RISC-V interrupts
Hesham Almatary heshamelmatary at gmail.com
Wed Jun 7 19:41:30 UTC 2017
On Thu, Jun 8, 2017 at 2:26 AM, Denis Obrezkov <denisobrezkov at gmail.com> wrote:
> 2017-06-07 14:44 GMT+03:00 Sebastian Huber
> <sebastian.huber at embedded-brains.de>:
>> On 06/06/17 18:58, Hesham Almatary wrote:
>>> Originally RTEMS had a one big linkcmd for each platform, which
>>> defines linker symbols (used in C code) and required sections. This
>>> has been improved with current BSPs (like ARM-based ones), by
>>> splitting up shared linkcmd parts (linkcmd base) and BSP specific ones
>>> that include the shared one. riscv_generic, given that it's old,
>>> follows the old way of having a single big linkcmd. You can change
>>> this for your new BSP.
>> New ports/BSPs should definitely use a shared linkcmds.base (see ARM). Use
>> "riscv-rtems4.12-ld --verbose" to get the default linker script.
> Ok.
> Now I have a problem:
> https://github.com/embeddedden/rtems-riscv/blob/hifive1/c/src/lib/libbsp/riscv32/hifive1/start/start.S#L117
> When I step to that line, gdb hangs with a message:
> (gdb) step
> Note: automatically using hardware breakpoints for read-only addresses.
How do you run/attach simulator (and which one do you use)? Do GDB and
the simulator support 0x20400000 > addresses (where your text section
is loaded to)? AFAIK, that's not the case. Spike's default machine
only works with addresses >= 0x80000000. You've to look up if Spike,
Qemu [1] or GDB target sim model your board.
[1] https://github.com/riscv/riscv-qemu
> Does somebody know what can be done here?
> Also, I don't like my initial linker file:
> https://github.com/embeddedden/rtems-riscv/blob/hifive1/c/src/lib/libbsp/riscv32/hifive1/startup/linkcmds
> Critique is very appreciated.
> Regards, Denis Obrezkov
Hesham
