[PATCH] Remove rtems_rate_monotonic_postponed_job_count() Add a variable named "count" in rtems_rate_monotonic_period_status structure Revise rtems_rate_monotonic_get_status() for the postponed job count.
Kuan Hsun Chen c0066c at gmail.com
Wed Jan 25 16:31:13 UTC 2017
Hi Gedare,
Thanks a lot.
I should read all the documents again...
Best,
Kuan-Hsun
2017-01-25 17:16 GMT+01:00 Gedare Bloom <gedare at rtems.org>:
> On Wed, Jan 25, 2017 at 9:16 AM, Kuan Hsun Chen <c0066c at gmail.com> wrote:
> > Hi Sebastian,
> > Okay. I will clarify it.
> > I used git format-patch -1 to generate the patch and git send-email --to
> > devel at rtems.org *.patch to send out the mail.
> > Could you tell me what I have missed?
> https://devel.rtems.org/wiki/Developer/Git#GitCommits
> This should likely be linked to / added in the
> https://devel.rtems.org/wiki/Developer/Coding/Conventions
> > Aha, it is 2017...
> > Best,
> > Kuan-hsun
> > 2017-01-25 15:10 GMT+01:00 Sebastian Huber
> > <sebastian.huber at embedded-brains.de>:
> >> Please use the standard Git commit message format.
> >> On 25/01/17 15:04, Kuan-Hsun Chen wrote:
> >>> sptests/sp69: Revise
> >>> Add in the verification of the postponed job count for
> >>> rtems_rate_monotonic_get_status().
> >>>   cpukit/rtems/include/rtems/rtems/ratemon.h | 24
> >>>   cpukit/rtems/src/ratemongetstatus.c        |  2 ++
> >>>   cpukit/rtems/src/ratemonperiod.c           | 14 --------------
> >>>   testsuites/sptests/sp69/init.c             |  8 ++++++++
> >>>   testsuites/sptests/sp69/sp69.doc           |  2 ++
> >>>   testsuites/sptests/sp69/sp69.scn           |  5 +++--
> >>>   6 files changed, 20 insertions(+), 35 deletions(-)
> >>> diff --git a/cpukit/rtems/include/rtems/rtems/ratemon.h
> >>> b/cpukit/rtems/include/rtems/rtems/ratemon.h
> >>> index 54ddd05..59512c5 100644
> >>> --- a/cpukit/rtems/include/rtems/rtems/ratemon.h
> >>> +++ b/cpukit/rtems/include/rtems/rtems/ratemon.h
> >>> @@ -182,6 +182,11 @@ typedef struct {
> >>>      *  then this field has no meaning.
> >>>     rtems_thread_cpu_usage_t             executed_since_last_period;
> >>> +  /** This is the number of postponed jobs. This number
> >>> +   * is only increased by the corresponding watchdog,
> >>> +   * and is decreased by RMS manager with the postponed job releasing.
> >>> +  uint32_t                             postponed_jobs_count;
> >>>   }  rtems_rate_monotonic_period_status;
> >> Number in comment vs. count in member. I prefer count. Please clarify
> this
> >> a bit and avoid the watchdog. The watchdog is an implementation detail.
> The
> >> mentioning of RMS manager is redundant.
> >>> @@ -417,25 +422,6 @@ rtems_status_code rtems_rate_monotonic_period(
> >>>     rtems_interval  length
> >>> - * @brief Return the number of postponed jobs
> >>> - * This is a helper function for runtime monitoring to return
> >>> - * the number of postponed jobs in this given period. This number
> >>> - * is only increased by the corresponding watchdog,
> >>> - * and is decreased by RMS manager with the postponed job releasing.
> >>> - * @param[in] id is the period id
> >>> - * @retval This helper function returns the number of postponed
> >>> - * jobs with a given period_id.
> >>> -uint32_t rtems_rate_monotonic_postponed_job_count(
> >>> -  rtems_id        period_id
> >>>     #ifdef __cplusplus
> >>> diff --git a/cpukit/rtems/src/ratemongetstatus.c
> >>> b/cpukit/rtems/src/ratemongetstatus.c
> >>> index 403c6ed..8bd3613 100644
> >>> --- a/cpukit/rtems/src/ratemongetstatus.c
> >>> +++ b/cpukit/rtems/src/ratemongetstatus.c
> >>> @@ -9,6 +9,7 @@
> >>>    *  COPYRIGHT (c) 1989-2009.
> >>>    *  On-Line Applications Research Corporation (OAR).
> >>>    *  Copyright (c) 2016 embedded brains GmbH.
> >>> + *  Copyright (c) 2016 Kuan-Hsun Chen.
> >> We have 2017.
