[PATCH] bsps: Improve interrupt vector enable/disable API
Sebastian Huber
Mon Jun 19 13:19:31 UTC 2017
Change bsp_interrupt_vector_enable() and bsp_interrupt_vector_disable()
to not return a status code. Add bsp_interrupt_assert() and use it to
validate the vector number in the vector enable/disable implementations.
c/src/lib/libbsp/arm/beagle/irq.c | 12 +++---
c/src/lib/libbsp/arm/edb7312/irq/irq.c | 12 +++---
c/src/lib/libbsp/arm/gdbarmsim/irq/irq.c | 8 ++--
c/src/lib/libbsp/arm/lpc24xx/irq/irq.c | 10 ++---
c/src/lib/libbsp/arm/lpc32xx/irq/irq.c | 49 +++++++++-------------
c/src/lib/libbsp/arm/raspberrypi/irq/irq.c | 16 ++-----
c/src/lib/libbsp/arm/shared/arm-gic-irq.c | 28 ++++---------
.../lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c | 18 +++-----
c/src/lib/libbsp/arm/tms570/irq/irq.c | 40 +++---------------
c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c | 8 ++--
c/src/lib/libbsp/i386/pc386/timer/timer.c | 7 +---
c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c | 6 ---
c/src/lib/libbsp/i386/shared/irq/irq.c | 14 +++----
c/src/lib/libbsp/lm32/shared/irq/irq.c | 8 ++--
c/src/lib/libbsp/m68k/genmcf548x/irq/irq.c | 44 +++++++------------
c/src/lib/libbsp/mips/shared/irq/irq.c | 8 ++--
c/src/lib/libbsp/or1k/generic_or1k/irq/irq.c | 8 ++--
c/src/lib/libbsp/powerpc/gen5200/irq/irq.c | 32 +++++++-------
c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c | 16 +++----
c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.c | 12 +++---
c/src/lib/libbsp/powerpc/psim/irq/irq_init.c | 8 ++--
c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c | 8 ++--
c/src/lib/libbsp/powerpc/qoriq/irq/irq.c | 24 +++++------
c/src/lib/libbsp/powerpc/t32mppc/irq/irq.c | 8 ++--
c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c | 32 +++++++-------
c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c | 32 +++++---------
c/src/lib/libbsp/shared/include/irq-generic.h | 30 +++++++------
c/src/lib/libbsp/shared/src/irq-generic.c | 16 +------
c/src/lib/libbsp/shared/src/irq-server.c | 8 +++-
c/src/lib/libbsp/sparc/shared/irq/irq-shared.c | 10 ++---
c/src/lib/libcpu/arm/at91rm9200/irq/irq.c | 10 ++---
c/src/lib/libcpu/arm/lpc22xx/irq/irq.c | 10 ++---
c/src/lib/libcpu/arm/mc9328mxl/irq/irq.c | 20 ++++-----
c/src/lib/libcpu/arm/pxa255/irq/irq.c | 10 ++---
c/src/lib/libcpu/arm/s3c24xx/irq/irq.c | 8 ++--
c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c | 18 +++-----
36 files changed, 238 insertions(+), 370 deletions(-)
diff --git a/c/src/lib/libbsp/arm/beagle/irq.c b/c/src/lib/libbsp/arm/beagle/irq.c
index d080a5e851..2fa1a5b0f0 100644
--- a/c/src/lib/libbsp/arm/beagle/irq.c
+++ b/c/src/lib/libbsp/arm/beagle/irq.c
@@ -95,28 +95,28 @@ static uint32_t omap_get_mir_reg(rtems_vector_number vector, uint32_t *const mas
return mir_reg;
-rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
+void bsp_interrupt_vector_enable(rtems_vector_number vector)
uint32_t mask, cur;
uint32_t mir_reg = omap_get_mir_reg(vector, &mask);
+ bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector));
cur = mmio_read(omap_intr.base + mir_reg);
mmio_write(omap_intr.base + mir_reg, cur & ~mask);
flush_data_cache();
- return RTEMS_SUCCESSFUL;
-rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
+void bsp_interrupt_vector_disable(rtems_vector_number vector)
uint32_t mask, cur;
mmio_write(omap_intr.base + mir_reg, cur | mask);
flush_data_cache();
