[PATCH 3/8] Adding LPC32XX Ethernet and USB OHCI files to script
Kevin Kirspel kevin-kirspel at idexx.com
Fri Jan 27 05:32:21 UTC 2017
 libbsd.py | 7 ++++++-
 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/libbsd.py b/libbsd.py
index 53461fa..66606f1 100755
--- a/libbsd.py
+++ b/libbsd.py
@@ -146,7 +146,7 @@ def rtems(mm):
             'pppd/upap.c',
             'pppd/utils.c',
             'sys/dev/usb/controller/ehci_mpc83xx.c',
-            'sys/dev/usb/controller/ohci_lpc.c',
+            'sys/dev/usb/controller/lpc_ohci.c',
             'sys/dev/usb/controller/dwc_otg_nexus.c',
             'sys/dev/usb/controller/usb_otg_transceiver.c',
             'sys/dev/usb/controller/usb_otg_transceiver_dump.c',
@@ -872,6 +872,9 @@ def dev_net(mm):
             'sys/dev/dwc/if_dwc.h',
             'sys/dev/dwc/if_dwcvar.h',
             'sys/arm/xilinx/zy7_slcr.h',
+            'sys/arm/lpc/if_lpereg.h',
+            'sys/arm/lpc/lpcreg.h',
+            'sys/arm/lpc/lpcvar.h',
     mod.addKernelSpaceSourceFiles(
@@ -890,6 +893,8 @@ def dev_net(mm):
             'sys/dev/cadence/if_cgem.c',
             'sys/dev/dwc/if_dwc.c',
             'sys/arm/xilinx/zy7_slcr.c',
+            'sys/arm/lpc/lpc_pwr.c',
+            'sys/arm/lpc/if_lpe.c',
         mm.generator['source']()
1.9.1
