[PATCH 4/8] Add support for ordering the initialization of Nexus devices. This can be used to make sure a device is initialized before a dependant device.
Kevin Kirspel kevin-kirspel at idexx.com
Fri Jan 27 05:32:22 UTC 2017
 rtemsbsd/include/rtems/bsd/bsd.h    | 13 ++++++++++++-
 rtemsbsd/rtems/rtems-kernel-nexus.c | 12 +++++++++---
 2 files changed, 21 insertions(+), 4 deletions(-)
 mode change 100644 => 100755 rtemsbsd/include/rtems/bsd/bsd.h
 mode change 100644 => 100755 rtemsbsd/rtems/rtems-kernel-nexus.c
diff --git a/rtemsbsd/include/rtems/bsd/bsd.h b/rtemsbsd/include/rtems/bsd/bsd.h
old mode 100644
new mode 100755
index 0968062..e356390
--- a/rtemsbsd/include/rtems/bsd/bsd.h
+++ b/rtemsbsd/include/rtems/bsd/bsd.h
@@ -63,6 +63,13 @@ typedef enum {
 	RTEMS_BSD_RES_MEMORY = 3
 } rtems_bsd_device_resource_type;
+typedef enum {
+	RTEMS_BSD_ORDER_FIRST,
+	RTEMS_BSD_ORDER_MIDDLE,
+	RTEMS_BSD_ORDER_LAST,
+	RTEMS_BSD_ORDER_MAX
+} rtems_bsd_device_order_type;
 typedef struct {
 	rtems_bsd_device_resource_type type;
 	unsigned long start_request;
@@ -72,15 +79,19 @@ typedef struct {
 typedef struct {
 	const char *name;
 	int unit;
+	rtems_bsd_device_order_type	order;
 	size_t resource_count;
 	const rtems_bsd_device_resource *resources;
 	const struct sysinit *driver_reference;
 } rtems_bsd_device;
 #define RTEMS_BSD_DEFINE_NEXUS_DEVICE(name, unit, resource_count, resources) \
+    RTEMS_BSD_DEFINE_NEXUS_DEVICE_ORDERED(name, unit, RTEMS_BSD_ORDER_MIDDLE, resource_count, resources)
+#define RTEMS_BSD_DEFINE_NEXUS_DEVICE_ORDERED(name, unit, order, resource_count, resources) \
     extern struct sysinit SYSINIT_ENTRY_NAME(name##_nexusmodule); \
     RTEMS_BSD_DEFINE_SET_ITEM(nexus, name##unit, rtems_bsd_device) = \
-        { #name, unit, (resource_count), (resources), \
+        { #name, unit, order, (resource_count), (resources), \
             &SYSINIT_ENTRY_NAME(name##_nexusmodule) }
 rtems_status_code rtems_bsd_initialize(void);
diff --git a/rtemsbsd/rtems/rtems-kernel-nexus.c b/rtemsbsd/rtems/rtems-kernel-nexus.c
old mode 100644
new mode 100755
index 04638cc..caff30e
--- a/rtemsbsd/rtems/rtems-kernel-nexus.c
+++ b/rtemsbsd/rtems/rtems-kernel-nexus.c
@@ -78,7 +78,7 @@ SYSINIT_REFERENCE(irqs);
 static int
 nexus_probe(device_t dev)
-	int err;
+	int err, index;
 	const rtems_bsd_device *nd;
 	device_set_desc(dev, "RTEMS Nexus device");
@@ -113,8 +113,14 @@ nexus_probe(device_t dev)
 	BSD_ASSERT(err == 0);
 #endif
-	SET_FOREACH(nd, nexus) {
-		device_add_child(dev, nd->name, nd->unit);
+	for( index = 0; index < RTEMS_BSD_ORDER_MAX; index++ )
+		SET_FOREACH(nd, nexus) {
+			if( nd->order == (rtems_bsd_device_order_type)index )
+				device_add_child(dev, nd->name, nd->unit);
 	return (0);
1.9.1