rtems_status_code bsp_interrupt_facility_initialize(void)
diff --git a/c/src/lib/libbsp/arm/edb7312/irq/irq.c b/c/src/lib/libbsp/arm/edb7312/irq/irq.c
index 8c18ea7abd..1d9151a1bd 100644
--- a/c/src/lib/libbsp/arm/edb7312/irq/irq.c
+++ b/c/src/lib/libbsp/arm/edb7312/irq/irq.c
@@ -27,8 +27,10 @@ void edb7312_interrupt_dispatch(rtems_vector_number vector)
bsp_interrupt_handler_dispatch(vector);
if(vector >= BSP_EXTFIQ && vector <= BSP_SSEOTI)
/* interrupt managed by INTMR1 and INTSR1 */
@@ -49,12 +51,12 @@ rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
/* interrupt managed by INTMR3 and INTSR3 */
*EP7312_INTMR3 |= (1 << (vector - 21));
@@ -75,8 +77,6 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
*EP7312_INTMR3 &= ~(1 << (vector - 21));
diff --git a/c/src/lib/libbsp/arm/gdbarmsim/irq/irq.c b/c/src/lib/libbsp/arm/gdbarmsim/irq/irq.c
index 79665b46fd..886f928d2d 100644
--- a/c/src/lib/libbsp/arm/gdbarmsim/irq/irq.c
+++ b/c/src/lib/libbsp/arm/gdbarmsim/irq/irq.c
@@ -50,14 +50,14 @@ unsigned lpc24xx_irq_get_priority(rtems_vector_number vector)
#ifdef ARM_MULTILIB_ARCH_V4
diff --git a/c/src/lib/libbsp/arm/lpc24xx/irq/irq.c b/c/src/lib/libbsp/arm/lpc24xx/irq/irq.c
index 408f20db4f..7801c37843 100644
--- a/c/src/lib/libbsp/arm/lpc24xx/irq/irq.c
+++ b/c/src/lib/libbsp/arm/lpc24xx/irq/irq.c
@@ -64,18 +64,16 @@ unsigned lpc24xx_irq_get_priority(rtems_vector_number vector)
VICIntEnable = 1U << vector;
VICIntEnClear = 1U << vector;
diff --git a/c/src/lib/libbsp/arm/lpc32xx/irq/irq.c b/c/src/lib/libbsp/arm/lpc32xx/irq/irq.c
index 37080f4de2..eac320000b 100755
--- a/c/src/lib/libbsp/arm/lpc32xx/irq/irq.c
+++ b/c/src/lib/libbsp/arm/lpc32xx/irq/irq.c
@@ -50,11 +50,6 @@ static lpc32xx_irq_fields lpc32xx_irq_priority_masks [LPC32XX_IRQ_PRIORITY_COUNT
static lpc32xx_irq_fields lpc32xx_irq_enable;
-static inline bool lpc32xx_irq_is_valid(rtems_vector_number vector)
- return vector <= BSP_INTERRUPT_VECTOR_MAX;
static inline bool lpc32xx_irq_priority_is_valid(unsigned priority)
return priority <= LPC32XX_IRQ_PRIORITY_LOWEST;
@@ -130,7 +125,7 @@ static inline unsigned lpc32xx_irq_get_index(uint32_t val)
void lpc32xx_irq_set_priority(rtems_vector_number vector, unsigned priority)
- if (lpc32xx_irq_is_valid(vector)) {
+ if (bsp_interrupt_is_valid_vector(vector)) {
rtems_interrupt_level level;
unsigned i = 0;
@@ -156,7 +151,7 @@ void lpc32xx_irq_set_priority(rtems_vector_number vector, unsigned priority)
unsigned lpc32xx_irq_get_priority(rtems_vector_number vector)
return lpc32xx_irq_priority_table [vector];
} else {
return LPC32XX_IRQ_PRIORITY_LOWEST;
@@ -165,7 +160,7 @@ unsigned lpc32xx_irq_get_priority(rtems_vector_number vector)
void lpc32xx_irq_set_activation_polarity(rtems_vector_number vector, lpc32xx_irq_activation_polarity activation_polarity)
rtems_interrupt_disable(level);
@@ -180,7 +175,7 @@ void lpc32xx_irq_set_activation_polarity(rtems_vector_number vector, lpc32xx_irq
lpc32xx_irq_activation_polarity lpc32xx_irq_get_activation_polarity(rtems_vector_number vector)
if (lpc32xx_irq_is_bit_set_in_register(vector, LPC32XX_IRQ_OFFSET_APR)) {
return LPC32XX_IRQ_ACTIVE_HIGH_OR_RISING_EDGE;
} else {
@@ -193,7 +188,7 @@ lpc32xx_irq_activation_polarity lpc32xx_irq_get_activation_polarity(rtems_vector
void lpc32xx_irq_set_activation_type(rtems_vector_number vector, lpc32xx_irq_activation_type activation_type)
@@ -208,7 +203,7 @@ void lpc32xx_irq_set_activation_type(rtems_vector_number vector, lpc32xx_irq_act
