[PATCH 05/10] Adding support for LPC32XX network driver and phy
Kevin Kirspel
kevin-kirspel at idexx.com
Mon Jan 30 16:58:19 UTC 2017
freebsd/sys/arm/lpc/if_lpe.c | 178 +++++++++++++++++++++++++++++
freebsd/sys/arm/lpc/lpc_pwr.c | 8 ++
freebsd/sys/dev/mii/icsphy.c | 3 +
rtemsbsd/include/rtems/bsd/local/miidevs.h | 2 +
4 files changed, 191 insertions(+)
mode change 100644 => 100755 freebsd/sys/arm/lpc/if_lpe.c
mode change 100644 => 100755 freebsd/sys/arm/lpc/lpc_pwr.c
mode change 100644 => 100755 freebsd/sys/dev/mii/icsphy.c
mode change 100644 => 100755 rtemsbsd/include/rtems/bsd/local/miidevs.h
diff --git a/freebsd/sys/arm/lpc/if_lpe.c b/freebsd/sys/arm/lpc/if_lpe.c
old mode 100644
new mode 100755
index 76b794f..69e24ae
--- a/freebsd/sys/arm/lpc/if_lpe.c
+++ b/freebsd/sys/arm/lpc/if_lpe.c
@@ -43,7 +43,9 @@ __FBSDID("$FreeBSD$");
#include <sys/bus.h>
#include <sys/socket.h>
#include <machine/bus.h>
+#ifndef __rtems__
#include <machine/intr.h>
+#endif /* __rtems__ */
#include <net/if.h>
#include <net/if_arp.h>
@@ -55,8 +57,10 @@ __FBSDID("$FreeBSD$");
#include <net/bpf.h>
+#ifndef __rtems__
#include <dev/ofw/ofw_bus.h>
#include <dev/ofw/ofw_bus_subr.h>
#include <dev/mii/mii.h>
#include <dev/mii/miivar.h>
@@ -66,6 +70,9 @@ __FBSDID("$FreeBSD$");
#include <arm/lpc/if_lpereg.h>
#include <rtems/bsd/local/miibus_if.h>
+#ifdef __rtems__
+#include <machine/rtems-bsd-cache.h>
#ifdef DEBUG
#define debugf(fmt, args...) do { printf("%s(): ", __func__); \
@@ -80,13 +87,17 @@ struct lpe_dmamap_arg {
struct lpe_rxdesc {
struct mbuf * lpe_rxdesc_mbuf;
+#ifndef __rtems__
bus_dmamap_t lpe_rxdesc_dmamap;
struct lpe_txdesc {
int lpe_txdesc_first;
struct mbuf * lpe_txdesc_mbuf;
+#ifndef __rtems__
bus_dmamap_t lpe_txdesc_dmamap;
struct lpe_chain_data {
@@ -122,7 +133,9 @@ struct lpe_ring_data {
struct lpe_softc {
struct ifnet * lpe_ifp;
struct mtx lpe_mtx;
+#ifndef __rtems__
phandle_t lpe_ofw;
device_t lpe_dev;
device_t lpe_miibus;
uint8_t lpe_enaddr[6];
@@ -192,11 +205,13 @@ static int
lpe_probe(device_t dev)
+#ifndef __rtems__
if (!ofw_bus_status_okay(dev))
return (ENXIO);
if (!ofw_bus_is_compatible(dev, "lpc,ethernet"))
return (ENXIO);
device_set_desc(dev, "LPC32x0 10/100 Ethernet");
return (BUS_PROBE_DEFAULT);
@@ -211,6 +226,7 @@ lpe_attach(device_t dev)
uint32_t val;
sc->lpe_dev = dev;
+#ifndef __rtems__
sc->lpe_ofw = ofw_bus_get_node(dev);
i = OF_getprop(sc->lpe_ofw, "local-mac-address", (void *)&sc->lpe_enaddr, 6);
@@ -222,6 +238,9 @@ lpe_attach(device_t dev)
sc->lpe_enaddr[4] = 0x44;
sc->lpe_enaddr[5] = 0x55;
+#else /* __rtems__ */
