[PATCH 02/10] Adding LPC32XX USB OHCI support
Kevin Kirspel kevin-kirspel at idexx.com
Mon Jan 30 16:58:16 UTC 2017
 rtemsbsd/sys/dev/usb/controller/ohci_lpc32xx.c | 499 +++++++++++++++++++++++++
 1 file changed, 499 insertions(+)
 create mode 100755 rtemsbsd/sys/dev/usb/controller/ohci_lpc32xx.c
diff --git a/rtemsbsd/sys/dev/usb/controller/ohci_lpc32xx.c b/rtemsbsd/sys/dev/usb/controller/ohci_lpc32xx.c
new file mode 100755
index 0000000..dca99c2
--- /dev/null
+++ b/rtemsbsd/sys/dev/usb/controller/ohci_lpc32xx.c
@@ -0,0 +1,499 @@
+ * Copyright (c) 2011 Jakub Wojciech Klama <jceel at FreeBSD.org>
+ * All rights reserved.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <machine/rtems-bsd-kernel-space.h>
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+#include <sys/stdint.h>
+#include <sys/stddef.h>
+#include <rtems/bsd/sys/param.h>
+#include <sys/queue.h>
+#include <sys/types.h>
+#include <sys/systm.h>
+#include <sys/kernel.h>
+#include <sys/bus.h>
+#include <sys/module.h>
+#include <rtems/bsd/sys/lock.h>
+#include <sys/mutex.h>
+#include <sys/condvar.h>
+#include <sys/sysctl.h>
+#include <sys/rman.h>
+#include <sys/sx.h>
+#include <rtems/bsd/sys/unistd.h>
+#include <sys/callout.h>
+#include <sys/malloc.h>
+#include <sys/priv.h>
+#include <sys/kdb.h>
+#include <bsp.h>
+#if defined(LIBBSP_ARM_LPC32XX_BSP_H)
+#ifdef BSP_USB_OTG_TRANSCEIVER_I2C_ADDR
+#include <dev/usb/usb_otg_transceiver.h>
+#endif /* BSP_USB_OTG_TRANSCEIVER_I2C_ADDR */
+#include <dev/usb/usb.h>
+#include <dev/usb/usbdi.h>
+#include <dev/usb/usb_core.h>
+#include <dev/usb/usb_busdma.h>
+#include <dev/usb/usb_process.h>
+#include <dev/usb/usb_util.h>
+#include <dev/usb/usb_controller.h>
+#include <dev/usb/usb_bus.h>
+#include <dev/usb/controller/ohci.h>
+#include <dev/usb/controller/ohcireg.h>
+#include <arm/lpc/lpcreg.h>
+#include <arm/lpc/lpcvar.h>
+#define	I2C_START_BIT		(1 << 8)
+#define	I2C_STOP_BIT		(1 << 9)
+#define	I2C_READ		0x01
+#define	I2C_WRITE		0x00
+#define	DUMMY_BYTE		0x55
+#define	lpc_otg_read_4(_sc, _reg)					\
+    bus_space_read_4(_sc->sc_io_tag, _sc->sc_io_hdl, _reg)
+#define	lpc_otg_write_4(_sc, _reg, _value)				\
+    bus_space_write_4(_sc->sc_io_tag, _sc->sc_io_hdl, _reg, _value)
+#define	lpc_otg_wait_write_4(_sc, _wreg, _sreg, _value)			\
+    do {								\
+    	lpc_otg_write_4(_sc, _wreg, _value);				\
+    	while ((lpc_otg_read_4(_sc, _sreg) & _value) != _value);    	\
+    } while (0);
+static int lpc_ohci_probe(device_t dev);
+static int lpc_ohci_attach(device_t dev);
+static int lpc_ohci_detach(device_t dev);
+static void lpc_usb_module_enable(device_t dev, struct ohci_softc *);
+static void lpc_usb_module_disable(device_t dev, struct ohci_softc *);
+static void lpc_usb_pin_config(device_t dev, struct ohci_softc *);