lpc32xx_irq_activation_type lpc32xx_irq_get_activation_type(rtems_vector_number vector)
if (lpc32xx_irq_is_bit_set_in_register(vector, LPC32XX_IRQ_OFFSET_ATR)) {
return LPC32XX_IRQ_EDGE_SENSITIVE;
} else {
@@ -265,32 +260,28 @@ void bsp_interrupt_dispatch(void)
lpc32xx.sic_2.er = er_sic_2 & lpc32xx_irq_enable.field.sic_2;
- rtems_interrupt_level level;
+ rtems_interrupt_level level;
- rtems_interrupt_disable(level);
- lpc32xx_irq_set_bit_in_register(vector, LPC32XX_IRQ_OFFSET_ER);
- lpc32xx_irq_set_bit_in_field(vector, &lpc32xx_irq_enable);
- rtems_interrupt_enable(level);
+ rtems_interrupt_disable(level);
+ lpc32xx_irq_set_bit_in_register(vector, LPC32XX_IRQ_OFFSET_ER);
+ lpc32xx_irq_set_bit_in_field(vector, &lpc32xx_irq_enable);
+ rtems_interrupt_enable(level);
- lpc32xx_irq_clear_bit_in_field(vector, &lpc32xx_irq_enable);
- lpc32xx_irq_clear_bit_in_register(vector, LPC32XX_IRQ_OFFSET_ER);
+ lpc32xx_irq_clear_bit_in_field(vector, &lpc32xx_irq_enable);
+ lpc32xx_irq_clear_bit_in_register(vector, LPC32XX_IRQ_OFFSET_ER);
void lpc32xx_set_exception_handler(
diff --git a/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c b/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c
index 48f781075b..5b10385bfe 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c
+++ b/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c
@@ -139,26 +139,18 @@ void bsp_interrupt_dispatch(void)
- if ( vector > BSP_INTERRUPT_VECTOR_MAX )
- return RTEMS_INVALID_ID;
BCM2835_REG(bsp_vector_to_reg(vector)->enable_reg_addr) =
bsp_vector_to_mask(vector);
BCM2835_REG(bsp_vector_to_reg(vector)->disable_reg_addr) =
void bsp_interrupt_handler_default(rtems_vector_number vector)
diff --git a/c/src/lib/libbsp/arm/shared/arm-gic-irq.c b/c/src/lib/libbsp/arm/shared/arm-gic-irq.c
index 487ee16f72..5a4a998bfb 100644
--- a/c/src/lib/libbsp/arm/shared/arm-gic-irq.c
+++ b/c/src/lib/libbsp/arm/shared/arm-gic-irq.c
@@ -44,34 +44,22 @@ void bsp_interrupt_dispatch(void)
- rtems_status_code sc = RTEMS_SUCCESSFUL;
+ volatile gic_dist *dist = ARM_GIC_DIST;
- if (bsp_interrupt_is_valid_vector(vector)) {
- volatile gic_dist *dist = ARM_GIC_DIST;
- gic_id_enable(dist, vector);
- } else {
- sc = RTEMS_INVALID_ID;
- return sc;
+ gic_id_enable(dist, vector);
- gic_id_disable(dist, vector);
- } else {
- return sc;
+ gic_id_disable(dist, vector);
static inline uint32_t get_id_count(volatile gic_dist *dist)
diff --git a/c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c b/c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c
index df17c26cdd..1d930a4591 100644
--- a/c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c
+++ b/c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c
@@ -22,22 +22,16 @@
#ifdef ARM_MULTILIB_ARCH_V7M
- _ARMV7M_NVIC_Set_enable((int) vector);
+ _ARMV7M_NVIC_Set_enable((int) vector);
- _ARMV7M_NVIC_Clear_enable((int) vector);
+ _ARMV7M_NVIC_Clear_enable((int) vector);
diff --git a/c/src/lib/libbsp/arm/tms570/irq/irq.c b/c/src/lib/libbsp/arm/tms570/irq/irq.c
index 7a2a55fff5..579c11ed2a 100644
--- a/c/src/lib/libbsp/arm/tms570/irq/irq.c
+++ b/c/src/lib/libbsp/arm/tms570/irq/irq.c
@@ -28,24 +28,6 @@
#include <bsp/irq.h>
#include <rtems/score/armv4.h>
- * @brief Check if isr vector is valid
- * Check if isr vector is valid by using BSP_INTERRUPT_VECTOR_MAX and
- * BSP_INTERRUPT_VECTOR_MIN defined in irq.h
- * @param[in] vector interrupt vector to be checked.
