[PATCH] shell: Display scheduler instead of current CPU
Sebastian Huber
Wed Jun 14 13:15:09 UTC 2017
Display the scheduler name instead of the current CPU in the "task"
shell command. The current CPU could be misleading in case locking
protocols are involved. The "cpuuse" command can be used to obtain the
current CPU.
cpukit/libmisc/monitor/mon-task.c | 26 +++++++++++++++++---------
cpukit/libmisc/monitor/monitor.h | 4 ++--
2 files changed, 19 insertions(+), 11 deletions(-)
diff --git a/cpukit/libmisc/monitor/mon-task.c b/cpukit/libmisc/monitor/mon-task.c
index a4d7d24bab..dbbebf545d 100644
--- a/cpukit/libmisc/monitor/mon-task.c
+++ b/cpukit/libmisc/monitor/mon-task.c
@@ -76,6 +76,7 @@ rtems_monitor_task_canonical(
Thread_Control *rtems_thread;
RTEMS_API_Control *api;
+ Objects_Name name;
rtems_thread =
RTEMS_DECONST( Thread_Control *, (const Thread_Control *) thread_void );
@@ -95,13 +96,20 @@ rtems_monitor_task_canonical(
sizeof( canonical_task->long_name )
+ name.name_u32 = _Thread_Scheduler_get_home( rtems_thread )->name;
+ _Objects_Name_to_string(
+ name,
+ false,
+ canonical_task->scheduler_name,
+ sizeof( canonical_task->scheduler_name )
rtems_monitor_task_wait_info( canonical_task, rtems_thread );
canonical_task->state = rtems_thread->current_state;
canonical_task->entry = rtems_thread->Start.Entry;
canonical_task->stack = rtems_thread->Start.Initial_stack.area;
canonical_task->stack_size = rtems_thread->Start.Initial_stack.size;
- canonical_task->cpu = _Per_CPU_Get_index( _Thread_Get_CPU( rtems_thread ) );
canonical_task->priority = _Thread_Get_priority( rtems_thread );
canonical_task->events = api->Event.pending_events;
@@ -127,8 +135,8 @@ rtems_monitor_task_dump_header(
fprintf(stdout,"\
-ID NAME CPU PRI STATE MODES EVENTS WAITINFO\n"); /*
-0a010004 SHLL 0 100 READY P:T:nA NONE 00000000 */
+ID NAME SHED PRI STATE MODES EVENTS WAITINFO\n"); /*
+0a010004 SHLL UPD 100 READY P:T:nA NONE 00000000 */
rtems_monitor_separator();
@@ -159,16 +167,16 @@ rtems_monitor_task_dump(
length += rtems_monitor_pad(30, length);
- length += fprintf(stdout, "%3" PRId32, monitor_task->cpu);
- length += rtems_monitor_pad(34, length);
+ length += fprintf(stdout, "%s", monitor_task->scheduler_name);
+ length += rtems_monitor_pad(35, length);
length += rtems_monitor_dump_priority(monitor_task->priority);
- length += rtems_monitor_pad(38, length);
+ length += rtems_monitor_pad(39, length);
length += rtems_monitor_dump_state(monitor_task->state);
- length += rtems_monitor_pad(45, length);
+ length += rtems_monitor_pad(46, length);
length += rtems_monitor_dump_modes(monitor_task->modes);
- length += rtems_monitor_pad(52, length);
+ length += rtems_monitor_pad(53, length);
length += rtems_monitor_dump_events(monitor_task->events);
- length += rtems_monitor_pad(61, length);
+ length += rtems_monitor_pad(62, length);
length += fprintf(stdout, "%s", monitor_task->wait);
fprintf(stdout,"\n");
diff --git a/cpukit/libmisc/monitor/monitor.h b/cpukit/libmisc/monitor/monitor.h
index ca62be6174..6ecd903c63 100644
--- a/cpukit/libmisc/monitor/monitor.h
+++ b/cpukit/libmisc/monitor/monitor.h
@@ -100,13 +100,13 @@ typedef struct {
Thread_Entry_information entry;
void *stack;
uint32_t stack_size;
- uint32_t cpu;
+ char scheduler_name[5];
rtems_task_priority priority;
States_Control state;
rtems_event_set events;
rtems_mode modes;
rtems_attribute attributes;
- char wait[18];
+ char wait[17];
uint32_t ticks;
} rtems_monitor_task_t;
2.12.3