+static void lpc_usb_host_clock_enable(device_t dev, struct ohci_softc *);
+static void lpc_otg_status_and_control(device_t dev, struct ohci_softc *);
+static rtems_interval lpc_usb_timeout_init(void);
+static bool lpc_usb_timeout_not_expired(rtems_interval start);
+static int lpc_otg_clk_ctrl(device_t dev, struct ohci_softc *sc, uint32_t otg_clk_ctrl);
+static int lpc_otg_i2c_wait_for_receive_fifo_not_empty(struct ohci_softc *sc);
+static int lpc_otg_i2c_wait_for_transaction_done(struct ohci_softc *sc);
+static int lpc_otg_i2c_read(const struct usb_otg_transceiver *self, uint8_t reg_addr, uint8_t *value);
+static int lpc_otg_i2c_write(const struct usb_otg_transceiver *self, uint8_t reg_addr, uint8_t value);
+static int
+lpc_ohci_probe(device_t dev)
+	device_set_desc(dev, "LPC32x0 USB OHCI controller");
+	return (BUS_PROBE_DEFAULT);
+static int
+lpc_ohci_attach(device_t dev)
+	struct ohci_softc *sc = device_get_softc(dev);
+	int err;
+  int eno;
+	int rid;
+	int i = 0;
+	uint32_t usbctrl;
+	uint32_t otgstatus;
+	sc->sc_bus.parent = dev;
+	sc->sc_bus.devices = sc->sc_devices;
+	sc->sc_bus.devices_max = OHCI_MAX_DEVICES;
+	sc->sc_bus.dma_bits = 32;
+	if (usb_bus_mem_alloc_all(&sc->sc_bus, USB_GET_DMA_TAG(dev),
+	    &ohci_iterate_hw_softc))
+		return (ENOMEM);
+	rid = 0;
+	sc->sc_io_res = bus_alloc_resource_any(dev, SYS_RES_MEMORY, &rid, RF_ACTIVE);
+	if (!sc->sc_io_res) {
+		device_printf(dev, "cannot map OHCI register space\n");
+		goto fail;
+	sc->sc_io_tag = rman_get_bustag(sc->sc_io_res);
+	sc->sc_io_hdl = rman_get_bushandle(sc->sc_io_res);
+	sc->sc_io_size = rman_get_size(sc->sc_io_res);
+	rid = 0;
+	sc->sc_irq_res = bus_alloc_resource_any(dev, SYS_RES_IRQ, &rid, RF_ACTIVE);
+	if (sc->sc_irq_res == NULL) {
+		device_printf(dev, "cannot allocate interrupt\n");
+		goto fail;
+	sc->sc_bus.bdev = device_add_child(dev, "usbus", -1);
+	if (!(sc->sc_bus.bdev))
+		goto fail;
+	device_set_ivars(sc->sc_bus.bdev, &sc->sc_bus);
+	strlcpy(sc->sc_vendor, "NXP", sizeof(sc->sc_vendor));
+	err = bus_setup_intr(dev, sc->sc_irq_res, INTR_TYPE_BIO | INTR_MPSAFE,
+	    NULL, (void *)ohci_interrupt, sc, &sc->sc_intr_hdl);
+	if (err) {
+		sc->sc_intr_hdl = NULL;
+		goto fail;
+  lpc_usb_module_enable(dev, sc);
+  eno = lpc_otg_clk_ctrl(dev, sc, LPC_OTG_CLOCK_CTRL_AHB_EN | LPC_OTG_CLOCK_CTRL_I2C_EN);
+  if (eno != 0) {
+    goto fail;
+  lpc_usb_pin_config(dev, sc);
+  sc->sc_otg_trans.read = lpc_otg_i2c_read;
+  sc->sc_otg_trans.write = lpc_otg_i2c_write;
+  sc->sc_otg_trans.i2c_addr = BSP_USB_OTG_TRANSCEIVER_I2C_ADDR;
+  sc->sc_otg_trans.softc = sc;
+  eno = usb_otg_transceiver_init(&sc->sc_otg_trans);
+  if (eno != 0) {
+    goto fail;
+#ifdef BSP_USB_OTG_TRANSCEIVER_DUMP
+  usb_otg_transceiver_dump(&sc->sc_otg_trans);