+ rtems_bsd_get_mac_address(device_get_name(sc->lpe_dev), device_get_unit(sc->lpe_dev), &sc->lpe_enaddr);
mtx_init(&sc->lpe_mtx, device_get_nameunit(dev), MTX_NETWORK_LOCK,
MTX_DEF);
@@ -275,16 +294,33 @@ lpe_attach(device_t dev)
/* Enable Ethernet clock */
+#ifndef __rtems__
lpc_pwr_write(dev, LPC_CLKPWR_MACCLK_CTRL,
LPC_CLKPWR_MACCLK_CTRL_REG |
LPC_CLKPWR_MACCLK_CTRL_SLAVE |
LPC_CLKPWR_MACCLK_CTRL_MASTER |
LPC_CLKPWR_MACCLK_CTRL_HDWINF(3));
+#ifdef LPC32XX_ETHERNET_RMII
+ lpc_pwr_write(dev, LPC_CLKPWR_MACCLK_CTRL,
+ LPC_CLKPWR_MACCLK_CTRL_REG |
+ LPC_CLKPWR_MACCLK_CTRL_SLAVE |
+ LPC_CLKPWR_MACCLK_CTRL_MASTER |
+ LPC_CLKPWR_MACCLK_CTRL_HDWINF(3));
+#else
+ LPC_CLKPWR_MACCLK_CTRL_HDWINF(1));
+#endif
/* Reset chip */
lpe_reset(sc);
/* Initialize MII */
+#ifndef __rtems__
val = lpe_read_4(sc, LPE_COMMAND);
lpe_write_4(sc, LPE_COMMAND, val | LPE_COMMAND_RMII);
@@ -294,6 +330,14 @@ lpe_attach(device_t dev)
device_printf(dev, "cannot find PHY\n");
goto fail;
+ if (mii_attach(dev, &sc->lpe_miibus, ifp, lpe_ifmedia_upd,
+ lpe_ifmedia_sts, BMSR_DEFCAPMASK, MII_PHY_ANY,
+ MII_OFFSET_ANY, 0)) {
+ device_printf(dev, "cannot find PHY\n");
+ goto fail;
lpe_dma_alloc(sc);
@@ -388,7 +432,9 @@ lpe_miibus_statchg(device_t dev)
struct lpe_softc *sc = device_get_softc(dev);
struct mii_data *mii = device_get_softc(sc->lpe_miibus);
+#ifndef __rtems__
lpe_lock(sc);
if ((mii->mii_media_status & IFM_ACTIVE) &&
(mii->mii_media_status & IFM_AVALID))
@@ -396,7 +442,9 @@ lpe_miibus_statchg(device_t dev)
else
sc->lpe_flags &= ~LPE_FLAG_LINK;
+#ifndef __rtems__
lpe_unlock(sc);
static void
@@ -404,6 +452,7 @@ lpe_reset(struct lpe_softc *sc)
uint32_t mac1;
+#ifndef __rtems__
/* Enter soft reset mode */
mac1 = lpe_read_4(sc, LPE_MAC1);
lpe_write_4(sc, LPE_MAC1, mac1 | LPE_MAC1_SOFTRESET | LPE_MAC1_RESETTX |
@@ -422,6 +471,43 @@ lpe_reset(struct lpe_softc *sc)
lpe_write_4(sc, LPE_MAC1, mac1 & ~(LPE_MAC1_SOFTRESET | LPE_MAC1_RESETTX |
LPE_MAC1_RESETMCSTX | LPE_MAC1_RESETRX | LPE_MAC1_RESETMCSRX));
+ /* Reset registers, Tx path and Rx path */
+ lpe_write_4(sc, LPE_COMMAND, LPE_COMMAND_REGRESET | LPE_COMMAND_TXRESET | LPE_COMMAND_RXRESET);
+ /* Enter soft reset mode */
+ mac1 = lpe_read_4(sc, LPE_MAC1);
+ lpe_write_4(sc, LPE_MAC1, mac1 | LPE_MAC1_SOFTRESET | LPE_MAC1_RESETTX |
+ LPE_MAC1_RESETMCSTX | LPE_MAC1_RESETRX | LPE_MAC1_RESETMCSRX);
+ /* Leave soft reset mode */
+ lpe_write_4(sc, LPE_MAC1, mac1 & ~(LPE_MAC1_SOFTRESET | LPE_MAC1_RESETTX |
+ LPE_MAC1_RESETMCSTX | LPE_MAC1_RESETRX | LPE_MAC1_RESETMCSRX));
+ /* Reinitialize registers */
+ lpe_write_4(sc, LPE_MCFG, LPE_MCFG_CLKSEL(0x7));
