Interrupts strange behavior on RISC-V
Denis Obrezkov
denisobrezkov at gmail.com
Sat Jul 8 17:18:15 UTC 2017
2017-07-08 18:05 GMT+02:00 Joel Sherrill <joel at rtems.org>:
> On Jul 8, 2017 10:09 AM, "Denis Obrezkov" <denisobrezkov at gmail.com> wrote:
> Hello all,
> I worked with local interrupts last few days and found some strange
> behavior:
> I am trying to handle local interrupts.
> That's what I do, in my handler for timer interrupts:
> * disable timer interrupts in mie
> * read a current value from mtime
> * copy it to mtimecmp (both are 64bit width types)
> * add some big value to mtimecmp
> * enable timer interrupts in mie.
> And I have two boards and the problem is that on one of them interrupts
> are permanently generated because mip register is always 1 in mtip
> position, though mtimecmp is greater than mtime, and are not generated at
> all on the other.
> Is there a procedure for clearing the interrupt?
Yes, it is written that external interrupts are cleared by PLIC (external
interrupt controller),
software interrupts are cleared I think by the main thread (I didn't find
it in docs), and timer
interrupts are cleared by writing the value in mtimecmp memory-mapped
register greater
than in mtime (memory mapped register too.) [2, p.28]
> In this piece of code, I turn on interrupts:
> la t0, RISCV_Exception_default
> csrs mtvec, t0
> li t0, 0x88
> csrs mie, t0
> csrsi mstatus, 0x8
> Can you point us to the documentation and section where this timer
> behavior is defined? Sometimes having someone else read it can provide a
> different interpretation.
> And is there other code like Linux which deals with this timer? There may
> be a magic sequence you are missing
I wasn't able to find a magic sequence and didn't look at Linux code, but I
initialized it like in hifive1 example provided with FreedomStudio (IDE for
HiFive1).:
https://github.com/sifive/freedom-e-sdk/tree/master/bsp
But these are the docs:
Description of mstatus register, which contains mie field for global
interrupt enabling (Ch 3.1.6):
[1] https://riscv.org/specifications/privileged-isa/
Description of the core, on which SoC is based (Ch 6 is about interrupts):
[2] https://www.sifive.com/documentation/coreplex/e31-coreplex-manual/
There are also description of the SoC:
https://www.sifive.com/documentation/freedom-soc/freedom-e300-platform-reference-manual/
and description of the chip:
https://www.sifive.com/documentation/chips/freedom-e310-g000-manual/
Regards, Denis Obrezkov
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170708/4d024780/attachment.html>