- * @retval TRUE vector is valid.
- * @retval FALSE vector is invalid
-static inline bool tms570_irq_is_valid(
- rtems_vector_number vector
- return (vector <= BSP_INTERRUPT_VECTOR_MAX) &&
- (vector > BSP_INTERRUPT_VECTOR_MIN);
unsigned int priorityTable[BSP_INTERRUPT_VECTOR_MAX+1];
@@ -64,7 +46,7 @@ void tms570_irq_set_priority(
unsigned priority
- if ( tms570_irq_is_valid(vector) ) {
+ if ( bsp_interrupt_is_valid_vector(vector) ) {
priorityTable[vector] = priority;
@@ -84,7 +66,7 @@ unsigned tms570_irq_get_priority(
return priorityTable[vector];
return 0;
@@ -114,17 +96,12 @@ void bsp_interrupt_dispatch(void)
* @retval RTEMS_INVALID_ID vector is invalid.
* @retval RTEMS_SUCCESSFUL interrupt source enabled.
- if( !tms570_irq_is_valid(vector) ) {
TMS570_VIM.REQENASET[vector >> 5] = 1 << (vector & 0x1f);
@@ -136,17 +113,12 @@ rtems_status_code bsp_interrupt_vector_enable(
* @retval RTEMS_SUCCESSFUL interrupt source disabled.
TMS570_VIM.REQENACLR[vector >> 5] = 1 << (vector & 0x1f);
diff --git a/c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c b/c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c
index 057a0f7e81..994e25bf0e 100644
--- a/c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c
+++ b/c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c
@@ -53,12 +53,12 @@ rtems_status_code bsp_interrupt_facility_initialize()
return 0;
- return 0;
- return 0;
diff --git a/c/src/lib/libbsp/i386/pc386/timer/timer.c b/c/src/lib/libbsp/i386/pc386/timer/timer.c
index 5bef139d38..16d3d66176 100644
--- a/c/src/lib/libbsp/i386/pc386/timer/timer.c
+++ b/c/src/lib/libbsp/i386/pc386/timer/timer.c
@@ -153,17 +153,12 @@ static void timerOn(const rtems_raw_irq_connect_data* used)
bsp_interrupt_vector_enable(used->idtIndex - BSP_IRQ_VECTOR_BASE);
-static int timerIsOn(const rtems_raw_irq_connect_data *used)
- return bsp_interrupt_vector_enable(used->idtIndex - BSP_IRQ_VECTOR_BASE);
static rtems_raw_irq_connect_data timer_raw_irq_data = {
BSP_PERIODIC_TIMER + BSP_IRQ_VECTOR_BASE,
timerisr,
timerOn,
timerOff,
- timerIsOn
+ NULL
diff --git a/c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c b/c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c
index 7802270140..d47d057860 100644
--- a/c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c
+++ b/c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c
@@ -173,11 +173,6 @@ static void BSP_uart_off(const rtems_raw_irq_connect_data* used)
bsp_interrupt_vector_disable(used->idtIndex - BSP_IRQ_VECTOR_BASE);
-static int BSP_uart_isOn(const rtems_raw_irq_connect_data* used)
* In order to have a possibility to break into
* running program, one has to call this function
@@ -210,7 +205,6 @@ void i386_stub_glue_init_breakin(void)
uart_raw_irq_data.on = BSP_uart_on;
uart_raw_irq_data.off = BSP_uart_off;
- uart_raw_irq_data.isOn= BSP_uart_isOn;
/* Install ISR */
uart_raw_irq_data.idtIndex = port_current->ulIntVector + BSP_IRQ_VECTOR_BASE;
diff --git a/c/src/lib/libbsp/i386/shared/irq/irq.c b/c/src/lib/libbsp/i386/shared/irq/irq.c
index f4ffd8c0e4..ac08f1f7be 100644
--- a/c/src/lib/libbsp/i386/shared/irq/irq.c
+++ b/c/src/lib/libbsp/i386/shared/irq/irq.c
@@ -270,18 +270,16 @@ static inline bool bsp_interrupt_vector_is_valid(rtems_vector_number vector)
