Optimization issue in RISC-V BSP
Fri Jul 28 15:31:18 UTC 2017
On Fri, Jul 28, 2017 at 11:05 AM, Joel Sherrill <joel at rtems.org> wrote:
> On Fri, Jul 28, 2017 at 9:23 AM, Denis Obrezkov <denisobrezkov at gmail.com>
> wrote:
>> 2017-07-28 15:19 GMT+02:00 Sebastian Huber
>> <sebastian.huber at embedded-brains.de>:
>>> On 28/07/17 15:15, Denis Obrezkov wrote:
>>>> 2017-07-28 14:56 GMT+02:00 Joel Sherrill <joel at rtems.org
>>>> <mailto:joel at rtems.org>>:
>>>>     There is a debug option near the bottom of confdefs.h which you
>>>>     can enable to generate a data structure filled in with various
>>>>     values computed by confdefs. You can look at that in gdb without
>>>>     loading it on the target.
>>>>     It is probably worth it to look at that now and see what you spot.
>>>> Okay, I'll try.
>>>>     And a random thought.. what's the interrupt stack size and how is
>>>>     it allocated? What are the port specific related macros set to?
>>>> I don't completely understand what is the interrupt stack. Because, when
>>>> an interrupt occurs,
>>>> I save all registers and move the stack pointer, handle interrupt,
>>> Now you handle the interrupt on the stack of the interrupted context
>>> (usually a thread). So, you must take this overhead into account for every
>>> thread. If you switch to an interrupt stack, then you only have to account
>>> for one interrupt frame per thread. If you support nested interrupts, you
>>> need even more space per thread without an interrupt stack.
>> Am I understand right that RTEMS has a wrapper for interrupt handlers that
>> creates a dedicated 'interrupt handler' task?
>> I think it is not, since we call ISR directly from assembler code, thus
>> should we save registers in a dedicated interrupt stack
>> by ourselves in the ISR?
> There can be interrupt server threads but that is a distinct topic.
> Interrupts have to execute on a stack. As Gedare said, you are currently
> processing each
> ISR on the stack of the thread that was interrupted. Most of the other ports
> have a dedicated
> interrupt stack and switch to it.
Well, it was Sebastian who pointed this out, but yes the interrupt
stack should be used to avoid task stack size inflation.
> There is a worst case stack usage for each thread and the interrupts.
> Without a dedicated
> interrupt stack, each task must account for its worst usage and the worst
> case interrupt
> when allocating its stack.
>> Also, I don't understand what do you mean by: " you only have to account
>> for one interrupt frame per thread".
>> And what is an 'interrupt frame'? I have found something in a relatively
>> old guide:
>> https://docs.rtems.org/releases/rtemsdocs-4.9.6/share/rtems/html/porting/porting00033.html
>> but it doesn't make it clear.
> An interrupt frame is the set of data that must be saved for each interrupt
> occurrence. The
> "only have to save one" is because you can switch to a dedicated stack where
> interrupts
> are processed and possibly nested. Thus you have the usage for the
> processing and
> possible nested interrupts.
> But you need to figure out why the memory allocated changed. Optimization
> level should be
> independent of that.
I find it quite likely that the use of optimization is allowing the
program to execute correctly further. The next step is to shrink and
optimize the use of memory and manage the (linker) memory map
carefully.
>> Regards, Denis Obrezkov
> devel mailing list
> devel at rtems.org
