[PATCH 01/10] Adding LPC32XX ethernet driver support
Kevin Kirspel
kevin-kirspel at idexx.com
Mon Jan 30 16:58:15 UTC 2017
freebsd/sys/arm/lpc/if_lpe.c | 1234 +++++++++++++++++++++++++++++++++++++++
freebsd/sys/arm/lpc/if_lpereg.h | 208 +++++++
freebsd/sys/arm/lpc/lpc_pwr.c | 131 +++++
freebsd/sys/arm/lpc/lpcreg.h | 665 +++++++++++++++++++++
freebsd/sys/arm/lpc/lpcvar.h | 69 +++
5 files changed, 2307 insertions(+)
create mode 100644 freebsd/sys/arm/lpc/if_lpe.c
create mode 100644 freebsd/sys/arm/lpc/if_lpereg.h
create mode 100644 freebsd/sys/arm/lpc/lpc_pwr.c
create mode 100644 freebsd/sys/arm/lpc/lpcreg.h
create mode 100644 freebsd/sys/arm/lpc/lpcvar.h
diff --git a/freebsd/sys/arm/lpc/if_lpe.c b/freebsd/sys/arm/lpc/if_lpe.c
new file mode 100644
index 0000000..76b794f
--- /dev/null
+++ b/freebsd/sys/arm/lpc/if_lpe.c
@@ -0,0 +1,1234 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * Copyright (c) 2011 Jakub Wojciech Klama <jceel at FreeBSD.org>
+ * All rights reserved.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+#include <rtems/bsd/sys/param.h>
+#include <sys/endian.h>
+#include <sys/systm.h>
+#include <sys/sockio.h>
+#include <sys/mbuf.h>
+#include <sys/malloc.h>
+#include <sys/kernel.h>
+#include <sys/module.h>
+#include <rtems/bsd/sys/lock.h>
+#include <sys/mutex.h>
+#include <sys/rman.h>
+#include <sys/bus.h>
+#include <sys/socket.h>
+#include <machine/bus.h>
+#include <machine/intr.h>
+#include <net/if.h>
+#include <net/if_arp.h>
+#include <net/ethernet.h>
+#include <net/if_dl.h>
+#include <net/if_media.h>
+#include <net/if_types.h>
+#include <net/if_var.h>
+#include <net/bpf.h>
+#include <dev/ofw/ofw_bus.h>
+#include <dev/ofw/ofw_bus_subr.h>
+#include <dev/mii/mii.h>
+#include <dev/mii/miivar.h>
+#include <arm/lpc/lpcreg.h>
+#include <arm/lpc/lpcvar.h>
+#include <arm/lpc/if_lpereg.h>
+#include <rtems/bsd/local/miibus_if.h>
+#ifdef DEBUG
+#define debugf(fmt, args...) do { printf("%s(): ", __func__); \
+ printf(fmt,##args); } while (0)
+#else
+#endif
+struct lpe_dmamap_arg {
+ bus_addr_t lpe_dma_busaddr;
+struct lpe_rxdesc {
+ struct mbuf * lpe_rxdesc_mbuf;
+ bus_dmamap_t lpe_rxdesc_dmamap;
+struct lpe_txdesc {
+ int lpe_txdesc_first;
+ struct mbuf * lpe_txdesc_mbuf;
+ bus_dmamap_t lpe_txdesc_dmamap;
+struct lpe_chain_data {
+ bus_dma_tag_t lpe_parent_tag;
+ bus_dma_tag_t lpe_tx_ring_tag;
+ bus_dmamap_t lpe_tx_ring_map;
+ bus_dma_tag_t lpe_tx_status_tag;
+ bus_dmamap_t lpe_tx_status_map;
+ bus_dma_tag_t lpe_tx_buf_tag;
+ bus_dma_tag_t lpe_rx_ring_tag;
+ bus_dmamap_t lpe_rx_ring_map;
+ bus_dma_tag_t lpe_rx_status_tag;
+ bus_dmamap_t lpe_rx_status_map;
+ bus_dma_tag_t lpe_rx_buf_tag;
+ struct lpe_rxdesc lpe_rx_desc[LPE_RXDESC_NUM];
+ struct lpe_txdesc lpe_tx_desc[LPE_TXDESC_NUM];
+ int lpe_tx_prod;
+ int lpe_tx_last;
+ int lpe_tx_used;
+struct lpe_ring_data {
+ struct lpe_hwdesc * lpe_rx_ring;
+ struct lpe_hwstatus * lpe_rx_status;
+ bus_addr_t lpe_rx_ring_phys;
+ bus_addr_t lpe_rx_status_phys;
+ struct lpe_hwdesc * lpe_tx_ring;
+ struct lpe_hwstatus * lpe_tx_status;
+ bus_addr_t lpe_tx_ring_phys;
+ bus_addr_t lpe_tx_status_phys;
+struct lpe_softc {
+ struct ifnet * lpe_ifp;
+ struct mtx lpe_mtx;
+ phandle_t lpe_ofw;
+ device_t lpe_dev;
+ device_t lpe_miibus;
+ uint8_t lpe_enaddr[6];
+ struct resource * lpe_mem_res;
+ struct resource * lpe_irq_res;
+ void * lpe_intrhand;
+ bus_space_tag_t lpe_bst;
+ bus_space_handle_t lpe_bsh;
+#define LPE_FLAG_LINK (1 << 0)
+ uint32_t lpe_flags;
+ int lpe_watchdog_timer;
+ struct callout lpe_tick;
+ struct lpe_chain_data lpe_cdata;
+ struct lpe_ring_data lpe_rdata;
+static int lpe_probe(device_t);
+static int lpe_attach(device_t);
+static int lpe_detach(device_t);
+static int lpe_miibus_readreg(device_t, int, int);
+static int lpe_miibus_writereg(device_t, int, int, int);
+static void lpe_miibus_statchg(device_t);
+static void lpe_reset(struct lpe_softc *);
+static void lpe_init(void *);
+static void lpe_init_locked(struct lpe_softc *);
+static void lpe_start(struct ifnet *);
+static void lpe_start_locked(struct ifnet *);
+static void lpe_stop(struct lpe_softc *);
+static void lpe_stop_locked(struct lpe_softc *);
+static int lpe_ioctl(struct ifnet *, u_long, caddr_t);
+static void lpe_set_rxmode(struct lpe_softc *);
+static void lpe_set_rxfilter(struct lpe_softc *);
+static void lpe_intr(void *);
+static void lpe_rxintr(struct lpe_softc *);
+static void lpe_txintr(struct lpe_softc *);
+static void lpe_tick(void *);
+static void lpe_watchdog(struct lpe_softc *);
+static int lpe_encap(struct lpe_softc *, struct mbuf **);
+static int lpe_dma_alloc(struct lpe_softc *);
+static int lpe_dma_alloc_rx(struct lpe_softc *);
+static int lpe_dma_alloc_tx(struct lpe_softc *);
+static int lpe_init_rx(struct lpe_softc *);
+static int lpe_init_rxbuf(struct lpe_softc *, int);
+static void lpe_discard_rxbuf(struct lpe_softc *, int);
+static void lpe_dmamap_cb(void *, bus_dma_segment_t *, int, int);
+static int lpe_ifmedia_upd(struct ifnet *);
+static void lpe_ifmedia_sts(struct ifnet *, struct ifmediareq *);
+#define lpe_lock(_sc) mtx_lock(&(_sc)->lpe_mtx)
+#define lpe_unlock(_sc) mtx_unlock(&(_sc)->lpe_mtx)
+#define lpe_lock_assert(_sc) mtx_assert(&(_sc)->lpe_mtx, MA_OWNED)
+#define lpe_read_4(_sc, _reg) \
+ bus_space_read_4((_sc)->lpe_bst, (_sc)->lpe_bsh, (_reg))
+#define lpe_write_4(_sc, _reg, _val) \
+ bus_space_write_4((_sc)->lpe_bst, (_sc)->lpe_bsh, (_reg), (_val))
+#define LPE_HWDESC_RXERRS (LPE_HWDESC_CRCERROR | LPE_HWDESC_SYMBOLERROR | \
+ LPE_HWDESC_LENGTHERROR | LPE_HWDESC_ALIGNERROR | LPE_HWDESC_OVERRUN | \
+ LPE_HWDESC_RXNODESCR)
+#define LPE_HWDESC_TXERRS (LPE_HWDESC_EXCDEFER | LPE_HWDESC_EXCCOLL | \
+ LPE_HWDESC_LATECOLL | LPE_HWDESC_UNDERRUN | LPE_HWDESC_TXNODESCR)
+static int
+lpe_probe(device_t dev)
+ if (!ofw_bus_status_okay(dev))
+ return (ENXIO);
+ if (!ofw_bus_is_compatible(dev, "lpc,ethernet"))
+ return (ENXIO);
+ device_set_desc(dev, "LPC32x0 10/100 Ethernet");
+ return (BUS_PROBE_DEFAULT);
+static int
+lpe_attach(device_t dev)
+ struct lpe_softc *sc = device_get_softc(dev);
+ struct ifnet *ifp;
+ int rid, i;
+ uint32_t val;
+ sc->lpe_dev = dev;
+ sc->lpe_ofw = ofw_bus_get_node(dev);
+ i = OF_getprop(sc->lpe_ofw, "local-mac-address", (void *)&sc->lpe_enaddr, 6);
+ if (i != 6) {
+ sc->lpe_enaddr[0] = 0x00;
+ sc->lpe_enaddr[1] = 0x11;
+ sc->lpe_enaddr[2] = 0x22;
+ sc->lpe_enaddr[3] = 0x33;
+ sc->lpe_enaddr[4] = 0x44;
+ sc->lpe_enaddr[5] = 0x55;
+ mtx_init(&sc->lpe_mtx, device_get_nameunit(dev), MTX_NETWORK_LOCK,
+ MTX_DEF);
+ callout_init_mtx(&sc->lpe_tick, &sc->lpe_mtx, 0);
+ rid = 0;
+ sc->lpe_mem_res = bus_alloc_resource_any(dev, SYS_RES_MEMORY, &rid,
+ RF_ACTIVE);
+ if (!sc->lpe_mem_res) {
+ device_printf(dev, "cannot allocate memory window\n");
+ goto fail;
+ sc->lpe_bst = rman_get_bustag(sc->lpe_mem_res);
+ sc->lpe_bsh = rman_get_bushandle(sc->lpe_mem_res);
+ rid = 0;
+ sc->lpe_irq_res = bus_alloc_resource_any(dev, SYS_RES_IRQ, &rid,
+ RF_ACTIVE);
+ if (!sc->lpe_irq_res) {
+ device_printf(dev, "cannot allocate interrupt\n");
+ goto fail;
+ sc->lpe_ifp = if_alloc(IFT_ETHER);
+ if (!sc->lpe_ifp) {
+ device_printf(dev, "cannot allocated ifnet\n");
+ goto fail;
+ ifp = sc->lpe_ifp;
+ if_initname(ifp, device_get_name(dev), device_get_unit(dev));
+ ifp->if_softc = sc;
+ ifp->if_flags = IFF_BROADCAST | IFF_SIMPLEX | IFF_MULTICAST;
