HiFive1 BSP current state
Thu Jul 20 09:48:58 UTC 2017
On 20/07/17 11:34, Denis Obrezkov wrote:
> 2017-07-18 14:10 GMT+02:00 Joel Sherrill <joel.sherrill at gmail.com
> <mailto:joel.sherrill at gmail.com>>:
>     I am not near a computer to check but is there a section in the
>     Configuring a System chapter with a low memory example? I know the
>     individual options are documented but an example configuration
>     with the safer ones to use might help users.
> Could you point me to the documentation with the Configuration a
> System chapter?
For real low memory systems we need self-contained objects and a static
initialization.
https://lists.rtems.org/pipermail/devel/2017-February/016874.html
For threads we can use something like this:
struct my_thread {
   Thread_Control thread;
   char space_for_thread_control_addons_and_tls_and_stack[N];
} a;
SYSINIT_THREAD(&a, sizeof(a));
If sizeof(a) is too small, then issue a fatal error.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
