[PATCH 06/10] Add support for LPC32XX USB driver
Kevin Kirspel kevin-kirspel at idexx.com
Mon Jan 30 16:58:20 UTC 2017
 freebsd/sys/dev/usb/controller/ohci.h      |  2 -
 rtemsbsd/sys/dev/usb/controller/ohci_lpc.c | 93 +-----------------------------
 rtemsbsd/sys/dev/usb/usb_otg_transceiver.h |  1 +
 3 files changed, 3 insertions(+), 93 deletions(-)
 mode change 100644 => 100755 freebsd/sys/dev/usb/controller/ohci.h
 mode change 100644 => 100755 rtemsbsd/sys/dev/usb/controller/ohci_lpc.c
 mode change 100644 => 100755 rtemsbsd/sys/dev/usb/usb_otg_transceiver.h
diff --git a/freebsd/sys/dev/usb/controller/ohci.h b/freebsd/sys/dev/usb/controller/ohci.h
old mode 100644
new mode 100755
index d020d99..a650ce1
--- a/freebsd/sys/dev/usb/controller/ohci.h
+++ b/freebsd/sys/dev/usb/controller/ohci.h
@@ -234,9 +234,7 @@ typedef struct ohci_softc {
 	struct ohci_ed *sc_bulk_p_last;
 	struct ohci_ed *sc_isoc_p_last;
 	struct ohci_ed *sc_intr_p_last[OHCI_NO_EDS];
-#ifndef __rtems__
 	void   *sc_intr_hdl;
-#endif /* __rtems__ */
 	device_t sc_dev;
 	bus_size_t sc_io_size;
 	bus_space_tag_t sc_io_tag;
diff --git a/rtemsbsd/sys/dev/usb/controller/ohci_lpc.c b/rtemsbsd/sys/dev/usb/controller/ohci_lpc.c
old mode 100644
new mode 100755
index a0314c5..de5bf2d
--- a/rtemsbsd/sys/dev/usb/controller/ohci_lpc.c
+++ b/rtemsbsd/sys/dev/usb/controller/ohci_lpc.c
@@ -36,12 +36,9 @@
-#if defined(LIBBSP_ARM_LPC24XX_BSP_H) || defined(LIBBSP_ARM_LPC32XX_BSP_H)
+#if defined(LIBBSP_ARM_LPC24XX_BSP_H)
 #include <bsp/irq.h>
-#ifdef LIBBSP_ARM_LPC24XX_BSP_H
 #include <bsp/io.h>
 #include <bsp/lpc24xx.h>
@@ -101,92 +98,6 @@ static void lpc_otg_status_and_control(void)
 	OTG_STAT_CTRL = 0x3;
-#endif /* LIBBSP_ARM_LPC24XX_BSP_H */
-#ifdef LIBBSP_ARM_LPC32XX_BSP_H
-#include <bsp/lpc32xx.h>
-#define LPC_USB_OHCI_BASE LPC32XX_BASE_USB
-#define LPC_USB_I2C_BASE (&LPC32XX_I2C_RX)
-#define LPC_OTG_CLK_CTRL LPC32XX_OTG_CLK_CTRL
-#define LPC_OTG_CLK_STAT LPC32XX_OTG_CLK_STAT
-#define LPC_USB_OHCI_IRQ LPC32XX_IRQ_USB_HOST
-#define USB_CTRL_SLAVE_HCLK_EN (1U << 24)
-#define USB_CTRL_I2C_EN (1U << 23)
-#define USB_CTRL_DEV_NEED_CLK_EN (1U << 22)
-#define USB_CTRL_HOST_NEED_CLK_EN (1U << 21)
-#define USB_CTRL_PC_MASK (0x3U << 19)
-#define USB_CTRL_PC_PULL_UP (0x0U << 19)
-#define USB_CTRL_PC_BUS_KEEPER (0x1U << 19)
-#define USB_CTRL_PC_NONE (0x2U << 19)
-#define USB_CTRL_PC_PULL_DOWN (0x3U << 19)
-#define USB_CTRL_CLKEN2 (1U << 18)