+ ifp->if_start = lpe_start;
+ ifp->if_ioctl = lpe_ioctl;
+ ifp->if_init = lpe_init;
+ IFQ_SET_MAXLEN(&ifp->if_snd, IFQ_MAXLEN);
+ ifp->if_snd.ifq_drv_maxlen = IFQ_MAXLEN;
+ IFQ_SET_READY(&ifp->if_snd);
+ ether_ifattach(ifp, sc->lpe_enaddr);
+ if (bus_setup_intr(dev, sc->lpe_irq_res, INTR_TYPE_NET, NULL,
+ lpe_intr, sc, &sc->lpe_intrhand)) {
+ device_printf(dev, "cannot establish interrupt handler\n");
+ ether_ifdetach(ifp);
+ goto fail;
+ /* Enable Ethernet clock */
+ lpc_pwr_write(dev, LPC_CLKPWR_MACCLK_CTRL,
+ LPC_CLKPWR_MACCLK_CTRL_REG |
+ LPC_CLKPWR_MACCLK_CTRL_SLAVE |
+ LPC_CLKPWR_MACCLK_CTRL_MASTER |
+ LPC_CLKPWR_MACCLK_CTRL_HDWINF(3));
+ /* Reset chip */
+ lpe_reset(sc);
+ /* Initialize MII */
+ val = lpe_read_4(sc, LPE_COMMAND);
+ lpe_write_4(sc, LPE_COMMAND, val | LPE_COMMAND_RMII);
+ if (mii_attach(dev, &sc->lpe_miibus, ifp, lpe_ifmedia_upd,
+ lpe_ifmedia_sts, BMSR_DEFCAPMASK, 0x01,
+ MII_OFFSET_ANY, 0)) {
+ device_printf(dev, "cannot find PHY\n");
+ goto fail;
+ lpe_dma_alloc(sc);
+ return (0);
+fail:
+ if (sc->lpe_ifp)
+ if_free(sc->lpe_ifp);
+ if (sc->lpe_intrhand)
+ bus_teardown_intr(dev, sc->lpe_irq_res, sc->lpe_intrhand);
+ if (sc->lpe_irq_res)
+ bus_release_resource(dev, SYS_RES_IRQ, 0, sc->lpe_irq_res);
+ if (sc->lpe_mem_res)
+ bus_release_resource(dev, SYS_RES_MEMORY, 0, sc->lpe_mem_res);
+ return (ENXIO);
+static int
+lpe_detach(device_t dev)
+ lpe_stop(sc);
+ return (0);
+static int
+lpe_miibus_readreg(device_t dev, int phy, int reg)
+ uint32_t val;
+ int result;
+ lpe_write_4(sc, LPE_MCMD, LPE_MCMD_READ);
+ lpe_write_4(sc, LPE_MADR,
+ (reg & LPE_MADR_REGMASK) << LPE_MADR_REGSHIFT |
+ (phy & LPE_MADR_PHYMASK) << LPE_MADR_PHYSHIFT);
+ val = lpe_read_4(sc, LPE_MIND);
+ /* Wait until request is completed */
+ while (val & LPE_MIND_BUSY) {
+ DELAY(10);
+ if (val & LPE_MIND_INVALID)
+ return (0);
+ lpe_write_4(sc, LPE_MCMD, 0);
+ result = (lpe_read_4(sc, LPE_MRDD) & LPE_MRDD_DATAMASK);
+ debugf("phy=%d reg=%d result=0x%04x\n", phy, reg, result);
+ return (result);
+static int
+lpe_miibus_writereg(device_t dev, int phy, int reg, int data)
+ uint32_t val;
+ debugf("phy=%d reg=%d data=0x%04x\n", phy, reg, data);
+ lpe_write_4(sc, LPE_MCMD, LPE_MCMD_WRITE);
+ lpe_write_4(sc, LPE_MWTD, (data & LPE_MWTD_DATAMASK));
+ DELAY(10);
+ return (0);
+static void
+lpe_miibus_statchg(device_t dev)
+ struct mii_data *mii = device_get_softc(sc->lpe_miibus);
+ lpe_lock(sc);
+ if ((mii->mii_media_status & IFM_ACTIVE) &&
+ (mii->mii_media_status & IFM_AVALID))
+ sc->lpe_flags |= LPE_FLAG_LINK;
+ else
+ sc->lpe_flags &= ~LPE_FLAG_LINK;
+ lpe_unlock(sc);
+static void
+lpe_reset(struct lpe_softc *sc)
+ uint32_t mac1;
+ /* Enter soft reset mode */
+ mac1 = lpe_read_4(sc, LPE_MAC1);
+ lpe_write_4(sc, LPE_MAC1, mac1 | LPE_MAC1_SOFTRESET | LPE_MAC1_RESETTX |
+ LPE_MAC1_RESETMCSTX | LPE_MAC1_RESETRX | LPE_MAC1_RESETMCSRX);
+ /* Reset registers, Tx path and Rx path */
+ lpe_write_4(sc, LPE_COMMAND, LPE_COMMAND_REGRESET |
+ LPE_COMMAND_TXRESET | LPE_COMMAND_RXRESET);
+ /* Set station address */
+ lpe_write_4(sc, LPE_SA2, sc->lpe_enaddr[1] << 8 | sc->lpe_enaddr[0]);
+ lpe_write_4(sc, LPE_SA1, sc->lpe_enaddr[3] << 8 | sc->lpe_enaddr[2]);
+ lpe_write_4(sc, LPE_SA0, sc->lpe_enaddr[5] << 8 | sc->lpe_enaddr[4]);
+ /* Leave soft reset mode */
+ lpe_write_4(sc, LPE_MAC1, mac1 & ~(LPE_MAC1_SOFTRESET | LPE_MAC1_RESETTX |
+ LPE_MAC1_RESETMCSTX | LPE_MAC1_RESETRX | LPE_MAC1_RESETMCSRX));
+static void
+lpe_init(void *arg)
+ struct lpe_softc *sc = (struct lpe_softc *)arg;
+ lpe_lock(sc);
+ lpe_init_locked(sc);
+ lpe_unlock(sc);
+static void
+lpe_init_locked(struct lpe_softc *sc)
+ struct ifnet *ifp = sc->lpe_ifp;
+ uint32_t cmd, mac1;
+ lpe_lock_assert(sc);
+ if (ifp->if_drv_flags & IFF_DRV_RUNNING)
+ return;
+ /* Enable Tx and Rx */
+ cmd = lpe_read_4(sc, LPE_COMMAND);
+ lpe_write_4(sc, LPE_COMMAND, cmd | LPE_COMMAND_RXENABLE |
+ LPE_COMMAND_TXENABLE | LPE_COMMAND_PASSRUNTFRAME);
+ /* Enable receive */
+ lpe_write_4(sc, LPE_MAC1, /*mac1 |*/ LPE_MAC1_RXENABLE | LPE_MAC1_PASSALL);
+ lpe_write_4(sc, LPE_MAC2, LPE_MAC2_CRCENABLE | LPE_MAC2_PADCRCENABLE |
+ LPE_MAC2_FULLDUPLEX);
+ lpe_write_4(sc, LPE_MCFG, LPE_MCFG_CLKSEL(7));
+ /* Set up Rx filter */
+ lpe_set_rxmode(sc);
+ /* Enable interrupts */
+ lpe_write_4(sc, LPE_INTENABLE, LPE_INT_RXOVERRUN | LPE_INT_RXERROR |
+ LPE_INT_RXFINISH | LPE_INT_RXDONE | LPE_INT_TXUNDERRUN |
+ LPE_INT_TXERROR | LPE_INT_TXFINISH | LPE_INT_TXDONE);
+ sc->lpe_cdata.lpe_tx_prod = 0;
+ sc->lpe_cdata.lpe_tx_last = 0;
+ sc->lpe_cdata.lpe_tx_used = 0;
+ lpe_init_rx(sc);
+ /* Initialize Rx packet and status descriptor heads */
+ lpe_write_4(sc, LPE_RXDESC, sc->lpe_rdata.lpe_rx_ring_phys);
+ lpe_write_4(sc, LPE_RXSTATUS, sc->lpe_rdata.lpe_rx_status_phys);
+ lpe_write_4(sc, LPE_RXDESC_NUMBER, LPE_RXDESC_NUM - 1);
+ lpe_write_4(sc, LPE_RXDESC_CONS, 0);
+ /* Initialize Tx packet and status descriptor heads */
+ lpe_write_4(sc, LPE_TXDESC, sc->lpe_rdata.lpe_tx_ring_phys);
+ lpe_write_4(sc, LPE_TXSTATUS, sc->lpe_rdata.lpe_tx_status_phys);
+ lpe_write_4(sc, LPE_TXDESC_NUMBER, LPE_TXDESC_NUM - 1);
+ lpe_write_4(sc, LPE_TXDESC_PROD, 0);
+ ifp->if_drv_flags |= IFF_DRV_RUNNING;
+ ifp->if_drv_flags &= ~IFF_DRV_OACTIVE;
+ callout_reset(&sc->lpe_tick, hz, lpe_tick, sc);
+static void
+lpe_start(struct ifnet *ifp)
+ struct lpe_softc *sc = (struct lpe_softc *)ifp->if_softc;
+ lpe_lock(sc);
+ lpe_start_locked(ifp);
+ lpe_unlock(sc);
+static void
+lpe_start_locked(struct ifnet *ifp)
+ struct mbuf *m_head;
+ int encap = 0;
+ while (!IFQ_DRV_IS_EMPTY(&ifp->if_snd)) {
+ if (lpe_read_4(sc, LPE_TXDESC_PROD) ==
+ lpe_read_4(sc, LPE_TXDESC_CONS) - 5)
+ break;
+ /* Dequeue first packet */
+ IFQ_DRV_DEQUEUE(&ifp->if_snd, m_head);
+ if (!m_head)
+ break;
+ lpe_encap(sc, &m_head);
+ encap++;
+ /* Submit new descriptor list */
+ if (encap) {
+ lpe_write_4(sc, LPE_TXDESC_PROD, sc->lpe_cdata.lpe_tx_prod);
+ sc->lpe_watchdog_timer = 5;
+static int
+lpe_encap(struct lpe_softc *sc, struct mbuf **m_head)
+ struct lpe_txdesc *txd;
+ struct lpe_hwdesc *hwd;
+ bus_dma_segment_t segs[LPE_MAXFRAGS];
+ int i, err, nsegs, prod;
+ M_ASSERTPKTHDR((*m_head));
+ prod = sc->lpe_cdata.lpe_tx_prod;
+ txd = &sc->lpe_cdata.lpe_tx_desc[prod];
+ debugf("starting with prod=%d\n", prod);
+ err = bus_dmamap_load_mbuf_sg(sc->lpe_cdata.lpe_tx_buf_tag,
+ txd->lpe_txdesc_dmamap, *m_head, segs, &nsegs, BUS_DMA_NOWAIT);
+ if (err)
+ return (err);
+ if (nsegs == 0) {
+ m_freem(*m_head);
+ *m_head = NULL;
+ return (EIO);
+ bus_dmamap_sync(sc->lpe_cdata.lpe_tx_buf_tag, txd->lpe_txdesc_dmamap,
+ BUS_DMASYNC_PREREAD);
+ bus_dmamap_sync(sc->lpe_cdata.lpe_tx_ring_tag, sc->lpe_cdata.lpe_tx_ring_map,
+ BUS_DMASYNC_POSTREAD | BUS_DMASYNC_POSTWRITE);
+ txd->lpe_txdesc_first = 1;
+ txd->lpe_txdesc_mbuf = *m_head;
+ for (i = 0; i < nsegs; i++) {
+ hwd = &sc->lpe_rdata.lpe_tx_ring[prod];
+ hwd->lhr_data = segs[i].ds_addr;
+ hwd->lhr_control = segs[i].ds_len - 1;
+ if (i == nsegs - 1) {
+ hwd->lhr_control |= LPE_HWDESC_LASTFLAG;
+ hwd->lhr_control |= LPE_HWDESC_INTERRUPT;
+ hwd->lhr_control |= LPE_HWDESC_CRC;
+ hwd->lhr_control |= LPE_HWDESC_PAD;
+ LPE_INC(prod, LPE_TXDESC_NUM);
+ BUS_DMASYNC_PREREAD | BUS_DMASYNC_PREWRITE);
+ sc->lpe_cdata.lpe_tx_used += nsegs;
+ sc->lpe_cdata.lpe_tx_prod = prod;
+ return (0);
+static void
+lpe_stop(struct lpe_softc *sc)
+ lpe_lock(sc);
+ lpe_stop_locked(sc);
