RISC-V interrupts
    Hesham Almatary
    heshamelmatary at gmail.com
    Tue Jun  6 16:58:28 UTC 2017
Hi Denis,
In riscv_generic, only context switching is supported. It was supposed
to only run hello world (console) and ticker (tickless timer), both
don't need interrupts. I assume you can do the same for HiFive1, which
is the simplest. Then we can discuss about the timer and interrupt
implementations.
Originally RTEMS had a one big linkcmd for each platform, which
defines linker symbols (used in C code) and required sections. This
has been improved with current BSPs (like ARM-based ones), by
splitting up shared linkcmd parts (linkcmd base) and BSP specific ones
that include the shared one. riscv_generic, given that it's old,
follows the old way of having a single big linkcmd. You can change
this for your new BSP.
Cheers,
Hesham
On Tue, Jun 6, 2017 at 11:55 PM, Denis Obrezkov <denisobrezkov at gmail.com> wrote:
> Hello Hesham,
> I am trying to figure out, what should be done in order to run the simplest
> BSP on HiFive1 boards. So, I have some questions:
> What is already done in risc-v generic - clocks, interrupts handling,
> context
> switching?
> How local and global interrupts relate to each other? How should the be
> implemented in RTEMS?
> Why RTEMS' linkcmd for riscv-generic so big?
> Regards, Denis Obrezkov
Hesham