return BSP_i8259a_irq_valid((const rtems_irq_number) vector);
- if (bsp_interrupt_vector_is_valid(vector))
- BSP_irq_enable_at_i8259a(vector);
+ BSP_irq_enable_at_i8259a(vector);
- BSP_irq_disable_at_i8259a(vector);
+ BSP_irq_disable_at_i8259a(vector);
diff --git a/c/src/lib/libbsp/lm32/shared/irq/irq.c b/c/src/lib/libbsp/lm32/shared/irq/irq.c
index 8f9bfaf1ac..79626ee449 100644
--- a/c/src/lib/libbsp/lm32/shared/irq/irq.c
+++ b/c/src/lib/libbsp/lm32/shared/irq/irq.c
@@ -17,14 +17,14 @@ rtems_status_code bsp_interrupt_facility_initialize(void)
lm32_interrupt_unmask(1 << vector);
lm32_interrupt_mask(1 << vector);
diff --git a/c/src/lib/libbsp/m68k/genmcf548x/irq/irq.c b/c/src/lib/libbsp/m68k/genmcf548x/irq/irq.c
index 58e904426a..f02231b67c 100644
--- a/c/src/lib/libbsp/m68k/genmcf548x/irq/irq.c
+++ b/c/src/lib/libbsp/m68k/genmcf548x/irq/irq.c
@@ -59,42 +59,30 @@ static rtems_vector_number vector_to_exception_vector(
return vector + 64U;
+ volatile uint32_t *imr = vector_to_imr(vector);
+ uint32_t bit = vector_to_bit(vector);
- volatile uint32_t *imr = vector_to_imr(vector);
- uint32_t bit = vector_to_bit(vector);
- *imr &= ~bit;
- } else {
- return sc;
+ *imr &= ~bit;
- *imr |= bit;
- } else {
- return sc;
+ *imr |= bit;
static void_func get_exception_handler(rtems_vector_number vector)
diff --git a/c/src/lib/libbsp/mips/shared/irq/irq.c b/c/src/lib/libbsp/mips/shared/irq/irq.c
index d4941763bc..1c2d3b8c5b 100644
--- a/c/src/lib/libbsp/mips/shared/irq/irq.c
+++ b/c/src/lib/libbsp/mips/shared/irq/irq.c
@@ -67,14 +67,14 @@ static inline bool bsp_irq_is_valid(rtems_vector_number vector)
diff --git a/c/src/lib/libbsp/or1k/generic_or1k/irq/irq.c b/c/src/lib/libbsp/or1k/generic_or1k/irq/irq.c
index 00d53d7409..f9a7b6426d 100644
--- a/c/src/lib/libbsp/or1k/generic_or1k/irq/irq.c
+++ b/c/src/lib/libbsp/or1k/generic_or1k/irq/irq.c
@@ -32,12 +32,12 @@ rtems_status_code bsp_interrupt_facility_initialize()
return 0;
- return 0;
- return 0;
diff --git a/c/src/lib/libbsp/powerpc/gen5200/irq/irq.c b/c/src/lib/libbsp/powerpc/gen5200/irq/irq.c
index 029ed3182e..58e2f2a987 100644
--- a/c/src/lib/libbsp/powerpc/gen5200/irq/irq.c
+++ b/c/src/lib/libbsp/powerpc/gen5200/irq/irq.c
@@ -359,24 +359,26 @@ static inline void BSP_disable_crit_irq_at_siu( rtems_vector_number
* This function enables a given siu interrupt
-rtems_status_code bsp_interrupt_vector_enable( rtems_vector_number irqLine)
+void bsp_interrupt_vector_enable( rtems_vector_number vector)
- int base_index = get_siu_irq_base_index( irqLine);
+ int base_index = get_siu_irq_base_index( vector);
- if (is_siu_irq( irqLine)) {
+ if (is_siu_irq( vector)) {
rtems_interrupt_disable( level);
switch (base_index) {
case BSP_PER_IRQ_LOWEST_OFFSET:
- BSP_enable_per_irq_at_siu( irqLine);
+ BSP_enable_per_irq_at_siu( vector);
break;
case BSP_MAIN_IRQ_LOWEST_OFFSET:
- BSP_enable_main_irq_at_siu( irqLine);
+ BSP_enable_main_irq_at_siu( vector);
break;
case BSP_CRIT_IRQ_LOWEST_OFFSET:
- BSP_enable_crit_irq_at_siu( irqLine);
+ BSP_enable_crit_irq_at_siu( vector);
break;
default:
rtems_interrupt_enable( level);
@@ -386,31 +388,31 @@ rtems_status_code bsp_interrupt_vector_enable( rtems_vector_number irqLine)
* This function disables a given siu interrupt
