Optimization issue in RISC-V BSP
Joel Sherrill
joel at rtems.org
Fri Jul 28 22:57:42 UTC 2017
On Jul 28, 2017 5:55 PM, "Denis Obrezkov" <denisobrezkov at gmail.com> wrote:
2017-07-28 22:36 GMT+02:00 Joel Sherrill <joel at rtems.org>:
> Can you check the memory immediately after a download'?
> Then after the loop that copies initialized data into place?
> I suspect something off there. Could be a linker script issue or the
> copy gone crazy.
> --joel
> On Fri, Jul 28, 2017 at 3:20 PM, Denis Obrezkov <denisobrezkov at gmail.com>
> wrote:
>> 2017-07-28 22:16 GMT+02:00 Joel Sherrill <joel at rtems.org>:
>>> On Fri, Jul 28, 2017 at 2:50 PM, Denis Obrezkov <denisobrezkov at gmail.com
>>> > wrote:
>>>>>> I can see that during task initialization I have a call:
>>>>>> _Thread_Initialize_information (information=information at entry=0x80000ad4
>>>>>> <_RTEMS_tasks_Information>, the_api=the_api at entry=OBJECTS_CLASSIC_API,
>>>>>> the_class=the_class at entry=1, maximum=124,
>>>>>> is_string=is_string at entry=false, maximum_name_length=maximum_na
>>>>>> me_length at entry=4)
>>>>>> And maximum is 124, but I have a configuration parameter:
>>>>>> #define CONFIGURE_MAXIMUM_TASKS 4
>>>>> I can't imagine any standard RTEMS test configuring that many tasks.
>>>>> Is there a data corruption issue?
>>>>> 124 = 0x7c which doesn't ring any bells for me on odd memory issues.
>>>>> What is the contents of "Configuration_RTEMS_API"?
>>>> Oh, I change my configuration options a bit, they are:
>>>> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>>>> #define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
>>>> #define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
>>>> #define CONFIGURE_TERMIOS_DISABLED
>>>> #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 0
>>>> #define CONFIGURE_MINIMUM_TASK_STACK_SIZE 512
>>>> #define CONFIGURE_MAXIMUM_PRIORITY 3
>>>> #define CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS
>>>> #define CONFIGURE_IDLE_TASK_BODY Init
>>>> #define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
>>>> #define CONFIGURE_TASKS 4
>>>> #define CONFIGURE_UNIFIED_WORK_AREAS
>>>> Also it is the test from a lower ticker example.
>>>> Configuration_RTEMS_API with -O0 option:
>>>> {maximum_tasks = 5, maximum_timers = 0, maximum_semaphores = 7,
>>>> maximum_message_queues = 0, maximum_partitions = 0, maximum_regions = 0,
>>>> maximum_ports = 0, maximum_periods = 0,
>>>> maximum_barriers = 0, number_of_initialization_tasks = 0,
>>>> User_initialization_tasks_table = 0x0}
>>>> with -Os option:
>>>> {maximum_tasks = 124, maximum_timers = 0, maximum_semaphores = 7,
>>> Hmmm.. If you look at this structure in gdb without attaching to the
>>> target, what
>>> is maximum_tasks?
>>> --joel
>>>>>> It seems that other tasks are LIBBLOCK tasks.
>>>>>> Also, this is my Configuration during run:
>>>>>> (gdb) p Configuration.stack_space_size
>>>>>> $1 = 2648
>>>>>> (gdb) p Configuration.work_space_size
>>>>>> $2 = 4216
>>>>>> (gdb) p Configuration.interrupt_stack_size
>>>>>> $3 = 512
>>>>>> (gdb) p Configuration.idle_task_stack_size
>>>>>> $4 = 512
>>>>> That looks reasonable. Add CONFIGURE_MAXIMUM_PRIORITY and set it to 4.
>>>>> That should
>>>>> reduce the workspace.
>>>>> long term, we might want to consider lowering it permanently like one
>>>>> of the Coldfires
>>>>> had to. Or change the default scheduler to the Simple one to save
>>>>> memory.
>>>> I haven't dealt with the Scheduler option yet.
>>>> Regards, Denis Obrezkov
>>> maximum_tasks = 4
>> So, is it a linker file issue?
>> This is it:
>> https://github.com/embeddedden/rtems-riscv/blob/hifive1/c/sr
>> c/lib/libbsp/riscv32/hifive1/startup/linkcmds
> After download:
{maximum_tasks = 938162044, maximum_timers = 1270834941, maximum_semaphores
= 2534801264 <(253)%20480-1264>, maximum_message_queues = 425684620,
maximum_partitions = 1496738036,
maximum_regions = 3085560870 <(308)%20556-0870>, maximum_ports =
4269782132, maximum_periods = 2362012542 <(236)%20201-2542>,
maximum_barriers = 1138223297, number_of_initialization_tasks = 4224313421,
User_initialization_tasks_table = 0x43bd1bd3}
right after data copying:
{maximum_tasks = 124, maximum_timers = 0, maximum_semaphores = 1,
But I found the mistake - I made it in .data initialization code
(https://github.com/embeddedden/rtems-riscv/blob/hifive1/c/src/lib/libbsp/
riscv32/hifive1/start/start.S#L116 - first byte in the loop was
uninitialized)
Awesome! Does that mean it is running?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170728/3c870c7e/attachment-0001.html>
