620e 100644
> > --- a/cpukit/score/cpu/powerpc/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
> > @@ -87,19 +87,6 @@ extern "C" {
> conversion
> > -#if defined(__BIG_ENDIAN__) || defined(_BIG_ENDIAN)
> > -#else
> > -#endif
> > * Does the CPU have hardware floating point?
> > * If TRUE, then the RTEMS_FLOATING_POINT task attribute is supported.
> > diff --git a/cpukit/score/cpu/sh/rtems/score/cpu.h
> b/cpukit/score/cpu/sh/rtems/score/cpu.h
> > index b4e5532..0ad3829 100644
> > --- a/cpukit/score/cpu/sh/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/sh/rtems/score/cpu.h
> > @@ -218,22 +218,6 @@ extern "C" {
> conversion
> > - * NOTE: SHes can be big or little endian, the default is big endian
> > -/* __LITTLE_ENDIAN__ is defined if -ml is given to gcc */
> > -#if defined(__LITTLE_ENDIAN__)
> > -#else
> > -#endif
> > diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h
> b/cpukit/score/cpu/sparc/rtems/score/cpu.h
> > index 1bc4a0e..6d8e1f9 100644
> > --- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
> > @@ -208,22 +208,6 @@ extern "C" {
> > - * The SPARC is big endian.
> > - * The SPARC is NOT little endian.
> > diff --git a/cpukit/score/cpu/sparc64/rtems/score/cpu.h
> b/cpukit/score/cpu/sparc64/rtems/score/cpu.h
> > index 4402bde..9926ebb 100644
> > --- a/cpukit/score/cpu/sparc64/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/sparc64/rtems/score/cpu.h
> > @@ -183,14 +183,6 @@ extern "C" {
> > #define CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED( 16 )
> conversion
> > diff --git a/cpukit/score/cpu/v850/rtems/score/cpu.h
> b/cpukit/score/cpu/v850/rtems/score/cpu.h
> > index 8f3fbd9..6c77f51 100644
> > --- a/cpukit/score/cpu/v850/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/v850/rtems/score/cpu.h
> > @@ -273,46 +273,6 @@ extern "C" {
> > - * same values.
> > - * The v850 is little endian.
> the
> > - * same values.
> > 1.8.4.5
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170125/0fc9788f/attachment-0001.html>