+ lpe_write_4(sc, LPE_MAC2, LPE_MAC2_PADCRCENABLE | LPE_MAC2_CRCENABLE | LPE_MAC2_FULLDUPLEX);
+ lpe_write_4(sc, LPE_IPGT, 0x15);
+ lpe_write_4(sc, LPE_IPGR, 0x12);
+ lpe_write_4(sc, LPE_CLRT, 0x370f);
+ lpe_write_4(sc, LPE_MAXF, 0x0600);
+ lpe_write_4(sc, LPE_SUPP, LPE_SUPP_SPEED);
+ lpe_write_4(sc, LPE_TEST, 0x0);
+ lpe_write_4(sc, LPE_COMMAND, LPE_COMMAND_FULLDUPLEX | LPE_COMMAND_RMII);
+#else
+ lpe_write_4(sc, LPE_COMMAND, LPE_COMMAND_FULLDUPLEX);
+#endif
+ lpe_write_4(sc, LPE_INTENABLE, 0x0);
+ lpe_write_4(sc, LPE_INTCLEAR, 0x30ff);
+ lpe_write_4(sc, LPE_POWERDOWN, 0x0);
+ /* Set station address */
+ lpe_write_4(sc, LPE_SA2, sc->lpe_enaddr[1] << 8 | sc->lpe_enaddr[0]);
+ lpe_write_4(sc, LPE_SA1, sc->lpe_enaddr[3] << 8 | sc->lpe_enaddr[2]);
+ lpe_write_4(sc, LPE_SA0, sc->lpe_enaddr[5] << 8 | sc->lpe_enaddr[4]);
static void
@@ -533,6 +619,31 @@ lpe_start_locked(struct ifnet *ifp)
+#ifdef __rtems__
+static int
+lpe_get_segs_for_tx(struct mbuf *m, bus_dma_segment_t segs[LPE_MAXFRAGS],
+ int *nsegs)
+ int i = 0;
+ do {
+ if (m->m_len > 0) {
+ segs[i].ds_addr = mtod(m, bus_addr_t);
+ segs[i].ds_len = m->m_len;
+#ifdef CPU_DATA_CACHE_ALIGNMENT
+ rtems_cache_flush_multiple_data_lines(m->m_data, m->m_len);
+#endif
+ ++i;
+ m = m->m_next;
+ if (m == NULL) {
+ *nsegs = i;
+ return (0);
+ } while (i < LPE_MAXFRAGS);
+ return (EFBIG);
static int
lpe_encap(struct lpe_softc *sc, struct mbuf **m_head)
@@ -549,8 +660,12 @@ lpe_encap(struct lpe_softc *sc, struct mbuf **m_head)
debugf("starting with prod=%d\n", prod);
+#ifndef __rtems__
err = bus_dmamap_load_mbuf_sg(sc->lpe_cdata.lpe_tx_buf_tag,
txd->lpe_txdesc_dmamap, *m_head, segs, &nsegs, BUS_DMA_NOWAIT);
+ err = lpe_get_segs_for_tx(*m_head, segs, &nsegs);
if (err)
return (err);
@@ -561,8 +676,10 @@ lpe_encap(struct lpe_softc *sc, struct mbuf **m_head)
return (EIO);
+#ifndef __rtems__
bus_dmamap_sync(sc->lpe_cdata.lpe_tx_buf_tag, txd->lpe_txdesc_dmamap,
BUS_DMASYNC_PREREAD);
bus_dmamap_sync(sc->lpe_cdata.lpe_tx_ring_tag, sc->lpe_cdata.lpe_tx_ring_map,
BUS_DMASYNC_POSTREAD | BUS_DMASYNC_POSTWRITE);
@@ -581,6 +698,11 @@ lpe_encap(struct lpe_softc *sc, struct mbuf **m_head)
hwd->lhr_control |= LPE_HWDESC_PAD;
+#ifdef __rtems__
+ rtems_cache_flush_multiple_data_lines(hwd, sizeof(*hwd));
+#endif
LPE_INC(prod, LPE_TXDESC_NUM);
@@ -724,9 +846,19 @@ lpe_intr(void *arg)
if (intstatus & LPE_INT_RXDONE)
lpe_rxintr(sc);
+#ifndef __rtems__
if (intstatus & LPE_INT_TXDONE)
lpe_txintr(sc);
+ if (intstatus & LPE_INT_TXUNDERRUN) {
+ if_inc_counter(sc->lpe_ifp, IFCOUNTER_OERRORS, 1);
+ lpe_stop_locked(sc);
+ lpe_init_locked(sc);
+ else if (intstatus & (LPE_INT_TXERROR | LPE_INT_TXFINISH | LPE_INT_TXDONE))
