Optimization issue in RISC-V BSP
Denis Obrezkov
denisobrezkov at gmail.com
Fri Jul 28 23:14:16 UTC 2017
2017-07-29 0:57 GMT+02:00 Joel Sherrill <joel at rtems.org>:
> On Jul 28, 2017 5:55 PM, "Denis Obrezkov" <denisobrezkov at gmail.com> wrote:
> 2017-07-28 22:36 GMT+02:00 Joel Sherrill <joel at rtems.org>:
>> Can you check the memory immediately after a download'?
>> Then after the loop that copies initialized data into place?
>> I suspect something off there. Could be a linker script issue or the
>> copy gone crazy.
>> --joel
>> On Fri, Jul 28, 2017 at 3:20 PM, Denis Obrezkov <denisobrezkov at gmail.com>
>> wrote:
>>> 2017-07-28 22:16 GMT+02:00 Joel Sherrill <joel at rtems.org>:
>>>> On Fri, Jul 28, 2017 at 2:50 PM, Denis Obrezkov <
>>>>>>> I can see that during task initialization I have a call:
>>>>>>> _Thread_Initialize_information (information=information at entry=0x80000ad4
>>>>>>> <_RTEMS_tasks_Information>, the_api=the_api at entry=OBJECTS_CLASSIC_API,
>>>>>>> the_class=the_class at entry=1, maximum=124,
>>>>>>> is_string=is_string at entry=false, maximum_name_length=maximum_na
>>>>>>> me_length at entry=4)
>>>>>>> And maximum is 124, but I have a configuration parameter:
>>>>>>> #define CONFIGURE_MAXIMUM_TASKS 4
>>>>>> I can't imagine any standard RTEMS test configuring that many tasks.
>>>>>> Is there a data corruption issue?
>>>>>> 124 = 0x7c which doesn't ring any bells for me on odd memory issues.
>>>>>> What is the contents of "Configuration_RTEMS_API"?
>>>>> Oh, I change my configuration options a bit, they are:
>>>>> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>>>>> #define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
>>>>> #define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
>>>>> #define CONFIGURE_TERMIOS_DISABLED
>>>>> #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 0
>>>>> #define CONFIGURE_MINIMUM_TASK_STACK_SIZE 512
>>>>> #define CONFIGURE_MAXIMUM_PRIORITY 3
>>>>> #define CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS
>>>>> #define CONFIGURE_IDLE_TASK_BODY Init
>>>>> #define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
>>>>> #define CONFIGURE_TASKS 4
>>>>> #define CONFIGURE_UNIFIED_WORK_AREAS
>>>>> Also it is the test from a lower ticker example.
>>>>> Configuration_RTEMS_API with -O0 option:
>>>>> {maximum_tasks = 5, maximum_timers = 0, maximum_semaphores = 7,
>>>>> maximum_message_queues = 0, maximum_partitions = 0, maximum_regions = 0,
>>>>> maximum_ports = 0, maximum_periods = 0,
>>>>> maximum_barriers = 0, number_of_initialization_tasks = 0,
>>>>> User_initialization_tasks_table = 0x0}
>>>>> with -Os option:
>>>>> {maximum_tasks = 124, maximum_timers = 0, maximum_semaphores = 7,
>>>> Hmmm.. If you look at this structure in gdb without attaching to the
>>>> target, what
>>>> is maximum_tasks?
>>>> --joel
>>>>>>> It seems that other tasks are LIBBLOCK tasks.
>>>>>>> Also, this is my Configuration during run:
>>>>>>> (gdb) p Configuration.stack_space_size
>>>>>>> $1 = 2648
>>>>>>> (gdb) p Configuration.work_space_size
>>>>>>> $2 = 4216
>>>>>>> (gdb) p Configuration.interrupt_stack_size
>>>>>>> $3 = 512
>>>>>>> (gdb) p Configuration.idle_task_stack_size
>>>>>>> $4 = 512
>>>>>> That looks reasonable. Add CONFIGURE_MAXIMUM_PRIORITY and set it to
>>>>>> 4. That should
>>>>>> reduce the workspace.
>>>>>> long term, we might want to consider lowering it permanently like
>>>>>> one of the Coldfires
>>>>>> had to. Or change the default scheduler to the Simple one to save
>>>>>> memory.
>>>>> I haven't dealt with the Scheduler option yet.
>>>>> Regards, Denis Obrezkov
>>>> maximum_tasks = 4
>>> So, is it a linker file issue?
>>> This is it:
>>> https://github.com/embeddedden/rtems-riscv/blob/hifive1/c/sr
>>> c/lib/libbsp/riscv32/hifive1/startup/linkcmds
>> After download:
> {maximum_tasks = 938162044, maximum_timers = 1270834941,
> maximum_semaphores = 2534801264 <(253)%20480-1264>,
> maximum_message_queues = 425684620, maximum_partitions = 1496738036,
> maximum_regions = 3085560870 <(308)%20556-0870>, maximum_ports =
> 4269782132, maximum_periods = 2362012542 <(236)%20201-2542>,
> maximum_barriers = 1138223297, number_of_initialization_tasks = 4224313421,
> User_initialization_tasks_table = 0x43bd1bd3}
> right after data copying:
> {maximum_tasks = 124, maximum_timers = 0, maximum_semaphores = 1,
> But I found the mistake - I made it in .data initialization code
> (https://github.com/embeddedden/rtems-riscv/blob/hifive1/c/
> src/lib/libbsp/riscv32/hifive1/start/start.S#L116 - first byte in the
> loop was uninitialized)
> Awesome! Does that mean it is running?
> Yes, it is running now. Not far, but running.
Now I am having an exception during atexit( Clock_exit )
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170729/afcfaf2c/attachment.html>