+ lpe_unlock(sc);
+static void
+lpe_stop_locked(struct lpe_softc *sc)
+ callout_stop(&sc->lpe_tick);
+ /* Disable interrupts */
+ lpe_write_4(sc, LPE_INTCLEAR, 0xffffffff);
+ /* Stop EMAC */
+ lpe_write_4(sc, LPE_MAC1, 0);
+ lpe_write_4(sc, LPE_MAC2, 0);
+ lpe_write_4(sc, LPE_COMMAND, 0);
+ sc->lpe_ifp->if_drv_flags &= ~IFF_DRV_OACTIVE;
+ sc->lpe_ifp->if_drv_flags &= ~IFF_DRV_RUNNING;
+static int
+lpe_ioctl(struct ifnet *ifp, u_long cmd, caddr_t data)
+ struct lpe_softc *sc = ifp->if_softc;
+ struct ifreq *ifr = (struct ifreq *)data;
+ int err = 0;
+ switch (cmd) {
+ case SIOCSIFFLAGS:
+ lpe_lock(sc);
+ if (ifp->if_flags & IFF_UP) {
+ if (ifp->if_drv_flags & IFF_DRV_RUNNING) {
+ lpe_set_rxfilter(sc);
+ } else
+ } else
+ lpe_stop(sc);
+ lpe_unlock(sc);
+ break;
+ case SIOCADDMULTI:
+ case SIOCDELMULTI:
+ lpe_lock(sc);
+ lpe_unlock(sc);
+ break;
+ case SIOCGIFMEDIA:
+ case SIOCSIFMEDIA:
+ err = ifmedia_ioctl(ifp, ifr, &mii->mii_media, cmd);
+ break;
+ default:
+ err = ether_ioctl(ifp, cmd, data);
+ break;
+ return (err);
+static void lpe_set_rxmode(struct lpe_softc *sc)
+ uint32_t rxfilt;
+ rxfilt = LPE_RXFILTER_UNIHASH | LPE_RXFILTER_MULTIHASH | LPE_RXFILTER_PERFECT;
+ if (ifp->if_flags & IFF_BROADCAST)
+ rxfilt |= LPE_RXFILTER_BROADCAST;
+ if (ifp->if_flags & IFF_PROMISC)
+ rxfilt |= LPE_RXFILTER_UNICAST | LPE_RXFILTER_MULTICAST;
+ if (ifp->if_flags & IFF_ALLMULTI)
+ rxfilt |= LPE_RXFILTER_MULTICAST;
+ lpe_write_4(sc, LPE_RXFILTER_CTRL, rxfilt);
+static void lpe_set_rxfilter(struct lpe_softc *sc)
+ struct ifmultiaddr *ifma;
+ int index;
+ uint32_t hashl, hashh;
+ hashl = 0;
+ hashh = 0;
+ if_maddr_rlock(ifp);
+ TAILQ_FOREACH(ifma, &ifp->if_multiaddrs, ifma_link) {
+ if (ifma->ifma_addr->sa_family != AF_LINK)
+ continue;
+ index = ether_crc32_be(LLADDR((struct sockaddr_dl *)
+ ifma->ifma_addr), ETHER_ADDR_LEN) >> 23 & 0x3f;
+ if (index > 31)
+ hashh |= (1 << (index - 32));
+ else
+ hashl |= (1 << index);
+ if_maddr_runlock(ifp);
+ /* Program new hash filter */
+ lpe_write_4(sc, LPE_HASHFILTER_L, hashl);
+ lpe_write_4(sc, LPE_HASHFILTER_H, hashh);
+static void
+lpe_intr(void *arg)
+ uint32_t intstatus;
+ debugf("status=0x%08x\n", lpe_read_4(sc, LPE_INTSTATUS));
+ lpe_lock(sc);
+ while ((intstatus = lpe_read_4(sc, LPE_INTSTATUS))) {
+ if (intstatus & LPE_INT_RXDONE)
+ lpe_rxintr(sc);
+ if (intstatus & LPE_INT_TXDONE)
+ lpe_txintr(sc);
+ lpe_write_4(sc, LPE_INTCLEAR, 0xffff);
+ lpe_unlock(sc);
+static void
+lpe_rxintr(struct lpe_softc *sc)
+ struct lpe_hwstatus *hws;
+ struct lpe_rxdesc *rxd;
+ struct mbuf *m;
+ int prod, cons;
+ for (;;) {
+ prod = lpe_read_4(sc, LPE_RXDESC_PROD);
+ cons = lpe_read_4(sc, LPE_RXDESC_CONS);
+ if (prod == cons)
+ break;
+ rxd = &sc->lpe_cdata.lpe_rx_desc[cons];
+ hwd = &sc->lpe_rdata.lpe_rx_ring[cons];
+ hws = &sc->lpe_rdata.lpe_rx_status[cons];
+ /* Check received frame for errors */
+ if (hws->lhs_info & LPE_HWDESC_RXERRS) {
+ if_inc_counter(ifp, IFCOUNTER_IERRORS, 1);
+ lpe_discard_rxbuf(sc, cons);
+ lpe_init_rxbuf(sc, cons);
+ goto skip;
+ m = rxd->lpe_rxdesc_mbuf;
+ m->m_pkthdr.rcvif = ifp;
+ m->m_data += 2;
+ if_inc_counter(ifp, IFCOUNTER_IPACKETS, 1);
+ lpe_unlock(sc);
+ (*ifp->if_input)(ifp, m);
+ lpe_lock(sc);
+skip:
+ LPE_INC(cons, LPE_RXDESC_NUM);
+ lpe_write_4(sc, LPE_RXDESC_CONS, cons);
+static void
+lpe_txintr(struct lpe_softc *sc)
+ int cons, last;
+ for (;;) {
+ cons = lpe_read_4(sc, LPE_TXDESC_CONS);
+ last = sc->lpe_cdata.lpe_tx_last;
+ if (cons == last)
+ break;
+ txd = &sc->lpe_cdata.lpe_tx_desc[last];
+ hwd = &sc->lpe_rdata.lpe_tx_ring[last];
+ hws = &sc->lpe_rdata.lpe_tx_status[last];
+ txd->lpe_txdesc_dmamap, BUS_DMASYNC_POSTWRITE);
+ if_inc_counter(ifp, IFCOUNTER_COLLISIONS, LPE_HWDESC_COLLISIONS(hws->lhs_info));
+ if (hws->lhs_info & LPE_HWDESC_TXERRS)
+ if_inc_counter(ifp, IFCOUNTER_OERRORS, 1);
+ else
+ if_inc_counter(ifp, IFCOUNTER_OPACKETS, 1);
+ if (txd->lpe_txdesc_first) {
+ bus_dmamap_unload(sc->lpe_cdata.lpe_tx_buf_tag,
+ txd->lpe_txdesc_dmamap);
+ m_freem(txd->lpe_txdesc_mbuf);
+ txd->lpe_txdesc_mbuf = NULL;
+ txd->lpe_txdesc_first = 0;
+ sc->lpe_cdata.lpe_tx_used--;
+ LPE_INC(sc->lpe_cdata.lpe_tx_last, LPE_TXDESC_NUM);
+ if (!sc->lpe_cdata.lpe_tx_used)
+ sc->lpe_watchdog_timer = 0;
+static void
+lpe_tick(void *arg)
+ mii_tick(mii);
+ lpe_watchdog(sc);
+static void
+lpe_watchdog(struct lpe_softc *sc)
+ if (sc->lpe_watchdog_timer == 0 || sc->lpe_watchdog_timer--)
+ return;
+ /* Chip has stopped responding */
+ device_printf(sc->lpe_dev, "WARNING: chip hangup, restarting...\n");
+ /* Try to resend packets */
+ if (!IFQ_DRV_IS_EMPTY(&ifp->if_snd))
+static int
+lpe_dma_alloc(struct lpe_softc *sc)
+ int err;
+ /* Create parent DMA tag */
+ err = bus_dma_tag_create(
+ bus_get_dma_tag(sc->lpe_dev),
+ 1, 0, /* alignment, boundary */
+ BUS_SPACE_MAXADDR_32BIT, /* lowaddr */
+ BUS_SPACE_MAXADDR, /* highaddr */
+ NULL, NULL, /* filter, filterarg */
+ BUS_SPACE_MAXSIZE_32BIT, 0, /* maxsize, nsegments */
+ BUS_SPACE_MAXSIZE_32BIT, 0, /* maxsegsize, flags */
+ NULL, NULL, /* lockfunc, lockarg */
+ &sc->lpe_cdata.lpe_parent_tag);
+ if (err) {
+ device_printf(sc->lpe_dev, "cannot create parent DMA tag\n");
+ return (err);
+ err = lpe_dma_alloc_rx(sc);
+ if (err)
+ return (err);
+ err = lpe_dma_alloc_tx(sc);
+ if (err)
+ return (err);
+ return (0);
+static int
+lpe_dma_alloc_rx(struct lpe_softc *sc)
+ struct lpe_dmamap_arg ctx;
+ int err, i;
+ /* Create tag for Rx ring */
+ sc->lpe_cdata.lpe_parent_tag,
+ LPE_DESC_ALIGN, 0, /* alignment, boundary */
+ BUS_SPACE_MAXADDR, /* lowaddr */
+ LPE_RXDESC_SIZE, 1, /* maxsize, nsegments */
+ LPE_RXDESC_SIZE, 0, /* maxsegsize, flags */
+ &sc->lpe_cdata.lpe_rx_ring_tag);
+ if (err) {
+ device_printf(sc->lpe_dev, "cannot create Rx ring DMA tag\n");
+ goto fail;
+ /* Create tag for Rx status ring */
+ LPE_RXSTATUS_SIZE, 1, /* maxsize, nsegments */
+ LPE_RXSTATUS_SIZE, 0, /* maxsegsize, flags */
+ &sc->lpe_cdata.lpe_rx_status_tag);
+ if (err) {
+ device_printf(sc->lpe_dev, "cannot create Rx status ring DMA tag\n");
+ goto fail;
+ /* Create tag for Rx buffers */
+ MCLBYTES * LPE_RXDESC_NUM, /* maxsize */
+ LPE_RXDESC_NUM, /* segments */
+ MCLBYTES, 0, /* maxsegsize, flags */
+ &sc->lpe_cdata.lpe_rx_buf_tag);
+ if (err) {
+ device_printf(sc->lpe_dev, "cannot create Rx buffers DMA tag\n");
+ goto fail;
+ /* Allocate Rx DMA ring */
+ err = bus_dmamem_alloc(sc->lpe_cdata.lpe_rx_ring_tag,
+ (void **)&sc->lpe_rdata.lpe_rx_ring, BUS_DMA_WAITOK | BUS_DMA_COHERENT |
+ BUS_DMA_ZERO, &sc->lpe_cdata.lpe_rx_ring_map);
+ err = bus_dmamap_load(sc->lpe_cdata.lpe_rx_ring_tag,
+ sc->lpe_cdata.lpe_rx_ring_map, sc->lpe_rdata.lpe_rx_ring,
+ LPE_RXDESC_SIZE, lpe_dmamap_cb, &ctx, 0);
+ sc->lpe_rdata.lpe_rx_ring_phys = ctx.lpe_dma_busaddr;
+ /* Allocate Rx status ring */
+ err = bus_dmamem_alloc(sc->lpe_cdata.lpe_rx_status_tag,
+ (void **)&sc->lpe_rdata.lpe_rx_status, BUS_DMA_WAITOK | BUS_DMA_COHERENT |
+ BUS_DMA_ZERO, &sc->lpe_cdata.lpe_rx_status_map);
+ err = bus_dmamap_load(sc->lpe_cdata.lpe_rx_status_tag,
+ sc->lpe_cdata.lpe_rx_status_map, sc->lpe_rdata.lpe_rx_status,
+ sc->lpe_rdata.lpe_rx_status_phys = ctx.lpe_dma_busaddr;
+ /* Create Rx buffers DMA map */
+ for (i = 0; i < LPE_RXDESC_NUM; i++) {
+ rxd = &sc->lpe_cdata.lpe_rx_desc[i];
+ rxd->lpe_rxdesc_mbuf = NULL;
+ rxd->lpe_rxdesc_dmamap = NULL;