+#endif /* BSP_USB_OTG_TRANSCEIVER_DUMP */
+  eno = usb_otg_transceiver_resume(&sc->sc_otg_trans);
+  if (eno != 0) {
+    goto fail;
+  lpc_usb_host_clock_enable(dev, sc);
+  eno = lpc_otg_clk_ctrl( dev, sc,
+    LPC_OTG_CLOCK_CTRL_AHB_EN | LPC_OTG_CLOCK_CTRL_HOST_EN
+      | LPC_OTG_CLOCK_CTRL_I2C_EN | LPC_OTG_CLOCK_CTRL_OTG_EN
+  if (eno != 0) {
+    goto fail;
+  lpc_otg_status_and_control(dev, sc);
+#if defined(BSP_USB_OTG_TRANSCEIVER_I2C_ADDR) \
+  && defined(BSP_USB_OTG_TRANSCEIVER_VBUS)
+  eno = usb_otg_transceiver_set_vbus(
+    &sc->sc_otg_trans,
+    BSP_USB_OTG_TRANSCEIVER_VBUS
+  if (eno != 0) {
+    goto fail;
+#endif /* defined(BSP_USB_OTG_TRANSCEIVER_I2C_ADDR)
+    && defined(BSP_USB_OTG_TRANSCEIVER_VBUS) */
+  && defined(BSP_USB_OTG_TRANSCEIVER_DUMP)
+    && defined(BSP_USB_OTG_TRANSCEIVER_DUMP) */
+  eno = lpc_otg_clk_ctrl(dev, sc, LPC_OTG_CLOCK_CTRL_AHB_EN | LPC_OTG_CLOCK_CTRL_HOST_EN);
+  if (eno != 0) {
+    goto fail;
+	err = ohci_init(sc);
+	if (err)
+		goto fail;
+	err = device_probe_and_attach(sc->sc_bus.bdev);
+	if (err)
+		goto fail;
+	return (0);
+fail:
+	if (sc->sc_intr_hdl)
+		bus_teardown_intr(dev, sc->sc_irq_res, sc->sc_intr_hdl);
+	if (sc->sc_irq_res)
+		bus_release_resource(dev, SYS_RES_IRQ, 0, sc->sc_irq_res);
+	if (sc->sc_io_res)
+		bus_release_resource(dev, SYS_RES_MEMORY, 0, sc->sc_io_res);
+	return (ENXIO);
+static int
+lpc_ohci_detach(device_t dev)
+	return (0);
+static void lpc_usb_module_enable(device_t dev, struct ohci_softc *sc)
+  uint32_t usbctrl;
+  lpc_pwr_write(dev, LPC_CLKPWR_USBDIV_CTRL, 0xc);
+  lpc_pwr_write(dev, LPC_CLKPWR_USB_CTRL,
+      LPC_CLKPWR_USB_CTRL_SLAVE_HCLK |
+      LPC_CLKPWR_USB_CTRL_BUSKEEPER |
+      LPC_CLKPWR_USB_CTRL_CLK_EN1 |
+      LPC_CLKPWR_USB_CTRL_PLL_PDOWN |
+      LPC_CLKPWR_USB_CTRL_POSTDIV(1) |
+      LPC_CLKPWR_USB_CTRL_PREDIV(0) |
+      LPC_CLKPWR_USB_CTRL_FDBKDIV(192));
+  do {
+    usbctrl = lpc_pwr_read(dev, LPC_CLKPWR_USB_CTRL);
+  } while ((usbctrl & LPC_CLKPWR_USB_CTRL_PLL_LOCK) == 0);
+  usbctrl |= LPC_CLKPWR_USB_CTRL_CLK_EN2;
+  lpc_pwr_write(dev, LPC_CLKPWR_USB_CTRL, usbctrl);
+static void lpc_usb_module_disable(device_t dev, struct ohci_softc *sc)
+  lpc_otg_write_4(sc, LPC_OTG_CLOCK_CTRL, 0x0);
+  lpc_pwr_write(dev, LPC_CLKPWR_USB_CTRL, LPC_CLKPWR_USB_CTRL_BUSKEEPER);
+static void lpc_usb_pin_config(device_t dev, struct ohci_softc *sc)
+static void lpc_usb_host_clock_enable(device_t dev, struct ohci_softc *sc)
+  uint32_t usbctrl;
+  usbctrl |= LPC_CLKPWR_USB_CTRL_HOST_NEED_CLK_EN;
+static void lpc_otg_status_and_control(device_t dev, struct ohci_softc *sc)
+  lpc_otg_write_4(sc, LPC_OTG_STATUS, 0x1);
+  return rtems_clock_get_ticks_since_boot();
+  rtems_interval elapsed = rtems_clock_get_ticks_since_boot() - start;
