RISC-V interrupts
    Sebastian Huber
    Wed Jun  7 11:44:05 UTC 2017
On 06/06/17 18:58, Hesham Almatary wrote:
> Originally RTEMS had a one big linkcmd for each platform, which
> defines linker symbols (used in C code) and required sections. This
> has been improved with current BSPs (like ARM-based ones), by
> splitting up shared linkcmd parts (linkcmd base) and BSP specific ones
> that include the shared one. riscv_generic, given that it's old,
> follows the old way of having a single big linkcmd. You can change
> this for your new BSP.
New ports/BSPs should definitely use a shared linkcmds.base (see ARM).
Use "riscv-rtems4.12-ld --verbose" to get the default linker script.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