+ err = bus_dmamap_create(sc->lpe_cdata.lpe_rx_buf_tag, 0,
+ &rxd->lpe_rxdesc_dmamap);
+ if (err) {
+ device_printf(sc->lpe_dev, "cannot create Rx DMA map\n");
+ return (err);
+ return (0);
+fail:
+ return (err);
+static int
+lpe_dma_alloc_tx(struct lpe_softc *sc)
+ int err, i;
+ /* Create tag for Tx ring */
+ LPE_TXDESC_SIZE, 1, /* maxsize, nsegments */
+ LPE_TXDESC_SIZE, 0, /* maxsegsize, flags */
+ &sc->lpe_cdata.lpe_tx_ring_tag);
+ if (err) {
+ device_printf(sc->lpe_dev, "cannot create Tx ring DMA tag\n");
+ goto fail;
+ /* Create tag for Tx status ring */
+ LPE_TXSTATUS_SIZE, 1, /* maxsize, nsegments */
+ LPE_TXSTATUS_SIZE, 0, /* maxsegsize, flags */
+ &sc->lpe_cdata.lpe_tx_status_tag);
+ if (err) {
+ device_printf(sc->lpe_dev, "cannot create Tx status ring DMA tag\n");
+ goto fail;
+ /* Create tag for Tx buffers */
+ MCLBYTES * LPE_TXDESC_NUM, /* maxsize */
+ LPE_TXDESC_NUM, /* segments */
+ &sc->lpe_cdata.lpe_tx_buf_tag);
+ if (err) {
+ device_printf(sc->lpe_dev, "cannot create Tx buffers DMA tag\n");
+ goto fail;
+ /* Allocate Tx DMA ring */
+ err = bus_dmamem_alloc(sc->lpe_cdata.lpe_tx_ring_tag,
+ (void **)&sc->lpe_rdata.lpe_tx_ring, BUS_DMA_WAITOK | BUS_DMA_COHERENT |
+ BUS_DMA_ZERO, &sc->lpe_cdata.lpe_tx_ring_map);
+ err = bus_dmamap_load(sc->lpe_cdata.lpe_tx_ring_tag,
+ sc->lpe_cdata.lpe_tx_ring_map, sc->lpe_rdata.lpe_tx_ring,
+ sc->lpe_rdata.lpe_tx_ring_phys = ctx.lpe_dma_busaddr;
+ /* Allocate Tx status ring */
+ err = bus_dmamem_alloc(sc->lpe_cdata.lpe_tx_status_tag,
+ (void **)&sc->lpe_rdata.lpe_tx_status, BUS_DMA_WAITOK | BUS_DMA_COHERENT |
+ BUS_DMA_ZERO, &sc->lpe_cdata.lpe_tx_status_map);
+ err = bus_dmamap_load(sc->lpe_cdata.lpe_tx_status_tag,
+ sc->lpe_cdata.lpe_tx_status_map, sc->lpe_rdata.lpe_tx_status,
+ sc->lpe_rdata.lpe_tx_status_phys = ctx.lpe_dma_busaddr;
+ /* Create Tx buffers DMA map */
+ for (i = 0; i < LPE_TXDESC_NUM; i++) {
+ txd = &sc->lpe_cdata.lpe_tx_desc[i];
+ txd->lpe_txdesc_dmamap = NULL;
+ err = bus_dmamap_create(sc->lpe_cdata.lpe_tx_buf_tag, 0,
+ &txd->lpe_txdesc_dmamap);
+ if (err) {
+ device_printf(sc->lpe_dev, "cannot create Tx DMA map\n");
+ return (err);
+ return (0);
+fail:
+ return (err);
+static int
+lpe_init_rx(struct lpe_softc *sc)
+ int i, err;
+ err = lpe_init_rxbuf(sc, i);
+ if (err)
+ return (err);
+ return (0);
+static int
+lpe_init_rxbuf(struct lpe_softc *sc, int n)
+ struct mbuf *m;
+ bus_dma_segment_t segs[1];
+ int nsegs;
+ rxd = &sc->lpe_cdata.lpe_rx_desc[n];
+ hwd = &sc->lpe_rdata.lpe_rx_ring[n];
+ hws = &sc->lpe_rdata.lpe_rx_status[n];
+ m = m_getcl(M_NOWAIT, MT_DATA, M_PKTHDR);
+ if (!m) {
+ device_printf(sc->lpe_dev, "WARNING: mbufs exhausted!\n");
+ return (ENOBUFS);
+ m->m_len = m->m_pkthdr.len = MCLBYTES;
+ bus_dmamap_unload(sc->lpe_cdata.lpe_rx_buf_tag, rxd->lpe_rxdesc_dmamap);
+ if (bus_dmamap_load_mbuf_sg(sc->lpe_cdata.lpe_rx_buf_tag,
+ rxd->lpe_rxdesc_dmamap, m, segs, &nsegs, 0)) {
+ m_freem(m);
+ return (ENOBUFS);
+ bus_dmamap_sync(sc->lpe_cdata.lpe_rx_buf_tag, rxd->lpe_rxdesc_dmamap,
+ rxd->lpe_rxdesc_mbuf = m;
+ hwd->lhr_data = segs[0].ds_addr + 2;
+ hwd->lhr_control = (segs[0].ds_len - 1) | LPE_HWDESC_INTERRUPT;
+ return (0);
+static void
+lpe_discard_rxbuf(struct lpe_softc *sc, int n)
+ hwd->lhr_data = 0;
+ hwd->lhr_control = 0;
+ if (rxd->lpe_rxdesc_mbuf) {
+ m_freem(rxd->lpe_rxdesc_mbuf);
+static void
+lpe_dmamap_cb(void *arg, bus_dma_segment_t *segs, int nseg, int error)
+ struct lpe_dmamap_arg *ctx;
+ if (error)
+ return;
+ ctx = (struct lpe_dmamap_arg *)arg;
+ ctx->lpe_dma_busaddr = segs[0].ds_addr;
+static int
+lpe_ifmedia_upd(struct ifnet *ifp)
+ return (0);
+static void
+lpe_ifmedia_sts(struct ifnet *ifp, struct ifmediareq *ifmr)
+ lpe_lock(sc);
+ mii_pollstat(mii);
+ ifmr->ifm_active = mii->mii_media_active;
+ ifmr->ifm_status = mii->mii_media_status;
+ lpe_unlock(sc);
+static device_method_t lpe_methods[] = {
+ /* Device interface */
+ DEVMETHOD(device_probe, lpe_probe),
+ DEVMETHOD(device_attach, lpe_attach),
+ DEVMETHOD(device_detach, lpe_detach),
+ /* Bus interface */
+ DEVMETHOD(bus_print_child, bus_generic_print_child),
+ /* MII interface */
+ DEVMETHOD(miibus_readreg, lpe_miibus_readreg),
+ DEVMETHOD(miibus_writereg, lpe_miibus_writereg),
+ DEVMETHOD(miibus_statchg, lpe_miibus_statchg),
+ { 0, 0 }
+static driver_t lpe_driver = {
+ "lpe",
+ lpe_methods,
+ sizeof(struct lpe_softc),
+static devclass_t lpe_devclass;
+DRIVER_MODULE(lpe, simplebus, lpe_driver, lpe_devclass, 0, 0);
+DRIVER_MODULE(miibus, lpe, miibus_driver, miibus_devclass, 0, 0);
+MODULE_DEPEND(lpe, obio, 1, 1, 1);
+MODULE_DEPEND(lpe, miibus, 1, 1, 1);
+MODULE_DEPEND(lpe, ether, 1, 1, 1);
diff --git a/freebsd/sys/arm/lpc/if_lpereg.h b/freebsd/sys/arm/lpc/if_lpereg.h
index 0000000..8e1512b
--- /dev/null
+++ b/freebsd/sys/arm/lpc/if_lpereg.h
@@ -0,0 +1,208 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _ARM_LPC_IF_LPEREG_H
+#define _ARM_LPC_IF_LPEREG_H
+#define LPE_MAC1 0x000
+#define LPE_MAC1_RXENABLE (1 << 0)
+#define LPE_MAC1_PASSALL (1 << 1)
+#define LPE_MAC1_RXFLOWCTRL (1 << 2)
+#define LPE_MAC1_TXFLOWCTRL (1 << 3)
+#define LPE_MAC1_LOOPBACK (1 << 4)
+#define LPE_MAC1_RESETTX (1 << 8)
+#define LPE_MAC1_RESETMCSTX (1 << 9)
+#define LPE_MAC1_RESETRX (1 << 10)
+#define LPE_MAC1_RESETMCSRX (1 << 11)
+#define LPE_MAC1_SIMRESET (1 << 14)
+#define LPE_MAC1_SOFTRESET (1 << 15)
+#define LPE_MAC2 0x004
+#define LPE_MAC2_FULLDUPLEX (1 << 0)
+#define LPE_MAC2_FRAMELENCHECK (1 << 1)
+#define LPE_MAC2_HUGEFRAME (1 << 2)
+#define LPE_MAC2_DELAYEDCRC (1 << 3)
+#define LPE_MAC2_CRCENABLE (1 << 4)
+#define LPE_MAC2_PADCRCENABLE (1 << 5)
+#define LPE_MAC2_VLANPADENABLE (1 << 6)
+#define LPE_MAC2_AUTOPADENABLE (1 << 7)
+#define LPE_MAC2_PUREPREAMBLE (1 << 8)
+#define LPE_MAC2_LONGPREAMBLE (1 << 9)
+#define LPE_MAC2_NOBACKOFF (1 << 12)
+#define LPE_MAC2_BACKPRESSURE (1 << 13)
+#define LPE_MAC2_EXCESSDEFER (1 << 14)
+#define LPE_IPGT 0x008
+#define LPE_IPGR 0x00c
+#define LPE_CLRT 0x010
+#define LPE_MAXF 0x014
+#define LPE_SUPP 0x018
+#define LPE_SUPP_SPEED (1 << 8)
+#define LPE_TEST 0x01c
+#define LPE_MCFG 0x020
+#define LPE_MCFG_SCANINCR (1 << 0)
+#define LPE_MCFG_SUPPREAMBLE (1 << 1)
+#define LPE_MCFG_CLKSEL(_n) ((_n & 0x7) << 2)
+#define LPC_MCFG_RESETMII (1 << 15)
+#define LPE_MCMD 0x024
+#define LPE_MCMD_READ (1 << 0)
+#define LPE_MCMD_WRITE (0 << 0)
+#define LPE_MCMD_SCAN (1 << 1)
+#define LPE_MADR 0x028
+#define LPE_MADR_REGMASK 0x1f
+#define LPE_MADR_REGSHIFT 0
+#define LPE_MADR_PHYMASK 0x1f
+#define LPE_MADR_PHYSHIFT 8
+#define LPE_MWTD 0x02c
+#define LPE_MWTD_DATAMASK 0xffff
+#define LPE_MRDD 0x030
+#define LPE_MRDD_DATAMASK 0xffff
+#define LPE_MIND 0x034
+#define LPE_MIND_BUSY (1 << 0)
+#define LPE_MIND_SCANNING (1 << 1)
+#define LPE_MIND_INVALID (1 << 2)
+#define LPE_MIND_MIIFAIL (1 << 3)
+#define LPE_SA0 0x040
+#define LPE_SA1 0x044
+#define LPE_SA2 0x048
+#define LPE_COMMAND 0x100
+#define LPE_COMMAND_RXENABLE (1 << 0)
+#define LPE_COMMAND_TXENABLE (1 << 1)
+#define LPE_COMMAND_REGRESET (1 << 3)
+#define LPE_COMMAND_TXRESET (1 << 4)
+#define LPE_COMMAND_RXRESET (1 << 5)
+#define LPE_COMMAND_PASSRUNTFRAME (1 << 6)
+#define LPE_COMMAND_PASSRXFILTER (1 << 7)
+#define LPE_COMMAND_TXFLOWCTL (1 << 8)
+#define LPE_COMMAND_RMII (1 << 9)
+#define LPE_COMMAND_FULLDUPLEX (1 << 10)
+#define LPE_STATUS 0x104
+#define LPE_STATUS_RXACTIVE (1 << 0)
+#define LPE_STATUS_TXACTIVE (1 << 1)
