LIBBSD TCPDUMP
Kirspel, Kevin
Kevin-Kirspel at idexx.com
Sat Jul 1 15:49:03 UTC 2017
This is how I fixed it. I did similar things for EXTRACT_32BITS and EXTRACT_64BITS.
static inline u_int16_t
EXTRACT_16BITS(const void *p)
#if defined(__arm__) && defined(__rtems__)
if(((uint32_t)p % 2) != 0) {
u_int16_t value;
u_int8_t *ptr = (u_int8_t *)&value;
ptr[0] = ((const u_int8_t *)p)[0];
ptr[1] = ((const u_int8_t *)p)[1];
p = &value;
#endif /* __rtems__ */
return ((u_int16_t)ntohs(*(const u_int16_t *)(p)));
Kevin Kirspel
Electrical Engineer - Sr. Staff
Idexx Roswell
235 Hembree Park Drive
Roswell GA 30076
Tel: (770)-510-4444 ext. 81642
Direct: (770)-688-1642
Fax: (770)-510-4445
Sent: Saturday, July 01, 2017 11:39 AM
To: Gedare Bloom <gedare at rtems.org>
Cc: rtems-devel at rtems.org <devel at rtems.org>; Kirspel, Kevin <Kevin-Kirspel at idexx.com>
Subject: Re: LIBBSD TCPDUMP
On Jul 1, 2017 10:34 AM, "Gedare Bloom" <gedare at rtems.org<mailto:gedare at rtems.org>> wrote:
On Sat, Jul 1, 2017 at 10:01 AM, Kirspel, Kevin <Kevin-Kirspel at idexx.com<mailto:Kevin-Kirspel at idexx.com>> wrote:
> I get a crash when running the tcpdump command in LIBBSD. It is due to the
> following structure
> struct stp_bpdu_ {
> u_int8_t protocol_id[2];
> u_int8_t protocol_version;
> u_int8_t bpdu_type;
> u_int8_t flags;
> u_int8_t root_id[8];
> u_int8_t root_path_cost[4];
> u_int8_t bridge_id[8];
> u_int8_t port_id[2];
> u_int8_t message_age[2];
> u_int8_t max_age[2];
> u_int8_t hello_time[2];
> u_int8_t forward_delay[2];
> u_int8_t v1_length;
> In the code, there is an access to the port_id field as follows:
> EXTRACT_16BITS(&stp_bpdu->port_id). EXTRACT_16BITS calls ntohs() . Since
> the address of “&stp_bpdu->port_id” is at an odd word (16 bit) boundary, an
> exception is generated. What is the correct way to fix this? I was going
> to update EXTRACT_16BITS to check for an odd boundary and fix it up before
> calling ntohs().
That would probably be a more portable fix than allowing unaligned
accesses. I think the alignment should be made to the CPU_ALIGNMENT
macro.
Can't you also just pull it out a byte at a time, form the net version and then ntohs()?
That's what I coded recently in some marahalling code.
> Kevin Kirspel
> Idexx Roswell
> Roswell GA 30076
> Tel: (770)-510-4444 ext. 81642<tel:%28770%29-510-4444%20ext.%2081642>
> Direct: (770)-688-1642<tel:%28770%29-688-1642>
> Fax: (770)-510-4445<tel:%28770%29-510-4445>
> devel mailing list
> devel at rtems.org<mailto:devel at rtems.org>
> http://lists.rtems.org/mailman/listinfo/devel<https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_devel&d=DwMFaQ&c=2do6VJGs3LvEOe4OFFM1bA&r=HDiJ93ANMEQ32G5JGdpyUxbdebuwKHBbeiHMr3RbR74&m=DfsZaORruX70gPrZk3-vjldOIsh4IFQ9ZRHVCZMKJ_o&s=Xx_hsbQ3vmD8L038yTJmDbvtePgAQkCJ7YBI_A6FR-Y&e=>
devel mailing list
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170701/2f03efa9/attachment-0001.html>
