RSB Couverture-Qemu build queries
Fri Jun 16 20:52:20 UTC 2017
On Fri, Jun 16, 2017 at 4:38 PM, Joel Sherrill <joel at rtems.org> wrote:
> On Fri, Jun 16, 2017 at 2:13 PM, Cillian O'Donnell <cpodonnell8 at gmail.com>
> wrote:
>> Hi,
>> I am getting the RSB to build Couverture-Qemu and I just want to check
>> a few things I have done so far.
>> 1. There are about 5 patches applied to the current qemu build. Only
>> one of which applies cleanly to the Couverture build. Do you want me
>> to try and fix these up, comment them out and leave a note for
>> whoever wants to fix them or remove them completely? The patches that
>> don't work are:
>> %patch add qemu
>> pw://patchwork.ozlabs.org/patch/406903/raw/Provide-the-missing-LIBUSB_LOG_LEVEL_-for-older-libusb-or-FreeBSD.-Providing-just-the-needed-value-as-a-defined..patch
>> %patch add qemu
>> https://gaisler.org/qemu/0001-LEON3-Add-emulation-of-AMBA-plug-
>> play.patch
>> %patch add qemu
>> https://gaisler.org/qemu/0002-LEON3-Build-AMBA-plug-and-play-records-from-high-lev.patch
>> %patch add qemu
>> https://gaisler.org/qemu/0003-LEON3-Init-UART-timers-and-CPU-if-we-run-a-RAM-image.patch
> I think they need to be proposed to the Couverture project to be evaluated.
> They should
> be OK with the Gaisler ones without too much trouble. We can bring in
> Gaisler folks.
> The other is a portability one.
> So at least make the project aware of them.
> https://forge.open-do.org/projects/couverture-qemu/
> Make sure myself and chrisj@ are on any issue/email you file.
>> 2. For this source setting section, is the first part just dealing
>> with the case were this a packaged release so a tar of the download is
>> already included with it?
>> %if %{rsb_released} && %{!defined without_release_url}
>>     %source set qemu
>> %{rtems_release_url}/%{rtems_version}/sources/qemu-git-42d58e7.tar.xz
>> %else
>>     %source set qemu
>> https://github.com/AdaCore/qemu/archive/%{qemu_version}.tar.gz
>> %endif
> I think so but Chris should confirm that.
>> 3. What does the -q option do in the %prep section of the build, this
>> option shows up in examples in the docs but there is no description of
>> what it does?
>> %source setup qemu -q -n qemu-%{qemu_version}
> Chris will have to answer this.
>> 4. The current qemu build is configured with the default setting to
>> build for all architectures but most of the arch's aren't used by
>> RTEMS and/or don't have machine support for same bsps, so I've added a
>> --target-list to only build the targets that have a corresponding bsp
>> (sparc64-softmmu is missing as it runs into build issues, I forgot to
>> mention in the initial results). However the list spills over 80 lines
>> so should I make a %{qemu_targets} macro and if so where should I put
>> it?
> I like the idea of limiting the targets built. You are right that we don't
> care about the others.
sparc64-softmmu did not work for rtems the last time that I checked,
but that was a few years ago.
> The style and variable name are Chris questions.
>>  --make=%{__make} \
>>  72
>> --target-list=arm-softmmu,i386-softmmu,lm32-softmmu,mips-softmmu,ppc-softmmu,sparc-softmmu
>>  73     ${VDE_CONFIG} \
>>  74     --disable-smartcard-nss \
>> Thanks,
>> Cillian.
> devel mailing list
> devel at rtems.org