-#define USB_CTRL_CLKEN1 (1U << 17)
-#define USB_CTRL_POWER_UP (1U << 16)
-#define USB_CTRL_BYPASS (1U << 15)
-#define USB_CTRL_DIRECT (1U << 14)
-#define USB_CTRL_FEEDBACK (1U << 13)
-#define USB_CTRL_P_SHIFT 11
-#define USB_CTRL_P_MASK (0x3U << USB_CTRL_P_SHIFT)
-#define USB_CTRL_P_1 (0x0U << USB_CTRL_P_SHIFT)
-#define USB_CTRL_P_2 (0x1U << USB_CTRL_P_SHIFT)
-#define USB_CTRL_P_4 (0x2U << USB_CTRL_P_SHIFT)
-#define USB_CTRL_P_8 (0x3U << USB_CTRL_P_SHIFT)
-#define USB_CTRL_N_SHIFT 9
-#define USB_CTRL_N_MASK (0x3U << USB_CTRL_N_SHIFT)
-#define USB_CTRL_N_1 (0x0U << USB_CTRL_N_SHIFT)
-#define USB_CTRL_N_2 (0x1U << USB_CTRL_N_SHIFT)
-#define USB_CTRL_N_3 (0x2U << USB_CTRL_N_SHIFT)
-#define USB_CTRL_N_4 (0x3U << USB_CTRL_N_SHIFT)
-#define USB_CTRL_M_SHIFT 1
-#define USB_CTRL_M_MASK (0xffU << USB_CTRL_M_SHIFT)
-#define USB_CTRL_PLL_LOCK (1U << 0)
-static void lpc_usb_module_enable(void)
-	LPC32XX_USB_DIV = 0xc;
-	LPC32XX_USB_CTRL = USB_CTRL_SLAVE_HCLK_EN
-		| USB_CTRL_PC_BUS_KEEPER
-		| USB_CTRL_CLKEN1
-		| USB_CTRL_POWER_UP
-		| USB_CTRL_P_2
-		| USB_CTRL_N_1
-		| (191U << USB_CTRL_M_SHIFT);
-	while ((LPC32XX_USB_CTRL & USB_CTRL_PLL_LOCK) == 0) {
-		/* Wait */
-	LPC32XX_USB_CTRL |= USB_CTRL_CLKEN2;
-static void lpc_usb_module_disable(void)
-	LPC32XX_OTG_CLK_CTRL = 0;
-	LPC32XX_USB_CTRL = USB_CTRL_PC_BUS_KEEPER;
-static void lpc_usb_pin_config(void)
-	/* Nothing to do */
-static void lpc_usb_host_clock_enable(void)
-	LPC32XX_USB_CTRL |= USB_CTRL_HOST_NEED_CLK_EN;
-static void lpc_otg_status_and_control(void)
-	LPC32XX_OTG_STAT_CTRL = 0x1;
-#endif /* LIBBSP_ARM_LPC32XX_BSP_H */
 static rtems_interval lpc_usb_timeout_init(void)
 	return rtems_clock_get_ticks_since_boot();
@@ -639,4 +550,4 @@ static devclass_t ohci_devclass;
 DRIVER_MODULE(ohci, nexus, ohci_driver, ohci_devclass, 0, 0);
 MODULE_DEPEND(ohci, usb, 1, 1, 1);
-#endif /* defined(LIBBSP_ARM_LPC24XX_BSP_H) || defined(LIBBSP_ARM_LPC32XX_BSP_H) */
+#endif /* defined(LIBBSP_ARM_LPC24XX_BSP_H) */
diff --git a/rtemsbsd/sys/dev/usb/usb_otg_transceiver.h b/rtemsbsd/sys/dev/usb/usb_otg_transceiver.h
old mode 100644
new mode 100755
index 1e6b738..249d6a7
--- a/rtemsbsd/sys/dev/usb/usb_otg_transceiver.h
+++ b/rtemsbsd/sys/dev/usb/usb_otg_transceiver.h
@@ -88,6 +88,7 @@ struct usb_otg_transceiver {
 	uint16_t vendor_id;
 	uint16_t product_id;
 	uint8_t i2c_addr;
+	void* softc;
 int usb_otg_transceiver_read(
1.9.1