+#define LPE_RXDESC 0x108
+#define LPE_RXSTATUS 0x10c
+#define LPE_RXDESC_NUMBER 0x110
+#define LPE_RXDESC_PROD 0x114
+#define LPE_RXDESC_CONS 0x118
+#define LPE_TXDESC 0x11c
+#define LPE_TXSTATUS 0x120
+#define LPE_TXDESC_NUMBER 0x124
+#define LPE_TXDESC_PROD 0x128
+#define LPE_TXDESC_CONS 0x12c
+#define LPE_TSV0 0x158
+#define LPE_TSV1 0x15c
+#define LPE_RSV 0x160
+#define LPE_FLOWCONTROL_COUNTER 0x170
+#define LPE_FLOWCONTROL_STATUS 0x174
+#define LPE_RXFILTER_CTRL 0x200
+#define LPE_RXFILTER_UNICAST (1 << 0)
+#define LPE_RXFILTER_BROADCAST (1 << 1)
+#define LPE_RXFILTER_MULTICAST (1 << 2)
+#define LPE_RXFILTER_UNIHASH (1 << 3)
+#define LPE_RXFILTER_MULTIHASH (1 << 4)
+#define LPE_RXFILTER_PERFECT (1 << 5)
+#define LPE_RXFILTER_WOL (1 << 12)
+#define LPE_RXFILTER_FILTWOL (1 << 13)
+#define LPE_RXFILTER_WOL_STATUS 0x204
+#define LPE_RXFILTER_WOL_CLEAR 0x208
+#define LPE_HASHFILTER_L 0x210
+#define LPE_HASHFILTER_H 0x214
+#define LPE_INTSTATUS 0xfe0
+#define LPE_INTENABLE 0xfe4
+#define LPE_INTCLEAR 0xfe8
+#define LPE_INTSET 0xfec
+#define LPE_INT_RXOVERRUN (1 << 0)
+#define LPE_INT_RXERROR (1 << 1)
+#define LPE_INT_RXFINISH (1 << 2)
+#define LPE_INT_RXDONE (1 << 3)
+#define LPE_INT_TXUNDERRUN (1 << 4)
+#define LPE_INT_TXERROR (1 << 5)
+#define LPE_INT_TXFINISH (1 << 6)
+#define LPE_INT_TXDONE (1 << 7)
+#define LPE_INT_SOFTINT (1 << 12)
+#define LPE_INTWAKEUPINT (1 << 13)
+#define LPE_POWERDOWN 0xff4
+#define LPE_DESC_ALIGN 8
+#define LPE_TXDESC_NUM 128
+#define LPE_RXDESC_NUM 128
+#define LPE_TXDESC_SIZE (LPE_TXDESC_NUM * sizeof(struct lpe_hwdesc))
+#define LPE_RXDESC_SIZE (LPE_RXDESC_NUM * sizeof(struct lpe_hwdesc))
+#define LPE_TXSTATUS_SIZE (LPE_TXDESC_NUM * sizeof(struct lpe_hwstatus))
+#define LPE_RXSTATUS_SIZE (LPE_RXDESC_NUM * sizeof(struct lpe_hwstatus))
+#define LPE_MAXFRAGS 8
+struct lpe_hwdesc {
+ uint32_t lhr_data;
+ uint32_t lhr_control;
+struct lpe_hwstatus {
+ uint32_t lhs_info;
+ uint32_t lhs_crc;
+#define LPE_INC(x, y) (x) = ((x) == ((y)-1)) ? 0 : (x)+1
+/* These are valid for both Rx and Tx descriptors */
+#define LPE_HWDESC_SIZE_MASK (1 << 10)
+#define LPE_HWDESC_INTERRUPT (1U << 31)
+/* These are valid for Tx descriptors */
+#define LPE_HWDESC_LAST (1 << 30)
+#define LPE_HWDESC_CRC (1 << 29)
+#define LPE_HWDESC_PAD (1 << 28)
+#define LPE_HWDESC_HUGE (1 << 27)
+#define LPE_HWDESC_OVERRIDE (1 << 26)
+/* These are valid for Tx status descriptors */
+#define LPE_HWDESC_COLLISIONS(_n) (((_n) >> 21) & 0x7)
+#define LPE_HWDESC_DEFER (1 << 25)
+#define LPE_HWDESC_EXCDEFER (1 << 26)
+#define LPE_HWDESC_EXCCOLL (1 << 27)
+#define LPE_HWDESC_LATECOLL (1 << 28)
+#define LPE_HWDESC_UNDERRUN (1 << 29)
+#define LPE_HWDESC_TXNODESCR (1 << 30)
+#define LPE_HWDESC_ERROR (1U << 31)
+/* These are valid for Rx status descriptors */
+#define LPE_HWDESC_CONTROL (1 << 18)
+#define LPE_HWDESC_VLAN (1 << 19)
+#define LPE_HWDESC_FAILFILTER (1 << 20)
+#define LPE_HWDESC_MULTICAST (1 << 21)
+#define LPE_HWDESC_BROADCAST (1 << 22)
+#define LPE_HWDESC_CRCERROR (1 << 23)
+#define LPE_HWDESC_SYMBOLERROR (1 << 24)
+#define LPE_HWDESC_LENGTHERROR (1 << 25)
+#define LPE_HWDESC_RANGEERROR (1 << 26)
+#define LPE_HWDESC_ALIGNERROR (1 << 27)
+#define LPE_HWDESC_OVERRUN (1 << 28)
+#define LPE_HWDESC_RXNODESCR (1 << 29)
+#define LPE_HWDESC_LASTFLAG (1 << 30)
+#endif /* _ARM_LPC_IF_LPEREG_H */
diff --git a/freebsd/sys/arm/lpc/lpc_pwr.c b/freebsd/sys/arm/lpc/lpc_pwr.c
index 0000000..0ea8c6a
--- /dev/null
+++ b/freebsd/sys/arm/lpc/lpc_pwr.c
@@ -0,0 +1,131 @@
+ * are met:
+ * SUCH DAMAGE.
+struct lpc_pwr_softc {
+ device_t dp_dev;
+ struct resource * dp_mem_res;
+ bus_space_tag_t dp_bst;
+ bus_space_handle_t dp_bsh;
+static struct lpc_pwr_softc *lpc_pwr_sc = NULL;
+static int lpc_pwr_probe(device_t);
+static int lpc_pwr_attach(device_t);
+#define lpc_pwr_read_4(_sc, _reg) \
+ bus_space_read_4((_sc)->dp_bst, (_sc)->dp_bsh, _reg)
+#define lpc_pwr_write_4(_sc, _reg, _val) \
+ bus_space_write_4((_sc)->dp_bst, (_sc)->dp_bsh, _reg, _val)
+static int
+lpc_pwr_probe(device_t dev)
+ return (ENXIO);
+ if (!ofw_bus_is_compatible(dev, "lpc,pwr"))
+ return (ENXIO);
+ device_set_desc(dev, "LPC32x0 Power Controller");
+static int
+lpc_pwr_attach(device_t dev)
+ struct lpc_pwr_softc *sc = device_get_softc(dev);
+ int rid;
+ sc->dp_dev = dev;
+ rid = 0;
+ sc->dp_mem_res = bus_alloc_resource_any(dev, SYS_RES_MEMORY, &rid,
+ RF_ACTIVE);
+ if (!sc->dp_mem_res) {
+ return (ENXIO);
+ sc->dp_bst = rman_get_bustag(sc->dp_mem_res);
+ sc->dp_bsh = rman_get_bushandle(sc->dp_mem_res);
+ lpc_pwr_sc = sc;
+ return (0);
+uint32_t
+lpc_pwr_read(device_t dev, int reg)
+ return (lpc_pwr_read_4(lpc_pwr_sc, reg));
+void
+lpc_pwr_write(device_t dev, int reg, uint32_t value)
+ lpc_pwr_write_4(lpc_pwr_sc, reg, value);
+static device_method_t lpc_pwr_methods[] = {
+ DEVMETHOD(device_probe, lpc_pwr_probe),
+ DEVMETHOD(device_attach, lpc_pwr_attach),
+ { 0, 0 }
+static devclass_t lpc_pwr_devclass;
+static driver_t lpc_pwr_driver = {
+ "pwr",
+ lpc_pwr_methods,
+ sizeof(struct lpc_pwr_softc),
+DRIVER_MODULE(pwr, simplebus, lpc_pwr_driver, lpc_pwr_devclass, 0, 0);
diff --git a/freebsd/sys/arm/lpc/lpcreg.h b/freebsd/sys/arm/lpc/lpcreg.h
index 0000000..b63dfbc
--- /dev/null
+++ b/freebsd/sys/arm/lpc/lpcreg.h
@@ -0,0 +1,665 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _ARM_LPC_LPCREG_H
+#define _ARM_LPC_LPCREG_H
+#define LPC_DEV_PHYS_BASE 0x40000000
+#define LPC_DEV_P5_PHYS_BASE 0x20000000
+#define LPC_DEV_P6_PHYS_BASE 0x30000000
+#define LPC_DEV_SIZE 0x10000000
+ * Interrupt controller (from UM10326: LPC32x0 User manual, page 87)
+#define LPC_INTC_MIC_ER 0x0000
+#define LPC_INTC_MIC_RSR 0x0004
+#define LPC_INTC_MIC_SR 0x0008
+#define LPC_INTC_MIC_APR 0x000c
+#define LPC_INTC_MIC_ATR 0x0010
+#define LPC_INTC_MIC_ITR 0x0014
+#define LPC_INTC_SIC1_ER 0x4000
+#define LPC_INTC_SIC1_RSR 0x4004
+#define LPC_INTC_SIC1_SR 0x4008
+#define LPC_INTC_SIC1_APR 0x400c
+#define LPC_INTC_SIC1_ATR 0x4010
+#define LPC_INTC_SIC1_ITR 0x4014
+#define LPC_INTC_SIC2_ER 0x8000
+#define LPC_INTC_SIC2_RSR 0x8004
+#define LPC_INTC_SIC2_SR 0x8008
+#define LPC_INTC_SIC2_APR 0x800c
+#define LPC_INTC_SIC2_ATR 0x8010
+#define LPC_INTC_SIC2_ITR 0x8014
+ * Timer 0|1|2|3|4|5. (from UM10326: LPC32x0 User manual, page 540)
+#define LPC_TIMER_IR 0x00
+#define LPC_TIMER_TCR 0x04
+#define LPC_TIMER_TCR_ENABLE (1 << 0)
+#define LPC_TIMER_TCR_RESET (1 << 1)
+#define LPC_TIMER_TC 0x08
+#define LPC_TIMER_PR 0x0c
+#define LPC_TIMER_PC 0x10
+#define LPC_TIMER_MCR 0x14
+#define LPC_TIMER_MCR_MR0I (1 << 0)
+#define LPC_TIMER_MCR_MR0R (1 << 1)
+#define LPC_TIMER_MCR_MR0S (1 << 2)
+#define LPC_TIMER_MCR_MR1I (1 << 3)
+#define LPC_TIMER_MCR_MR1R (1 << 4)
+#define LPC_TIMER_MCR_MR1S (1 << 5)
+#define LPC_TIMER_MCR_MR2I (1 << 6)
+#define LPC_TIMER_MCR_MR2R (1 << 7)
+#define LPC_TIMER_MCR_MR2S (1 << 8)
+#define LPC_TIMER_MCR_MR3I (1 << 9)
+#define LPC_TIMER_MCR_MR3R (1 << 10)
+#define LPC_TIMER_MCR_MR3S (1 << 11)
+#define LPC_TIMER_MR0 0x18
+#define LPC_TIMER_CTCR 0x70
+ * Watchdog timer. (from UM10326: LPC32x0 User manual, page 572)
+#define LPC_WDTIM_PHYS_BASE (LPC_DEV_PHYS_BASE + 0x3c000)
+#define LPC_WDTIM_INT 0x00
+#define LPC_WDTIM_CTRL 0x04
+#define LPC_WDTIM_COUNTER 0x08
+#define LPC_WDTIM_MCTRL 0x0c
+#define LPC_WDTIM_MATCH0 0x10
+#define LPC_WDTIM_EMR 0x14
+#define LPC_WDTIM_PULSE 0x18
