libbsd include path issue
Sun Jul 23 12:04:26 UTC 2017
On Sun, Jul 23, 2017 at 7:49 AM, Gedare Bloom <gedare at rtems.org> wrote:
> On Sat, Jul 22, 2017 at 1:30 PM, Christian Mauderer <list at c-mauderer.de> wrote:
>> Hello Sichen,
>> as discussed in our private chat I'm quite convinced that your problem
>> is that the source file is in "freebsd/crypto/openssl/crypto" which
>> doesn't end on a path called "openssl".
>> As far as I can see, there is currently no support in our build system
>> for such cases. I created a (still quite uggly) hack that tries to copy
>> the headers to a path in the build tree. Could you please try out the
>> (mostly untested) attached patch? You should be able to specify
>> headerPaths() lines in builder.py which have different endings than the
>> original source paths.
> No patch attached
Nevermind I see it.
>> To our waf experts: Please tell me, that there is a better solution. If
>> not, it would be good if you could give me some feedback for a better
>> and cleaner solution. And: I currently only tried half a build. Do you
>> see any problems on any platforms on build or install with that
>> solution?
> You should be able to specify the 'includes' attribute of the build
> rule to point it to the right directory wherever the parent of openssl
> is.
> But really, this openssl/opensslv.h should be located already in an
> include/ directory that would be found?
Can you add crypto/openssl/ to includes?
>> Kind regards
>> Christian
>> devel mailing list
>> devel at rtems.org
