[PATCH 6/7] Add interrupt server move
Tue Jul 11 13:41:14 UTC 2017
 c/src/lib/libbsp/shared/src/irq-server.c | 75 ++++++++++++++++++++++++++++++++
 cpukit/include/rtems/irq-extension.h     | 26 +++++++++++
 2 files changed, 101 insertions(+)
diff --git a/c/src/lib/libbsp/shared/src/irq-server.c b/c/src/lib/libbsp/shared/src/irq-server.c
index 61d31754c2..a7b277c62c 100644
--- a/c/src/lib/libbsp/shared/src/irq-server.c
+++ b/c/src/lib/libbsp/shared/src/irq-server.c
@@ -694,6 +694,81 @@ rtems_status_code rtems_interrupt_server_request_initialize(
   return RTEMS_SUCCESSFUL;
+static void bsp_interrupt_server_handler_move_helper(void *arg)
+  bsp_interrupt_server_helper_data *hd = arg;
+  bsp_interrupt_server_handler_iterate_helper_data *hihd = hd->arg;
+  rtems_interrupt_server_entry *e;
+  rtems_option trigger_options;
+  bsp_interrupt_lock();
+  e = bsp_interrupt_server_query_entry(hd->vector, &trigger_options);
+  if (e != NULL) {
+    rtems_interrupt_lock_context lock_context;
+    bsp_interrupt_server_context *src = e->server;
+    bsp_interrupt_server_context *dst = hihd->arg;
+    bool pending;
+    rtems_interrupt_lock_acquire(&src->lock, &lock_context);
+    pending = !rtems_chain_is_node_off_chain(&e->node);
+    if (pending) {
+      rtems_chain_extract_unprotected(&e->node);
+      rtems_chain_set_off_chain(&e->node);
+    rtems_interrupt_lock_release(&src->lock, &lock_context);
+    e->server = dst;
+    if (pending) {
+      bsp_interrupt_server_trigger(e);
+  bsp_interrupt_unlock();
+  rtems_event_transient_send(hd->task);
+rtems_status_code rtems_interrupt_server_move(
+  uint32_t source_server_index,
+  rtems_vector_number vector,
+  uint32_t destination_server_index
+  rtems_status_code sc;
+  bsp_interrupt_server_context *src;
+  bsp_interrupt_server_context *dst;
+  bsp_interrupt_server_handler_iterate_helper_data hihd;
+  src = bsp_interrupt_server_get_context(source_server_index, &sc);
+  if (src == NULL) {
+    return sc;
+  dst = bsp_interrupt_server_get_context(destination_server_index, &sc);
+  if (dst == NULL) {
+    return sc;
+  if (!bsp_interrupt_is_valid_vector(vector)) {
+    return RTEMS_INVALID_ID;
+  hihd.arg = dst;
+  bsp_interrupt_server_call_helper(
+    src,
+    vector,
+    0,
+    NULL,
+    &hihd,
+    bsp_interrupt_server_handler_move_helper
+  return RTEMS_SUCCESSFUL;
 static void bsp_interrupt_server_entry_suspend_helper(void *arg)
diff --git a/cpukit/include/rtems/irq-extension.h b/cpukit/include/rtems/irq-extension.h
index 9cade113ad..e3fb4c5fea 100644
--- a/cpukit/include/rtems/irq-extension.h
+++ b/cpukit/include/rtems/irq-extension.h
@@ -362,6 +362,32 @@ rtems_status_code rtems_interrupt_server_handler_iterate(
+ * @brief Moves the interrupt handlers installed on the specified source
+ * interrupt server to the destination interrupt server.
+ * This function must be called from thread context.  It may block.  Calling
+ * this function within the context of an interrupt server is undefined
+ * behaviour.
+ * @param[in] source_server_index The source interrupt server index.  Use
+ *   @c RTEMS_INTERRUPT_SERVER_DEFAULT to specify the default server.
+ * @param[in] vector The interrupt vector number.
+ * @param[in] destination_server_index The destination interrupt server index.
+ *   Use @c RTEMS_INTERRUPT_SERVER_DEFAULT to specify the default server.
+ * @retval RTEMS_SUCCESSFUL Successful operation
+ * @retval RTEMS_INCORRECT_STATE The interrupt servers are not initialized.
+ * @retval RTEMS_INVALID_ID The destination interrupt server index is invalid.
+ * @retval RTEMS_INVALID_ID The vector number is invalid.
  * @brief Suspends the specified interrupt server.
  * A suspend request is sent to the specified interrupt server.  This function
2.12.3