+#define LPC_WDTIM_RES 0x1c
+#define LPC_WDTIM_SIZE 0x20
+ * Clocking and power control. (from UM10326: LPC32x0 User manual, page 58)
+#define LPC_CLKPWR_PHYS_BASE (LPC_DEV_PHYS_BASE + 0x4000)
+#define LPC_CLKPWR_PWR_CTRL 0x44
+#define LPC_CLKPWR_OSC_CTRL 0x4c
+#define LPC_CLKPWR_SYSCLK_CTRL 0x50
+#define LPC_CLKPWR_PLL397_CTRL 0x48
+#define LPC_CLKPWR_HCLKPLL_CTRL 0x58
+#define LPC_CLKPWR_HCLKDIV_CTRL 0x40
+#define LPC_CLKPWR_TEST_CTRL 0xa4
+#define LPC_CLKPWR_AUTOCLK_CTRL 0xec
+#define LPC_CLKPWR_START_ER_PIN 0x30
+#define LPC_CLKPWR_START_ER_INT 0x20
+#define LPC_CLKPWR_P0_INTR_ER 0x18
+#define LPC_CLKPWR_START_SR_PIN 0x38
+#define LPC_CLKPWR_START_SR_INT 0x28
+#define LPC_CLKPWR_START_RSR_PIN 0x34
+#define LPC_CLKPWR_START_RSR_INT 0x24
+#define LPC_CLKPWR_START_APR_PIN 0x3c
+#define LPC_CLKPWR_START_APR_INT 0x2c
+#define LPC_CLKPWR_USB_CTRL 0x64
+#define LPC_CLKPWR_USB_CTRL_SLAVE_HCLK (1 << 24)
+#define LPC_CLKPWR_USB_CTRL_I2C_EN (1 << 23)
+#define LPC_CLKPWR_USB_CTRL_DEV_NEED_CLK_EN (1 << 22)
+#define LPC_CLKPWR_USB_CTRL_HOST_NEED_CLK_EN (1 << 21)
+#define LPC_CLKPWR_USB_CTRL_BUSKEEPER (1 << 19)
+#define LPC_CLKPWR_USB_CTRL_CLK_EN2 (1 << 18)
+#define LPC_CLKPWR_USB_CTRL_CLK_EN1 (1 << 17)
+#define LPC_CLKPWR_USB_CTRL_PLL_PDOWN (1 << 16)
+#define LPC_CLKPWR_USB_CTRL_BYPASS (1 << 15)
+#define LPC_CLKPWR_USB_CTRL_DIRECT_OUT (1 << 14)
+#define LPC_CLKPWR_USB_CTRL_FEEDBACK (1 << 13)
+#define LPC_CLKPWR_USB_CTRL_POSTDIV(_x) ((_x & 0x3) << 11)
+#define LPC_CLKPWR_USB_CTRL_PREDIV(_x) ((_x & 0x3) << 9)
+#define LPC_CLKPWR_USB_CTRL_FDBKDIV(_x) (((_x-1) & 0xff) << 1)
+#define LPC_CLKPWR_USB_CTRL_PLL_LOCK (1 << 0)
+#define LPC_CLKPWR_USBDIV_CTRL 0x1c
+#define LPC_CLKPWR_MS_CTRL 0x80
+#define LPC_CLKPWR_MS_CTRL_DISABLE_SD (1 << 10)
+#define LPC_CLKPWR_MS_CTRL_CLOCK_EN (1 << 9)
+#define LPC_CLKPWR_MS_CTRL_MSSDIO23_PAD (1 << 8)
+#define LPC_CLKPWR_MS_CTRL_MSSDIO1_PAD (1 << 7)
+#define LPC_CLKPWR_MS_CTRL_MSSDIO0_PAD (1 << 6)
+#define LPC_CLKPWR_MS_CTRL_SD_CLOCK (1 << 5)
+#define LPC_CLKPWR_MS_CTRL_CLKDIV_MASK 0xf
+#define LPC_CLKPWR_DMACLK_CTRL 0xe8
+#define LPC_CLKPWR_DMACLK_CTRL_EN (1 << 0)
+#define LPC_CLKPWR_FLASHCLK_CTRL 0xc8
+#define LPC_CLKPWR_MACCLK_CTRL 0x90
+#define LPC_CLKPWR_MACCLK_CTRL_REG (1 << 0)
+#define LPC_CLKPWR_MACCLK_CTRL_SLAVE (1 << 1)
+#define LPC_CLKPWR_MACCLK_CTRL_MASTER (1 << 2)
+#define LPC_CLKPWR_MACCLK_CTRL_HDWINF(_n) ((_n & 0x3) << 3)
+#define LPC_CLKPWR_LCDCLK_CTRL 0x54
+#define LPC_CLKPWR_LCDCLK_CTRL_DISPTYPE (1 << 8)
+#define LPC_CLKPWR_LCDCLK_CTRL_MODE(_n) ((_n & 0x3) << 6)
+#define LPC_CLKPWR_LCDCLK_CTRL_MODE_12 0x0
+#define LPC_CLKPWR_LCDCLK_CTRL_MODE_15 0x1
+#define LPC_CLKPWR_LCDCLK_CTRL_MODE_16 0x2
+#define LPC_CLKPWR_LCDCLK_CTRL_MODE_24 0x3
+#define LPC_CLKPWR_LCDCLK_CTRL_HCLKEN (1 << 5)
+#define LPC_CLKPWR_LCDCLK_CTRL_CLKDIV(_n) ((_n) & 0x1f)
+#define LPC_CLKPWR_I2S_CTRL 0x7c
+#define LPC_CLKPWR_SSP_CTRL 0x78
+#define LPC_CLKPWR_SSP_CTRL_SSP1RXDMA (1 << 5)
+#define LPC_CLKPWR_SSP_CTRL_SSP1TXDMA (1 << 4)
+#define LPC_CLKPWR_SSP_CTRL_SSP0RXDMA (1 << 3)
+#define LPC_CLKPWR_SSP_CTRL_SSP0TXDMA (1 << 2)
+#define LPC_CLKPWR_SSP_CTRL_SSP1EN (1 << 1)
+#define LPC_CLKPWR_SSP_CTRL_SSP0EN (1 << 0)
+#define LPC_CLKPWR_SPI_CTRL 0xc4
+#define LPC_CLKPWR_I2CCLK_CTRL 0xac
+#define LPC_CLKPWR_TIMCLK_CTRL1 0xc0
+#define LPC_CLKPWR_TIMCLK_CTRL1_TIMER4 (1 << 0)
+#define LPC_CLKPWR_TIMCLK_CTRL1_TIMER5 (1 << 1)
+#define LPC_CLKPWR_TIMCLK_CTRL1_TIMER0 (1 << 2)
+#define LPC_CLKPWR_TIMCLK_CTRL1_TIMER1 (1 << 3)
+#define LPC_CLKPWR_TIMCLK_CTRL1_TIMER2 (1 << 4)
+#define LPC_CLKPWR_TIMCLK_CTRL1_TIMER3 (1 << 5)
+#define LPC_CLKPWR_TIMCLK_CTRL1_MOTORCTL (1 << 6)
+#define LPC_CLKPWR_TIMCLK_CTRL 0xbc
+#define LPC_CLKPWR_TIMCLK_CTRL_WATCHDOG (1 << 0)
+#define LPC_CLKPWR_TIMCLK_CTRL_HSTIMER (1 << 1)
+#define LPC_CLKPWR_ADCLK_CTRL 0xb4
+#define LPC_CLKPWR_ADCLK_CTRL1 0x60
+#define LPC_CLKPWR_KEYCLK_CTRL 0xb0
+#define LPC_CLKPWR_PWMCLK_CTRL 0xb8
+#define LPC_CLKPWR_UARTCLK_CTRL 0xe4
+#define LPC_CLKPWR_POS0_IRAM_CTRL 0x110
+#define LPC_CLKPWR_POS1_IRAM_CTRL 0x114
+#define LPC_CLKPWR_SIZE 0x118
+/* Additional UART registers in CLKPWR address space. */
+#define LPC_CLKPWR_UART_U3CLK 0xd0
+#define LPC_CLKPWR_UART_U4CLK 0xd4
+#define LPC_CLKPWR_UART_U5CLK 0xd8
+#define LPC_CLKPWR_UART_U6CLK 0xdc
+#define LPC_CLKPWR_UART_UCLK_HCLK (1 << 16)
+#define LPC_CLKPWR_UART_UCLK_X(_n) (((_n) & 0xff) << 8)
+#define LPC_CLKPWR_UART_UCLK_Y(_n) ((_n) & 0xff)
+#define LPC_CLKPWR_UART_IRDACLK 0xe0
+/* Additional UART registers */
+#define LPC_UART_BASE 0x80000
+#define LPC_UART_CONTROL_BASE 0x54000
+#define LPC_UART5_BASE 0x90000
+#define LPC_UART_CTRL 0x00
+#define LPC_UART_CLKMODE 0x04
+#define LPC_UART_CLKMODE_UART3(_n) (((_n) & 0x3) << 4)
+#define LPC_UART_CLKMODE_UART4(_n) (((_n) & 0x3) << 6)
+#define LPC_UART_CLKMODE_UART5(_n) (((_n) & 0x3) << 8)
+#define LPC_UART_CLKMODE_UART6(_n) (((_n) & 0x3) << 10)
+#define LPC_UART_LOOP 0x08
+#define LPC_UART_CONTROL_SIZE 0x0c
+#define LPC_UART_FIFOSIZE 64
+ * Real time clock. (from UM10326: LPC32x0 User manual, page 566)
+#define LPC_RTC_UCOUNT 0x00
+#define LPC_RTC_DCOUNT 0x04
+#define LPC_RTC_MATCH0 0x08
+#define LPC_RTC_MATCH1 0x0c
+#define LPC_RTC_CTRL 0x10
+#define LPC_RTC_CTRL_ONSW (1 << 7)
+#define LPC_RTC_CTRL_DISABLE (1 << 6)
+#define LPC_RTC_CTRL_RTCRESET (1 << 4)
+#define LPC_RTC_CTRL_MATCH0ONSW (1 << 3)
+#define LPC_RTC_CTRL_MATCH1ONSW (1 << 2)
+#define LPC_RTC_CTRL_MATCH1INTR (1 << 1)
+#define LPC_RTC_CTRL_MATCH0INTR (1 << 0)
+#define LPC_RTC_INTSTAT 0x14
+#define LPC_RTC_KEY 0x18
+#define LPC_RTC_SRAM_BEGIN 0x80
+#define LPC_RTC_SRAM_END 0xff
+ * MMC/SD controller. (from UM10326: LPC32x0 User manual, page 436)
+#define LPC_SD_PHYS_BASE (LPC_DEV_P5_PHYS_BASE + 0x98000)
+#define LPC_SD_CLK (13 * 1000 * 1000) // 13Mhz
+#define LPC_SD_POWER 0x00
+#define LPC_SD_POWER_OPENDRAIN (1 << 6)
+#define LPC_SD_POWER_CTRL_OFF 0x00
+#define LPC_SD_POWER_CTRL_UP 0x02
+#define LPC_SD_POWER_CTRL_ON 0x03
+#define LPC_SD_CLOCK 0x04
+#define LPC_SD_CLOCK_WIDEBUS (1 << 11)
+#define LPC_SD_CLOCK_BYPASS (1 << 10)
+#define LPC_SD_CLOCK_PWRSAVE (1 << 9)
+#define LPC_SD_CLOCK_ENABLE (1 << 8)
+#define LPC_SD_CLOCK_CLKDIVMASK 0xff
+#define LPC_SD_ARGUMENT 0x08
+#define LPC_SD_COMMAND 0x0c
+#define LPC_SD_COMMAND_ENABLE (1 << 10)
+#define LPC_SD_COMMAND_PENDING (1 << 9)
+#define LPC_SD_COMMAND_INTERRUPT (1 << 8)
+#define LPC_SD_COMMAND_LONGRSP (1 << 7)
+#define LPC_SD_COMMAND_RESPONSE (1 << 6)
+#define LPC_SD_COMMAND_CMDINDEXMASK 0x3f
+#define LPC_SD_RESPCMD 0x10
+#define LPC_SD_RESP0 0x14
+#define LPC_SD_RESP1 0x18
+#define LPC_SD_RESP2 0x1c
+#define LPC_SD_RESP3 0x20
+#define LPC_SD_DATATIMER 0x24
+#define LPC_SD_DATALENGTH 0x28
+#define LPC_SD_DATACTRL 0x2c
+#define LPC_SD_DATACTRL_BLOCKSIZESHIFT 4
+#define LPC_SD_DATACTRL_BLOCKSIZEMASK 0xf
+#define LPC_SD_DATACTRL_DMAENABLE (1 << 3)
+#define LPC_SD_DATACTRL_MODE (1 << 2)
+#define LPC_SD_DATACTRL_WRITE (0 << 1)
+#define LPC_SD_DATACTRL_READ (1 << 1)
+#define LPC_SD_DATACTRL_ENABLE (1 << 0)
+#define LPC_SD_DATACNT 0x30
+#define LPC_SD_STATUS 0x34
+#define LPC_SD_STATUS_RXDATAAVLBL (1 << 21)
+#define LPC_SD_STATUS_TXDATAAVLBL (1 << 20)
+#define LPC_SD_STATUS_RXFIFOEMPTY (1 << 19)
+#define LPC_SD_STATUS_TXFIFOEMPTY (1 << 18)
+#define LPC_SD_STATUS_RXFIFOFULL (1 << 17)
+#define LPC_SD_STATUS_TXFIFOFULL (1 << 16)
+#define LPC_SD_STATUS_RXFIFOHALFFULL (1 << 15)