+ lpe_txintr(sc);
lpe_write_4(sc, LPE_INTCLEAR, 0xffff);
@@ -753,6 +885,13 @@ lpe_rxintr(struct lpe_softc *sc)
rxd = &sc->lpe_cdata.lpe_rx_desc[cons];
hwd = &sc->lpe_rdata.lpe_rx_ring[cons];
hws = &sc->lpe_rdata.lpe_rx_status[cons];
+#ifdef __rtems__
+ rtems_cache_invalidate_multiple_data_lines(rxd, sizeof(*rxd));
+ rtems_cache_invalidate_multiple_data_lines(hwd, sizeof(*hwd));
+ rtems_cache_invalidate_multiple_data_lines(hws, sizeof(*hws));
+#endif
/* Check received frame for errors */
if (hws->lhs_info & LPE_HWDESC_RXERRS) {
@@ -763,6 +902,11 @@ lpe_rxintr(struct lpe_softc *sc)
m = rxd->lpe_rxdesc_mbuf;
+#ifdef __rtems__
+ rtems_cache_invalidate_multiple_data_lines(m->m_data, m->m_len);
+#endif
m->m_pkthdr.rcvif = ifp;
m->m_data += 2;
@@ -799,8 +943,16 @@ lpe_txintr(struct lpe_softc *sc)
hwd = &sc->lpe_rdata.lpe_tx_ring[last];
hws = &sc->lpe_rdata.lpe_tx_status[last];
+#ifndef __rtems__
txd->lpe_txdesc_dmamap, BUS_DMASYNC_POSTWRITE);
+ rtems_cache_invalidate_multiple_data_lines(txd, sizeof(*txd));
+#endif
if_inc_counter(ifp, IFCOUNTER_COLLISIONS, LPE_HWDESC_COLLISIONS(hws->lhs_info));
@@ -810,8 +962,10 @@ lpe_txintr(struct lpe_softc *sc)
if_inc_counter(ifp, IFCOUNTER_OPACKETS, 1);
if (txd->lpe_txdesc_first) {
+#ifndef __rtems__
bus_dmamap_unload(sc->lpe_cdata.lpe_tx_buf_tag,
txd->lpe_txdesc_dmamap);
m_freem(txd->lpe_txdesc_mbuf);
txd->lpe_txdesc_mbuf = NULL;
@@ -979,6 +1133,7 @@ lpe_dma_alloc_rx(struct lpe_softc *sc)
for (i = 0; i < LPE_RXDESC_NUM; i++) {
rxd = &sc->lpe_cdata.lpe_rx_desc[i];
rxd->lpe_rxdesc_mbuf = NULL;
+#ifndef __rtems__
rxd->lpe_rxdesc_dmamap = NULL;
err = bus_dmamap_create(sc->lpe_cdata.lpe_rx_buf_tag, 0,
@@ -988,6 +1143,7 @@ lpe_dma_alloc_rx(struct lpe_softc *sc)
device_printf(sc->lpe_dev, "cannot create Rx DMA map\n");
return (err);
return (0);
@@ -1081,11 +1237,15 @@ lpe_dma_alloc_tx(struct lpe_softc *sc)
for (i = 0; i < LPE_TXDESC_NUM; i++) {
txd = &sc->lpe_cdata.lpe_tx_desc[i];
+#ifndef __rtems__
txd->lpe_txdesc_dmamap = NULL;
txd->lpe_txdesc_first = 0;
+#ifndef __rtems__
err = bus_dmamap_create(sc->lpe_cdata.lpe_tx_buf_tag, 0,
&txd->lpe_txdesc_dmamap);
if (err) {
device_printf(sc->lpe_dev, "cannot create Tx DMA map\n");
@@ -1134,6 +1294,7 @@ lpe_init_rxbuf(struct lpe_softc *sc, int n)
m->m_len = m->m_pkthdr.len = MCLBYTES;
+#ifndef __rtems__
bus_dmamap_unload(sc->lpe_cdata.lpe_rx_buf_tag, rxd->lpe_rxdesc_dmamap);
if (bus_dmamap_load_mbuf_sg(sc->lpe_cdata.lpe_rx_buf_tag,
@@ -1144,10 +1305,21 @@ lpe_init_rxbuf(struct lpe_softc *sc, int n)
bus_dmamap_sync(sc->lpe_cdata.lpe_rx_buf_tag, rxd->lpe_rxdesc_dmamap,
