Optimization issue in RISC-V BSP
Denis Obrezkov
denisobrezkov at gmail.com
Fri Jul 28 13:15:33 UTC 2017
2017-07-28 14:56 GMT+02:00 Joel Sherrill <joel at rtems.org>:
> There is a debug option near the bottom of confdefs.h which you can enable
> to generate a data structure filled in with various values computed by
> confdefs. You can look at that in gdb without loading it on the target.
> It is probably worth it to look at that now and see what you spot.
Okay, I'll try.
> And a random thought.. what's the interrupt stack size and how is it
> allocated? What are the port specific related macros set to?
> I don't completely understand what is the interrupt stack. Because, when
an interrupt occurs,
I save all registers and move the stack pointer, handle interrupt, restore
registers and move stack
pointer back.
Regards, Denis Obrezkov
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170728/cdd4cc57/attachment-0002.html>
