RISC-V interrupts
Denis Obrezkov
denisobrezkov at gmail.com
Thu Jun 8 09:24:51 UTC 2017
2017-06-07 22:41 GMT+03:00 Hesham Almatary <heshamelmatary at gmail.com>:
> On Thu, Jun 8, 2017 at 2:26 AM, Denis Obrezkov <denisobrezkov at gmail.com>
> wrote:
> > 2017-06-07 14:44 GMT+03:00 Sebastian Huber
> > <sebastian.huber at embedded-brains.de>:
> >> On 06/06/17 18:58, Hesham Almatary wrote:
> >>> Originally RTEMS had a one big linkcmd for each platform, which
> >>> defines linker symbols (used in C code) and required sections. This
> >>> has been improved with current BSPs (like ARM-based ones), by
> >>> splitting up shared linkcmd parts (linkcmd base) and BSP specific ones
> >>> that include the shared one. riscv_generic, given that it's old,
> >>> follows the old way of having a single big linkcmd. You can change
> >>> this for your new BSP.
> >> New ports/BSPs should definitely use a shared linkcmds.base (see ARM).
> Use
> >> "riscv-rtems4.12-ld --verbose" to get the default linker script.
> > Ok.
> > Now I have a problem:
> > https://github.com/embeddedden/rtems-riscv/blob/
> hifive1/c/src/lib/libbsp/riscv32/hifive1/start/start.S#L117
> > When I step to that line, gdb hangs with a message:
> > (gdb) step
> > Note: automatically using hardware breakpoints for read-only addresses.
> How do you run/attach simulator (and which one do you use)? Do GDB and
> the simulator support 0x20400000 > addresses (where your text section
> is loaded to)? AFAIK, that's not the case. Spike's default machine
> only works with addresses >= 0x80000000. You've to look up if Spike,
> Qemu [1] or GDB target sim model your board.
I will investigate this.
Could you also explain you .stack section in linkcmd file?
is it on purpose always of zero size (.work section consumes all remaining
memory)?
Regards, Denis Obrezkov
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170608/c59d0d26/attachment.html>