+#endif
+ segs[0].ds_addr = mtod(m, bus_addr_t);
rxd->lpe_rxdesc_mbuf = m;
hwd->lhr_data = segs[0].ds_addr + 2;
hwd->lhr_control = (segs[0].ds_len - 1) | LPE_HWDESC_INTERRUPT;
+#ifdef __rtems__
+#endif
return (0);
@@ -1161,7 +1333,9 @@ lpe_discard_rxbuf(struct lpe_softc *sc, int n)
rxd = &sc->lpe_cdata.lpe_rx_desc[n];
hwd = &sc->lpe_rdata.lpe_rx_ring[n];
+#ifndef __rtems__
hwd->lhr_data = 0;
hwd->lhr_control = 0;
@@ -1227,7 +1401,11 @@ static driver_t lpe_driver = {
static devclass_t lpe_devclass;
+#ifndef __rtems__
DRIVER_MODULE(lpe, simplebus, lpe_driver, lpe_devclass, 0, 0);
+DRIVER_MODULE(lpe, nexus, lpe_driver, lpe_devclass, 0, 0);
DRIVER_MODULE(miibus, lpe, miibus_driver, miibus_devclass, 0, 0);
MODULE_DEPEND(lpe, obio, 1, 1, 1);
MODULE_DEPEND(lpe, miibus, 1, 1, 1);
diff --git a/freebsd/sys/arm/lpc/lpc_pwr.c b/freebsd/sys/arm/lpc/lpc_pwr.c
old mode 100644
new mode 100755
index 0ea8c6a..231024d
--- a/freebsd/sys/arm/lpc/lpc_pwr.c
+++ b/freebsd/sys/arm/lpc/lpc_pwr.c
@@ -38,10 +38,12 @@ __FBSDID("$FreeBSD$");
#include <sys/malloc.h>
#include <sys/rman.h>
+#ifndef __rtems__
#include <arm/lpc/lpcreg.h>
#include <arm/lpc/lpcvar.h>
@@ -67,11 +69,13 @@ static int
lpc_pwr_probe(device_t dev)
+#ifndef __rtems__
return (ENXIO);
if (!ofw_bus_is_compatible(dev, "lpc,pwr"))
return (ENXIO);
device_set_desc(dev, "LPC32x0 Power Controller");
@@ -128,4 +132,8 @@ static driver_t lpc_pwr_driver = {
sizeof(struct lpc_pwr_softc),
+#ifndef __rtems__
DRIVER_MODULE(pwr, simplebus, lpc_pwr_driver, lpc_pwr_devclass, 0, 0);
+DRIVER_MODULE(pwr, nexus, lpc_pwr_driver, lpc_pwr_devclass, 0, 0);
diff --git a/freebsd/sys/dev/mii/icsphy.c b/freebsd/sys/dev/mii/icsphy.c
old mode 100644
new mode 100755
index 29444f3..a51b899
--- a/freebsd/sys/dev/mii/icsphy.c
+++ b/freebsd/sys/dev/mii/icsphy.c
@@ -113,6 +113,9 @@ static const struct mii_phydesc icsphys[] = {
MII_PHY_DESC(ICS, 1890),
MII_PHY_DESC(ICS, 1892),
MII_PHY_DESC(ICS, 1893),
+#ifdef __rtems__
+ MII_PHY_DESC(ICS, 1893C),
MII_PHY_END
diff --git a/rtemsbsd/include/rtems/bsd/local/miidevs.h b/rtemsbsd/include/rtems/bsd/local/miidevs.h
old mode 100644
new mode 100755
index 2199229..18931b2
--- a/rtemsbsd/include/rtems/bsd/local/miidevs.h
+++ b/rtemsbsd/include/rtems/bsd/local/miidevs.h
@@ -318,6 +318,8 @@
#define MII_STR_ICS_1892 "ICS1892 10/100 media interface"
#define MII_MODEL_ICS_1893 0x0004
#define MII_STR_ICS_1893 "ICS1893 10/100 media interface"
+#define MII_MODEL_ICS_1893C 0x0005
+#define MII_STR_ICS_1893C "ICS1893C 10/100 media interface"
/* Intel Corporation PHYs */
#define MII_MODEL_xxINTEL_I82553 0x0000
1.9.1