> >>>    *  The license and distribution terms for this file may be
> >>>    *  found in the file LICENSE in this distribution or at
> >>> @@ -43,6 +44,7 @@ rtems_status_code rtems_rate_monotonic_get_status(
> >>>       period_status->owner = the_period->owner->Object.id;
> >>>     period_status->state = the_period->state;
> >>> +  period_status->postponed_jobs_count = the_period->postponed_jobs;
> >>>       if ( the_period->state == RATE_MONOTONIC_INACTIVE ) {
> >>> diff --git a/cpukit/rtems/src/ratemonperiod.c
> >>> b/cpukit/rtems/src/ratemonperiod.c
> >>> index 97547e2..efcd121 100644
> >>> --- a/cpukit/rtems/src/ratemonperiod.c
> >>> +++ b/cpukit/rtems/src/ratemonperiod.c
> >>> @@ -302,20 +302,6 @@ static rtems_status_code
> >>> _Rate_monotonic_Block_while_expired(
> >>>     return RTEMS_TIMEOUT;
> >>>   -uint32_t rtems_rate_monotonic_postponed_job_count( rtems_id
> period_id
> >>> -  Rate_monotonic_Control *the_period;
> >>> -  ISR_lock_Context        lock_context;
> >>> -  uint32_t                jobs;
> >>> -  the_period = _Rate_monotonic_Get( period_id, &lock_context );
> >>> -  _Assert( the_period != NULL );
> >>> -  jobs = the_period->postponed_jobs;
> >>> -  _Rate_monotonic_Release( the_period, &lock_context );
> >>> -  return jobs;
> >>>     rtems_id       id,
> >>> diff --git a/testsuites/sptests/sp69/init.c
> >>> b/testsuites/sptests/sp69/init.c
> >>> index ac6f58c..c38beb8 100644
> >>> --- a/testsuites/sptests/sp69/init.c
> >>> +++ b/testsuites/sptests/sp69/init.c
> >> Missing copyright?
> >>> @@ -162,6 +162,14 @@ rtems_task Init(
> >>>            rtems_test_assert( statistics.missed_count == i );
> >>> +  /* Check the status */
> >>> +  status = rtems_rate_monotonic_get_status( period_id,
> &period_status );
> >>> +  directive_failed( status, "rate_monotonic_get_status" );
> >>> +  puts(
> >>> +    "rtems_rate_monotonic_get_status - verify value of a postponed
> jobs
> >>> count"
> >>> +  rtems_test_assert( period_status.postponed_jobs_count == 3 );
> >>>         TEST_END();
> >>>   diff --git a/testsuites/sptests/sp69/sp69.doc
> >>> b/testsuites/sptests/sp69/sp69.doc
> >>> index fbf0e4e..e881a19 100644
> >>> --- a/testsuites/sptests/sp69/sp69.doc
> >>> +++ b/testsuites/sptests/sp69/sp69.doc
> >>> @@ -1,5 +1,6 @@
> >>>   #  COPYRIGHT (c) 1989-2009.
> >>>   #  On-Line Applications Research Corporation (OAR).
> >>> +#  COPYRIGHT (c) Kuan-Hsun Chen.
> >> Missing year.
> >>>   #  The license and distribution terms for this file may be
> >>>   #  found in the file LICENSE in this distribution or at
> >>> @@ -21,3 +22,4 @@ concepts:
> >>>     a period is initiated.
> >>>   + Verify the correctness of the status values returned on an active
> >>> period.
> >>>   + Ensure the missed period count is properly maintained.
> >>> ++ Verify the correctness of the postponed job count.
> >>> diff --git a/testsuites/sptests/sp69/sp69.scn
> >>> b/testsuites/sptests/sp69/sp69.scn
> >>> index 654eea0..e102d22 100644
> >>> --- a/testsuites/sptests/sp69/sp69.scn
> >>> +++ b/testsuites/sptests/sp69/sp69.scn
> >>> @@ -2,8 +2,9 @@
> >>>   rtems_rate_monotonic_get_status - verify values of an inactive
> period
> >>>   rtems_rate_monotonic_get_status - check RTEMS_NOT_DEFINED
> >>>   rtems_rate_monotonic_get_status - verify values of an active period
> >>> -wall time should be ~600000000 is 609216000
> >>> -cpu time should be ~100000000 is 109217000
> >>> +wall time should be ~600000000 is 609402399
> >>> +cpu time should be ~100000000 is 109612659
> >>>   rtems_rate_monotonic_cancel -  OK
> >>>   Testing statistics on missed periods
> >>> +rtems_rate_monotonic_get_status - verify value of a postponed jobs
> count
> >>>   *** END OF TEST 69 ***
> >> Sebastian Huber, embedded brains GmbH
> >> Address : Dornierstr. 4, D-82178 Puchheim, Germany
> >> Phone   : +49 89 189 47 41-16
> >> Fax     : +49 89 189 47 41-09
> >> E-Mail  : sebastian.huber at embedded-brains.de
> >> PGP     : Public key available on request.
> >> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170125/28f6725e/attachment-0002.html>