+#define LPC_SD_STATUS_TXFIFOHALFEMPTY (1 << 14)
+#define LPC_SD_STATUS_RXACTIVE (1 << 13)
+#define LPC_SD_STATUS_TXACTIVE (1 << 12)
+#define LPC_SD_STATUS_CMDACTIVE (1 << 11)
+#define LPC_SD_STATUS_DATABLOCKEND (1 << 10)
+#define LPC_SD_STATUS_STARTBITERR (1 << 9)
+#define LPC_SD_STATUS_DATAEND (1 << 8)
+#define LPC_SD_STATUS_CMDSENT (1 << 7)
+#define LPC_SD_STATUS_CMDRESPEND (1 << 6)
+#define LPC_SD_STATUS_RXOVERRUN (1 << 5)
+#define LPC_SD_STATUS_TXUNDERRUN (1 << 4)
+#define LPC_SD_STATUS_DATATIMEOUT (1 << 3)
+#define LPC_SD_STATUS_CMDTIMEOUT (1 << 2)
+#define LPC_SD_STATUS_DATACRCFAIL (1 << 1)
+#define LPC_SD_STATUS_CMDCRCFAIL (1 << 0)
+#define LPC_SD_CLEAR 0x38
+#define LPC_SD_MASK0 0x03c
+#define LPC_SD_MASK1 0x40
+#define LPC_SD_FIFOCNT 0x48
+#define LPC_SD_FIFO 0x80
+ * USB OTG controller (from UM10326: LPC32x0 User manual, page 410)
+#define LPC_OTG_INT_STATUS 0x100
+#define LPC_OTG_INT_ENABLE 0x104
+#define LPC_OTG_INT_SET 0x108
+#define LPC_OTG_INT_CLEAR 0x10c
+#define LPC_OTG_STATUS 0x110
+#define LPC_OTG_STATUS_ATOB_HNP_TRACK (1 << 9)
+#define LPC_OTG_STATUS_BTOA_HNP_TACK (1 << 8)
+#define LPC_OTG_STATUS_TRANSP_I2C_EN (1 << 7)
+#define LPC_OTG_STATUS_TIMER_RESET (1 << 6)
+#define LPC_OTG_STATUS_TIMER_EN (1 << 5)
+#define LPC_OTG_STATUS_TIMER_MODE (1 << 4)
+#define LPC_OTG_STATUS_TIMER_SCALE (1 << 2)
+#define LPC_OTG_STATUS_HOST_EN (1 << 0)
+#define LPC_OTG_TIMER 0x114
+#define LPC_OTG_I2C_TXRX 0x300
+#define LPC_OTG_I2C_STATUS 0x304
+#define LPC_OTG_I2C_STATUS_TFE (1 << 11)
+#define LPC_OTG_I2C_STATUS_TFF (1 << 10)
+#define LPC_OTG_I2C_STATUS_RFE (1 << 9)
+#define LPC_OTG_I2C_STATUS_RFF (1 << 8)
+#define LPC_OTG_I2C_STATUS_SDA (1 << 7)
+#define LPC_OTG_I2C_STATUS_SCL (1 << 6)
+#define LPC_OTG_I2C_STATUS_ACTIVE (1 << 5)
+#define LPC_OTG_I2C_STATUS_DRSI (1 << 4)
+#define LPC_OTG_I2C_STATUS_DRMI (1 << 3)
+#define LPC_OTG_I2C_STATUS_NAI (1 << 2)
+#define LPC_OTG_I2C_STATUS_AFI (1 << 1)
+#define LPC_OTG_I2C_STATUS_TDI (1 << 0)
+#define LPC_OTG_I2C_CTRL 0x308
+#define LPC_OTG_I2C_CTRL_SRST (1 << 8)
+#define LPC_OTG_I2C_CTRL_TFFIE (1 << 7)
+#define LPC_OTG_I2C_CTRL_RFDAIE (1 << 6)
+#define LPC_OTG_I2C_CTRL_RFFIE (1 << 5)
+#define LPC_OTG_I2C_CTRL_DRSIE (1 << 4)
+#define LPC_OTG_I2C_CTRL_DRMIE (1 << 3)
+#define LPC_OTG_I2C_CTRL_NAIE (1 << 2)
+#define LPC_OTG_I2C_CTRL_AFIE (1 << 1)
+#define LPC_OTG_I2C_CTRL_TDIE (1 << 0)
+#define LPC_OTG_I2C_CLKHI 0x30c
+#define LPC_OTG_I2C_CLKLO 0x310
+#define LPC_OTG_CLOCK_CTRL 0xff4
+#define LPC_OTG_CLOCK_CTRL_AHB_EN (1 << 4)
+#define LPC_OTG_CLOCK_CTRL_OTG_EN (1 << 3)
+#define LPC_OTG_CLOCK_CTRL_I2C_EN (1 << 2)
+#define LPC_OTG_CLOCK_CTRL_DEV_EN (1 << 1)
+#define LPC_OTG_CLOCK_CTRL_HOST_EN (1 << 0)
+#define LPC_OTG_CLOCK_STATUS 0xff8
+ * ISP3101 USB transceiver registers
+#define LPC_ISP3101_I2C_ADDR 0x2d
+#define LPC_ISP3101_MODE_CONTROL_1 0x04
+#define LPC_ISP3101_MC1_SPEED_REG (1 << 0)
+#define LPC_ISP3101_MC1_SUSPEND_REG (1 << 1)
+#define LPC_ISP3101_MC1_DAT_SE0 (1 << 2)
+#define LPC_ISP3101_MC1_TRANSPARENT (1 << 3)
+#define LPC_ISP3101_MC1_BDIS_ACON_EN (1 << 4)
+#define LPC_ISP3101_MC1_OE_INT_EN (1 << 5)
+#define LPC_ISP3101_MC1_UART_EN (1 << 6)
+#define LPC_ISP3101_MODE_CONTROL_2 0x12
+#define LPC_ISP3101_MC2_GLOBAL_PWR_DN (1 << 0)
+#define LPC_ISP3101_MC2_SPD_SUSP_CTRL (1 << 1)
+#define LPC_ISP3101_MC2_BI_DI (1 << 2)
+#define LPC_ISP3101_MC2_TRANSP_BDIR0 (1 << 3)
+#define LPC_ISP3101_MC2_TRANSP_BDIR1 (1 << 4)
+#define LPC_ISP3101_MC2_AUDIO_EN (1 << 5)
+#define LPC_ISP3101_MC2_PSW_EN (1 << 6)
+#define LPC_ISP3101_MC2_EN2V7 (1 << 7)
+#define LPC_ISP3101_OTG_CONTROL_1 0x06
+#define LPC_ISP3101_OTG1_DP_PULLUP (1 << 0)
+#define LPC_ISP3101_OTG1_DM_PULLUP (1 << 1)
+#define LPC_ISP3101_OTG1_DP_PULLDOWN (1 << 2)
+#define LPC_ISP3101_OTG1_DM_PULLDOWN (1 << 3)
+#define LPC_ISP3101_OTG1_ID_PULLDOWN (1 << 4)
+#define LPC_ISP3101_OTG1_VBUS_DRV (1 << 5)
+#define LPC_ISP3101_OTG1_VBUS_DISCHRG (1 << 6)
+#define LPC_ISP3101_OTG1_VBUS_CHRG (1 << 7)
+#define LPC_ISP3101_OTG_CONTROL_2 0x10
+#define LPC_ISP3101_OTG_INTR_LATCH 0x0a
+#define LPC_ISP3101_OTG_INTR_FALLING 0x0c
+#define LPC_ISP3101_OTG_INTR_RISING 0x0e
+#define LPC_ISP3101_REG_CLEAR_ADDR 0x01
+ * LCD Controller (from UM10326: LPC32x0 User manual, page 229)
+#define LPC_LCD_TIMH 0x00
+#define LPC_LCD_TIMH_HBP(_n) (((_n) & 0xff) << 24)
+#define LPC_LCD_TIMH_HFP(_n) (((_n) & 0xff) << 16)
+#define LPC_LCD_TIMH_HSW(_n) (((_n) & 0xff) << 8)
+#define LPC_LCD_TIMH_PPL(_n) (((_n) / 16 - 1) << 2)
+#define LPC_LCD_TIMV 0x04
+#define LPC_LCD_TIMV_VBP(_n) (((_n) & 0xff) << 24)
+#define LPC_LCD_TIMV_VFP(_n) (((_n) & 0xff) << 16)
+#define LPC_LCD_TIMV_VSW(_n) (((_n) & 0x3f) << 10)
+#define LPC_LCD_TIMV_LPP(_n) ((_n) & 0x1ff)
+#define LPC_LCD_POL 0x08
+#define LPC_LCD_POL_PCD_HI (((_n) & 0x1f) << 27)
+#define LPC_LCD_POL_BCD (1 << 26)
+#define LPC_LCD_POL_CPL(_n) (((_n) & 0x3ff) << 16)
+#define LPC_LCD_POL_IOE (1 << 14)
+#define LPC_LCD_POL_IPC (1 << 13)
+#define LPC_LCD_POL_IHS (1 << 12)
+#define LPC_LCD_POL_IVS (1 << 11)
+#define LPC_LCD_POL_ACB(_n) ((_n & 0x1f) << 6)
+#define LPC_LCD_POL_CLKSEL (1 << 5)
+#define LPC_LCD_POL_PCD_LO(_n) ((_n) & 0x1f)
+#define LPC_LCD_LE 0x0c
+#define LPC_LCD_LE_LEE (1 << 16)
+#define LPC_LCD_LE_LED ((_n) & 0x7f)
+#define LPC_LCD_UPBASE 0x10
+#define LPC_LCD_LPBASE 0x14
+#define LPC_LCD_CTRL 0x18
+#define LPC_LCD_CTRL_WATERMARK (1 << 16)
+#define LPC_LCD_CTRL_LCDVCOMP(_n) (((_n) & 0x3) << 12)
+#define LPC_LCD_CTRL_LCDPWR (1 << 11)
+#define LPC_LCD_CTRL_BEPO (1 << 10)
+#define LPC_LCD_CTRL_BEBO (1 << 9)
+#define LPC_LCD_CTRL_BGR (1 << 8)
+#define LPC_LCD_CTRL_LCDDUAL (1 << 7)
+#define LPC_LCD_CTRL_LCDMONO8 (1 << 6)
+#define LPC_LCD_CTRL_LCDTFT (1 << 5)
+#define LPC_LCD_CTRL_LCDBW (1 << 4)
+#define LPC_LCD_CTRL_LCDBPP(_n) (((_n) & 0x7) << 1)
+#define LPC_LCD_CTRL_BPP1 0
+#define LPC_LCD_CTRL_BPP2 1
+#define LPC_LCD_CTRL_BPP4 2
+#define LPC_LCD_CTRL_BPP8 3
+#define LPC_LCD_CTRL_BPP16 4
+#define LPC_LCD_CTRL_BPP24 5
+#define LPC_LCD_CTRL_BPP16_565 6
+#define LPC_LCD_CTRL_BPP12_444 7
+#define LPC_LCD_CTRL_LCDEN (1 << 0)
+#define LPC_LCD_INTMSK 0x1c
+#define LPC_LCD_INTRAW 0x20
+#define LPC_LCD_INTSTAT 0x24
+#define LPC_LCD_INTCLR 0x28
+#define LPC_LCD_UPCURR 0x2c
+#define LPC_LCD_LPCURR 0x30
+#define LPC_LCD_PAL 0x200
+#define LPC_LCD_CRSR_IMG 0x800
+#define LPC_LCD_CRSR_CTRL 0xc00
+#define LPC_LCD_CRSR_CFG 0xc04
+#define LPC_LCD_CRSR_PAL0 0xc08
+#define LPC_LCD_CRSR_PAL1 0xc0c
+#define LPC_LCD_CRSR_XY 0xc10
+#define LPC_LCD_CRSR_CLIP 0xc14
+#define LPC_LCD_CRSR_INTMSK 0xc20
+#define LPC_LCD_CRSR_INTCLR 0xc24
+#define LPC_LCD_CRSR_INTRAW 0xc28
+#define LPC_LCD_CRSR_INTSTAT 0xc2c
+ * SPI interface (from UM10326: LPC32x0 User manual, page 483)
+#define LPC_SPI_GLOBAL 0x00
+#define LPC_SPI_GLOBAL_RST (1 << 1)
+#define LPC_SPI_GLOBAL_ENABLE (1 << 0)
+#define LPC_SPI_CON 0x04
+#define LPC_SPI_CON_UNIDIR (1 << 23)
+#define LPC_SPI_CON_BHALT (1 << 22)
+#define LPC_SPI_CON_BPOL (1 << 21)
+#define LPC_SPI_CON_MSB (1 << 19)
+#define LPC_SPI_CON_MODE(_n) ((_n & 0x3) << 16)
+#define LPC_SPI_CON_RXTX (1 << 15)
+#define LPC_SPI_CON_THR (1 << 14)
+#define LPC_SPI_CON_SHIFT_OFF (1 << 13)
+#define LPC_SPI_CON_BITNUM(_n) ((_n & 0xf) << 9)
+#define LPC_SPI_CON_MS (1 << 7)
+#define LPC_SPI_CON_RATE(_n) (_n & 0x7f)
+#define LPC_SPI_FRM 0x08
+#define LPC_SPI_IER 0x0c
+#define LPC_SPI_IER_INTEOT (1 << 1)