+  return elapsed < (rtems_clock_get_ticks_per_second() / 10);
+  rtems_interval start;
+  bool not_ok;
+  lpc_otg_write_4(sc, LPC_OTG_CLOCK_CTRL, otg_clk_ctrl);
+  start = lpc_usb_timeout_init();
+  while (
+    (not_ok = (lpc_otg_read_4(sc, LPC_OTG_CLOCK_STATUS) & otg_clk_ctrl) != otg_clk_ctrl)
+      && lpc_usb_timeout_not_expired(start)
+    /* Wait */
+  return not_ok ? EIO : 0;
+  bool not_ok;
+  while (
+    (not_ok = (lpc_otg_read_4(sc, LPC_OTG_I2C_STATUS) & LPC_OTG_I2C_STATUS_RFE) != 0)
+    /* Wait */
+  bool not_ok;
+  while (
+    (not_ok = (lpc_otg_read_4(sc, LPC_OTG_I2C_STATUS) & LPC_OTG_I2C_STATUS_TDI) == 0)
+    /* Wait */
+  struct ohci_softc *sc = (struct ohci_softc *)self->softc;
+  int eno;
+  lpc_otg_write_4(sc, LPC_OTG_I2C_CTRL, LPC_OTG_I2C_CTRL_SRST);
+  lpc_otg_write_4(sc, LPC_OTG_I2C_TXRX, self->i2c_addr | I2C_START_BIT);
+  lpc_otg_write_4(sc, LPC_OTG_I2C_TXRX, reg_addr);
+  lpc_otg_write_4(sc, LPC_OTG_I2C_TXRX, self->i2c_addr | I2C_START_BIT | I2C_READ);
+  lpc_otg_write_4(sc, LPC_OTG_I2C_TXRX, I2C_STOP_BIT);
+  eno = lpc_otg_i2c_wait_for_receive_fifo_not_empty(sc);
+  if (eno == 0) {
+    *value = (uint8_t)lpc_otg_read_4(sc, LPC_OTG_I2C_TXRX);
+  return eno;
+  int eno;
+  lpc_otg_write_4(sc, LPC_OTG_I2C_STATUS, LPC_OTG_I2C_STATUS_TDI);
+  lpc_otg_write_4(sc, LPC_OTG_I2C_TXRX, value | I2C_STOP_BIT);
+  eno = lpc_otg_i2c_wait_for_transaction_done(sc);
+  return eno;
+static int ohci_lpc_otg_transceiver_suspend(device_t dev, struct ohci_softc *sc)
+  int eno = 0;
+  if (eno == 0) {
+      LPC_OTG_CLOCK_CTRL_AHB_EN | LPC_OTG_CLOCK_CTRL_HOST_EN | LPC_OTG_CLOCK_CTRL_I2C_EN
+  if (eno == 0) {
+    eno = usb_otg_transceiver_suspend(&sc->sc_otg_trans);
+  if (eno == 0) {
+  return eno;
+static int
+lpc_ohci_resume(device_t dev)
+  int eno = 0;
+  if (eno == 0) {
+  if (eno == 0) {
+#ifdef BSP_USB_OTG_TRANSCEIVER_VBUS
+  if (eno == 0) {
+#endif /* BSP_USB_OTG_TRANSCEIVER_VBUS */
+  if (eno == 0) {
+  if (eno == 0) {
+    eno = bus_generic_resume(dev);
+  return (eno);
+static device_method_t lpc_ohci_methods[] = {
+	/* Device interface */
+	DEVMETHOD(device_probe,		lpc_ohci_probe),
+	DEVMETHOD(device_attach,	lpc_ohci_attach),
+	DEVMETHOD(device_detach,	lpc_ohci_detach),
+  DEVMETHOD(device_suspend, bus_generic_suspend),
+  DEVMETHOD(device_resume,  lpc_ohci_resume),
+	DEVMETHOD(device_shutdown,	bus_generic_shutdown),
+	/* Bus interface */
+	DEVMETHOD(bus_print_child,	bus_generic_print_child),
+	{ 0, 0 }
+static driver_t lpc_ohci_driver = {
+	"ohci",
+	lpc_ohci_methods,
+	sizeof(struct ohci_softc),
+static devclass_t lpc_ohci_devclass;
+DRIVER_MODULE(ohci, nexus, lpc_ohci_driver, lpc_ohci_devclass, 0, 0);
+MODULE_DEPEND(ohci, usb, 1, 1, 1);
+#endif /* defined(LIBBSP_ARM_LPC32XX_BSP_H) */
1.9.1
