libbsd include path issue
Sun Jul 23 12:05:15 UTC 2017
On Sun, Jul 23, 2017 at 8:04 AM, Gedare Bloom <gedare at rtems.org> wrote:
> On Sun, Jul 23, 2017 at 7:49 AM, Gedare Bloom <gedare at rtems.org> wrote:
>> On Sat, Jul 22, 2017 at 1:30 PM, Christian Mauderer <list at c-mauderer.de> wrote:
>>> Hello Sichen,
>>> as discussed in our private chat I'm quite convinced that your problem
>>> is that the source file is in "freebsd/crypto/openssl/crypto" which
>>> doesn't end on a path called "openssl".
>>> As far as I can see, there is currently no support in our build system
>>> for such cases. I created a (still quite uggly) hack that tries to copy
>>> the headers to a path in the build tree. Could you please try out the
>>> (mostly untested) attached patch? You should be able to specify
>>> headerPaths() lines in builder.py which have different endings than the
>>> original source paths.
>> No patch attached
> Nevermind I see it.
>>> To our waf experts: Please tell me, that there is a better solution. If
>>> not, it would be good if you could give me some feedback for a better
>>> and cleaner solution. And: I currently only tried half a build. Do you
>>> see any problems on any platforms on build or install with that
>>> solution?
>> You should be able to specify the 'includes' attribute of the build
>> rule to point it to the right directory wherever the parent of openssl
>> is.
>> But really, this openssl/opensslv.h should be located already in an
>> include/ directory that would be found?
> Can you add crypto/openssl/ to includes?
Rather freebsd/crypto. Then include directive should find the openssl
subdirectory.
>>> Kind regards
>>> Christian
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