+#define LPC_SPI_IER_INTTHR (1 << 0)
+#define LPC_SPI_STAT 0x10
+#define LPC_SPI_STAT_INTCLR (1 << 8)
+#define LPC_SPI_STAT_EOT (1 << 7)
+#define LPC_SPI_STAT_BUSYLEV (1 << 6)
+#define LPC_SPI_STAT_SHIFTACT (1 << 3)
+#define LPC_SPI_STAT_BF (1 << 2)
+#define LPC_SPI_STAT_THR (1 << 1)
+#define LPC_SPI_STAT_BE (1 << 0)
+#define LPC_SPI_DAT 0x14
+#define LPC_SPI_TIM_CTRL 0x400
+#define LPC_SPI_TIM_COUNT 0x404
+#define LPC_SPI_TIM_STAT 0x408
+ * SSP interface (from UM10326: LPC32x0 User manual, page 500)
+#define LPC_SSP0_BASE 0x4c00
+#define LPC_SSP1_BASE 0xc000
+#define LPC_SSP_CR0 0x00
+#define LPC_SSP_CR0_DSS(_n) ((_n-1) & 0xf)
+#define LPC_SSP_CR0_TI (1 << 4)
+#define LPC_SSP_CR0_MICROWIRE (1 << 5)
+#define LPC_SSP_CR0_CPOL (1 << 6)
+#define LPC_SSP_CR0_CPHA (1 << 7)
+#define LPC_SSP_CR0_SCR(_n) ((_x & & 0xff) << 8)
+#define LPC_SSP_CR1 0x04
+#define LPC_SSP_CR1_LBM (1 << 0)
+#define LPC_SSP_CR1_SSE (1 << 1)
+#define LPC_SSP_CR1_MS (1 << 2)
+#define LPC_SSP_CR1_SOD (1 << 3)
+#define LPC_SSP_DR 0x08
+#define LPC_SSP_SR 0x0c
+#define LPC_SSP_SR_TFE (1 << 0)
+#define LPC_SSP_SR_TNF (1 << 1)
+#define LPC_SSP_SR_RNE (1 << 2)
+#define LPC_SSP_SR_RFF (1 << 3)
+#define LPC_SSP_SR_BSY (1 << 4)
+#define LPC_SSP_CPSR 0x10
+#define LPC_SSP_IMSC 0x14
+#define LPC_SSP_IMSC_RORIM (1 << 0)
+#define LPC_SSP_IMSC_RTIM (1 << 1)
+#define LPC_SSP_IMSC_RXIM (1 << 2)
+#define LPC_SSP_IMSC_TXIM (1 << 3)
+#define LPC_SSP_RIS 0x18
+#define LPC_SSP_RIS_RORRIS (1 << 0)
+#define LPC_SSP_RIS_RTRIS (1 << 1)
+#define LPC_SSP_RIS_RXRIS (1 << 2)
+#define LPC_SSP_RIS_TXRIS (1 << 3)
+#define LPC_SSP_MIS 0x1c
+#define LPC_SSP_ICR 0x20
+#define LPC_SSP_DMACR 0x24
+ * GPIO (from UM10326: LPC32x0 User manual, page 606)
+#define LPC_GPIO_PHYS_BASE (LPC_DEV_PHYS_BASE + 0x28000)
+#define LPC_GPIO_P0_COUNT 8
+#define LPC_GPIO_P1_COUNT 24
+#define LPC_GPIO_P2_COUNT 13
+#define LPC_GPIO_P3_COUNT 52
+#define LPC_GPIO_P0_INP_STATE 0x40
+#define LPC_GPIO_P0_OUTP_SET 0x44
+#define LPC_GPIO_P0_OUTP_CLR 0x48
+#define LPC_GPIO_P0_OUTP_STATE 0x4c
+#define LPC_GPIO_P0_DIR_SET 0x50
+#define LPC_GPIO_P0_DIR_CLR 0x54
+#define LPC_GPIO_P0_DIR_STATE 0x58
+#define LPC_GPIO_P1_INP_STATE 0x60
+#define LPC_GPIO_P1_OUTP_SET 0x64
+#define LPC_GPIO_P1_OUTP_CLR 0x68
+#define LPC_GPIO_P1_OUTP_STATE 0x6c
+#define LPC_GPIO_P1_DIR_SET 0x70
+#define LPC_GPIO_P1_DIR_CLR 0x74
+#define LPC_GPIO_P1_DIR_STATE 0x78
+#define LPC_GPIO_P2_INP_STATE 0x1c
+#define LPC_GPIO_P2_OUTP_SET 0x20
+#define LPC_GPIO_P2_OUTP_CLR 0x24
+#define LPC_GPIO_P2_DIR_SET 0x10
+#define LPC_GPIO_P2_DIR_CLR 0x14
+#define LPC_GPIO_P2_DIR_STATE 0x14
+#define LPC_GPIO_P3_INP_STATE 0x00
+#define LPC_GPIO_P3_OUTP_SET 0x04
+#define LPC_GPIO_P3_OUTP_CLR 0x08
+#define LPC_GPIO_P3_OUTP_STATE 0x0c
+#define LPC_GPIO_SIZE 0x80
+/* Aliases for logical pin numbers: */
+#define LPC_GPIO_GPI_00(_n) (0 + _n)
+#define LPC_GPIO_GPI_15(_n) (10 + _n)
+#define LPC_GPIO_GPI_25 (19)
+#define LPC_GPIO_GPI_27(_n) (20 + _n)
+#define LPC_GPIO_GPO_00(_n) (22 + _n)
+#define LPC_GPIO_GPIO_00(_n) (46 + _n)
+/* SPI devices chip selects: */
+#define SSD1289_CS_PIN LPC_GPIO_GPO_00(4)
+#define SSD1289_DC_PIN LPC_GPIO_GPO_00(5)
+#define ADS7846_CS_PIN LPC_GPIO_GPO_00(11)
+#define ADS7846_INTR_PIN LPC_GPIO_GPIO_00(0)
+ * GPDMA controller (from UM10326: LPC32x0 User manual, page 106)
+#define LPC_DMAC_INTSTAT 0x00
+#define LPC_DMAC_INTTCSTAT 0x04
+#define LPC_DMAC_INTTCCLEAR 0x08
+#define LPC_DMAC_INTERRSTAT 0x0c
+#define LPC_DMAC_INTERRCLEAR 0x10
+#define LPC_DMAC_RAWINTTCSTAT 0x14
+#define LPC_DMAC_RAWINTERRSTAT 0x18
+#define LPC_DMAC_ENABLED_CHANNELS 0x1c
+#define LPC_DMAC_SOFTBREQ 0x20
+#define LPC_DMAC_SOFTSREQ 0x24
+#define LPC_DMAC_SOFTLBREQ 0x28
+#define LPC_DMAC_SOFTLSREQ 0x2c
+#define LPC_DMAC_CONFIG 0x30
+#define LPC_DMAC_CONFIG_M1 (1 << 2)
+#define LPC_DMAC_CONFIG_M0 (1 << 1)
+#define LPC_DMAC_CONFIG_ENABLE (1 << 0)
+#define LPC_DMAC_CHADDR(_n) (0x100 + (_n * 0x20))
+#define LPC_DMAC_CHNUM 8
+#define LPC_DMAC_CHSIZE 0x20
+#define LPC_DMAC_CH_SRCADDR 0x00
+#define LPC_DMAC_CH_DSTADDR 0x04
+#define LPC_DMAC_CH_LLI 0x08
+#define LPC_DMAC_CH_LLI_AHB1 (1 << 0)
+#define LPC_DMAC_CH_CONTROL 0x0c
+#define LPC_DMAC_CH_CONTROL_I (1U << 31)
+#define LPC_DMAC_CH_CONTROL_DI (1 << 27)
+#define LPC_DMAC_CH_CONTROL_SI (1 << 26)
+#define LPC_DMAC_CH_CONTROL_D (1 << 25)
+#define LPC_DMAC_CH_CONTROL_S (1 << 24)
+#define LPC_DMAC_CH_CONTROL_WIDTH_4 2
+#define LPC_DMAC_CH_CONTROL_DWIDTH(_n) ((_n & 0x7) << 21)
+#define LPC_DMAC_CH_CONTROL_SWIDTH(_n) ((_n & 0x7) << 18)
+#define LPC_DMAC_CH_CONTROL_BURST_8 2
+#define LPC_DMAC_CH_CONTROL_DBSIZE(_n) ((_n & 0x7) << 15)
+#define LPC_DMAC_CH_CONTROL_SBSIZE(_n) ((_n & 0x7) << 12)
+#define LPC_DMAC_CH_CONTROL_XFERLEN(_n) (_n & 0xfff)
+#define LPC_DMAC_CH_CONFIG 0x10
+#define LPC_DMAC_CH_CONFIG_H (1 << 18)
+#define LPC_DMAC_CH_CONFIG_A (1 << 17)
+#define LPC_DMAC_CH_CONFIG_L (1 << 16)
+#define LPC_DMAC_CH_CONFIG_ITC (1 << 15)
+#define LPC_DMAC_CH_CONFIG_IE (1 << 14)
+#define LPC_DMAC_CH_CONFIG_FLOWCNTL(_n) ((_n & 0x7) << 11)
+#define LPC_DMAC_CH_CONFIG_DESTP(_n) ((_n & 0x1f) << 6)
+#define LPC_DMAC_CH_CONFIG_SRCP(_n) ((_n & 0x1f) << 1)
+#define LPC_DMAC_CH_CONFIG_E (1 << 0)
+/* DMA flow control values */
+#define LPC_DMAC_FLOW_D_M2M 0
+#define LPC_DMAC_FLOW_D_M2P 1
+#define LPC_DMAC_FLOW_D_P2M 2
+#define LPC_DMAC_FLOW_D_P2P 3
+#define LPC_DMAC_FLOW_DP_P2P 4
+#define LPC_DMAC_FLOW_P_M2P 5
+#define LPC_DMAC_FLOW_P_P2M 6
+#define LPC_DMAC_FLOW_SP_P2P 7
+/* DMA peripheral ID's */
+#define LPC_DMAC_I2S0_DMA0_ID 0
+#define LPC_DMAC_NAND_ID 1
+#define LPC_DMAC_IS21_DMA0_ID 2
+#define LPC_DMAC_SSP1_ID 3
+#define LPC_DMAC_SPI2_ID 3
+#define LPC_DMAC_SD_ID 4
+#define LPC_DMAC_UART1_TX_ID 5
+#define LPC_DMAC_UART1_RX_ID 6
+#define LPC_DMAC_UART2_TX_ID 7
+#define LPC_DMAC_UART2_RX_ID 8
+#define LPC_DMAC_UART7_TX_ID 9
+#define LPC_DMAC_UART7_RX_ID 10
+#define LPC_DMAC_I2S1_DMA1_ID 10
+#define LPC_DMAC_SPI1_ID 11
+#define LPC_DMAC_SSP1_TX_ID 11
+#define LPC_DMAC_NAND2_ID 12
+#define LPC_DMAC_I2S0_DMA1_ID 13
+#define LPC_DMAC_SSP0_RX 14
+#define LPC_DMAC_SSP0_TX 15
+#endif /* _ARM_LPC_LPCREG_H */
diff --git a/freebsd/sys/arm/lpc/lpcvar.h b/freebsd/sys/arm/lpc/lpcvar.h
index 0000000..ed05320
--- /dev/null
+++ b/freebsd/sys/arm/lpc/lpcvar.h
@@ -0,0 +1,69 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _ARM_LPC_LPCVAR_H
+#define _ARM_LPC_LPCVAR_H
+#include <sys/types.h>
+/* Clocking and power control */
+uint32_t lpc_pwr_read(device_t, int);
+void lpc_pwr_write(device_t, int, uint32_t);
+/* GPIO */
+void lpc_gpio_init(void);
+int lpc_gpio_set_flags(device_t, int, int);
+int lpc_gpio_set_state(device_t, int, int);
+int lpc_gpio_get_state(device_t, int, int *);
+/* DMA */
+struct lpc_dmac_channel_config
+ int ldc_fcntl;
+ int ldc_src_periph;
+ int ldc_src_width;
+ int ldc_src_incr;
+ int ldc_src_burst;
+ int ldc_dst_periph;
+ int ldc_dst_width;
+ int ldc_dst_incr;
+ int ldc_dst_burst;
+ void (*ldc_success_handler)(void *);
+ void (*ldc_error_handler)(void *);
+ void * ldc_handler_arg;
+int lpc_dmac_config_channel(device_t, int, struct lpc_dmac_channel_config *);
+int lpc_dmac_setup_transfer(device_t, int, bus_addr_t, bus_addr_t, bus_size_t, int);
+int lpc_dmac_enable_channel(device_t, int);
+int lpc_dmac_disable_channel(device_t, int);
+int lpc_dmac_start_burst(device_t, int);
+#endif /* _ARM_LPC_LPCVAR_H */
1.9.1
