Optimization issue in RISC-V BSP
Denis Obrezkov
denisobrezkov at gmail.com
Fri Jul 28 15:31:45 UTC 2017
2017-07-28 17:05 GMT+02:00 Joel Sherrill <joel at rtems.org>:
> On Fri, Jul 28, 2017 at 9:23 AM, Denis Obrezkov <denisobrezkov at gmail.com>
> wrote:
>> 2017-07-28 15:19 GMT+02:00 Sebastian Huber <sebastian.huber at embedded-brai
>> ns.de>:
>>> On 28/07/17 15:15, Denis Obrezkov wrote:
>>> 2017-07-28 14:56 GMT+02:00 Joel Sherrill <joel at rtems.org <mailto:
>>>> joel at rtems.org>>:
>>>> There is a debug option near the bottom of confdefs.h which you
>>>> can enable to generate a data structure filled in with various
>>>> values computed by confdefs. You can look at that in gdb without
>>>> loading it on the target.
>>>> It is probably worth it to look at that now and see what you spot.
>>>> Okay, I'll try.
>>>> And a random thought.. what's the interrupt stack size and how is
>>>> it allocated? What are the port specific related macros set to?
>>>> I don't completely understand what is the interrupt stack. Because,
>>>> when an interrupt occurs,
>>>> I save all registers and move the stack pointer, handle interrupt,
>>> Now you handle the interrupt on the stack of the interrupted context
>>> (usually a thread). So, you must take this overhead into account for every
>>> thread. If you switch to an interrupt stack, then you only have to account
>>> for one interrupt frame per thread. If you support nested interrupts, you
>>> need even more space per thread without an interrupt stack.
>> Am I understand right that RTEMS has a wrapper for interrupt handlers
>> that creates a dedicated 'interrupt handler' task?
>> I think it is not, since we call ISR directly from assembler code, thus
>> should we save registers in a dedicated interrupt stack
>> by ourselves in the ISR?
> There can be interrupt server threads but that is a distinct topic.
> Interrupts have to execute on a stack. As Gedare said, you are currently
> processing each
> ISR on the stack of the thread that was interrupted. Most of the other
> ports have a dedicated
> interrupt stack and switch to it.
> There is a worst case stack usage for each thread and the interrupts.
> Without a dedicated
> interrupt stack, each task must account for its worst usage and the worst
> case interrupt
> when allocating its stack.
>> Also, I don't understand what do you mean by: " you only have to account
>> for one interrupt frame per thread".
>> And what is an 'interrupt frame'? I have found something in a relatively
>> old guide:
>> https://docs.rtems.org/releases/rtemsdocs-4.9.6/share/rtems/
>> html/porting/porting00033.html
>> but it doesn't make it clear.
> An interrupt frame is the set of data that must be saved for each
> interrupt occurrence. The
> "only have to save one" is because you can switch to a dedicated stack
> where interrupts
> are processed and possibly nested. Thus you have the usage for the
> processing and
> possible nested interrupts.
> But you need to figure out why the memory allocated changed. Optimization
> level should be
> independent of that.
>> Regards, Denis Obrezkov
I can see that during task initialization I have a call:
_Thread_Initialize_information (information=information at entry=0x80000ad4
<_RTEMS_tasks_Information>, the_api=the_api at entry=OBJECTS_CLASSIC_API,
the_class=the_class at entry=1, maximum=124,
is_string=is_string at entry=false,
maximum_name_length=maximum_name_length at entry=4)
And maximum is 124, but I have a configuration parameter:
#define CONFIGURE_MAXIMUM_TASKS 4
It seems that other tasks are LIBBLOCK tasks.
Also, this is my Configuration during run:
(gdb) p Configuration.stack_space_size
$1 = 2648
(gdb) p Configuration.work_space_size
$2 = 4216
(gdb) p Configuration.interrupt_stack_size
$3 = 512
(gdb) p Configuration.idle_task_stack_size
$4 = 512
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170728/59672bc6/attachment.html>
