LIBBSD TCPDUMP
Sat Jul 1 17:29:32 UTC 2017
On Sat, Jul 1, 2017 at 11:49 AM, Kirspel, Kevin <Kevin-Kirspel at idexx.com> wrote:
> This is how I fixed it.  I did similar things for EXTRACT_32BITS and
> EXTRACT_64BITS.
> static inline u_int16_t
> EXTRACT_16BITS(const void *p)
> #if defined(__arm__) && defined(__rtems__)
>                 if(((uint32_t)p % 2) != 0) {
>                                 u_int16_t value;
>                                 u_int8_t *ptr = (u_int8_t *)&value;
>                                 ptr[0] = ((const u_int8_t *)p)[0];
>                                 ptr[1] = ((const u_int8_t *)p)[1];
>                                 p = &value;
Is it correct to assign a pointer to a block-scoped variable here? It
looks suspect to me. I'd at least put the declaration of 'value'
before the block here.
> #endif /* __rtems__ */
>                 return ((u_int16_t)ntohs(*(const u_int16_t *)(p)));
> Kevin Kirspel
> Electrical Engineer - Sr. Staff
> Idexx Roswell
> 235 Hembree Park Drive
> Roswell GA 30076
> Tel: (770)-510-4444 ext. 81642
> Direct: (770)-688-1642
> Fax: (770)-510-4445
> From: Joel Sherrill [mailto:joel at rtems.org]
> Sent: Saturday, July 01, 2017 11:39 AM
> To: Gedare Bloom <gedare at rtems.org>
> Cc: rtems-devel at rtems.org <devel at rtems.org>; Kirspel, Kevin
> Subject: Re: LIBBSD TCPDUMP
> On Jul 1, 2017 10:34 AM, "Gedare Bloom" <gedare at rtems.org> wrote:
> On Sat, Jul 1, 2017 at 10:01 AM, Kirspel, Kevin <Kevin-Kirspel at idexx.com>
> wrote:
>> I get a crash when running the tcpdump command in LIBBSD.  It is due to
>> the
>> following structure
>> struct stp_bpdu_ {
>>     u_int8_t protocol_id[2];
>>     u_int8_t protocol_version;
>>     u_int8_t bpdu_type;
>>     u_int8_t flags;
>>     u_int8_t root_id[8];
>>     u_int8_t root_path_cost[4];
>>    u_int8_t bridge_id[8];
>>     u_int8_t port_id[2];
>>     u_int8_t message_age[2];
>>     u_int8_t max_age[2];
>>     u_int8_t hello_time[2];
>>     u_int8_t forward_delay[2];
>>     u_int8_t v1_length;
>> In the code, there is an access to the port_id field as follows:
>> EXTRACT_16BITS(&stp_bpdu->port_id).  EXTRACT_16BITS calls ntohs() .  Since
>> the address of “&stp_bpdu->port_id” is at an odd word (16 bit) boundary,
>> an
>> exception is generated.  What is the correct way to fix this?  I was going
>> to update EXTRACT_16BITS to check for an odd boundary and fix it up before
>> calling ntohs().
> That would probably be a more portable fix than allowing unaligned
> accesses. I think the alignment should be made to the CPU_ALIGNMENT
> macro.
> Can't you also just pull it out a byte at a time, form the net version and
> then ntohs()?
> That's what I coded recently in some marahalling code.
>> Kevin Kirspel
>> Idexx Roswell
>> Roswell GA 30076
>> Fax: (770)-510-4445
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