-rtems_status_code bsp_interrupt_vector_disable( rtems_vector_number irqLine)
+void bsp_interrupt_vector_disable( rtems_vector_number vector)
- BSP_disable_per_irq_at_siu( irqLine);
+ BSP_disable_per_irq_at_siu( vector);
break;
- BSP_disable_main_irq_at_siu( irqLine);
+ BSP_disable_main_irq_at_siu( vector);
break;
- BSP_disable_crit_irq_at_siu( irqLine);
+ BSP_disable_crit_irq_at_siu( vector);
break;
default:
@@ -420,8 +422,6 @@ rtems_status_code bsp_interrupt_vector_disable( rtems_vector_number irqLine)
#if (BENCHMARK_IRQ_PROCESSING == 0)
diff --git a/c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c b/c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c
index 2d89cfa137..7a8ce3cc0b 100644
--- a/c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c
+++ b/c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c
@@ -376,11 +376,13 @@ rtems_status_code mpc83xx_ipic_set_highest_priority_interrupt(
* functions to enable/disable a source at the ipic
-rtems_status_code bsp_interrupt_vector_enable( rtems_vector_number irqnum)
- rtems_vector_number vecnum = irqnum - BSP_IPIC_IRQ_LOWEST_OFFSET;
+ rtems_vector_number vecnum = vector - BSP_IPIC_IRQ_LOWEST_OFFSET;
const BSP_isrc_rsc_t *rsc_ptr;
if (MPC83XX_IPIC_IS_VALID_VECTOR( vecnum)) {
rsc_ptr = &mpc83xx_ipic_isrc_rsc [vecnum];
if (rsc_ptr->mask_reg != NULL) {
@@ -392,15 +394,15 @@ rtems_status_code bsp_interrupt_vector_enable( rtems_vector_number irqnum)
-rtems_status_code bsp_interrupt_vector_disable( rtems_vector_number irqnum)
@@ -412,8 +414,6 @@ rtems_status_code bsp_interrupt_vector_disable( rtems_vector_number irqnum)
diff --git a/c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.c b/c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.c
index 52465ec2a7..c145186a52 100644
--- a/c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.c
+++ b/c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.c
@@ -328,28 +328,28 @@ BSP_CPM_irq_init(void)
+void bsp_interrupt_vector_enable( rtems_vector_number irqnum)
if (is_cpm_irq(irqnum)) {
* Enable interrupt at PIC level
BSP_irq_enable_at_cpm (irqnum);
+void bsp_interrupt_vector_disable( rtems_vector_number irqnum)
* disable interrupt at PIC level
BSP_irq_disable_at_cpm (irqnum);
diff --git a/c/src/lib/libbsp/powerpc/psim/irq/irq_init.c b/c/src/lib/libbsp/powerpc/psim/irq/irq_init.c
index 59f0e1dcea..61600a9d62 100644
--- a/c/src/lib/libbsp/powerpc/psim/irq/irq_init.c
+++ b/c/src/lib/libbsp/powerpc/psim/irq/irq_init.c
@@ -102,16 +102,16 @@ static int psim_exception_handler(
/* FIXME: do something */
diff --git a/c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c b/c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c
index f4592a375f..b5533e0872 100644
--- a/c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c
+++ b/c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c
@@ -38,16 +38,16 @@ static int qemuppc_exception_handler(
diff --git a/c/src/lib/libbsp/powerpc/qoriq/irq/irq.c b/c/src/lib/libbsp/powerpc/qoriq/irq/irq.c
index da7def3913..ea086215fc 100644
--- a/c/src/lib/libbsp/powerpc/qoriq/irq/irq.c
+++ b/c/src/lib/libbsp/powerpc/qoriq/irq/irq.c
@@ -175,28 +175,24 @@ rtems_status_code qoriq_pic_set_affinity(
static rtems_status_code pic_vector_enable(rtems_vector_number vector, uint32_t msk)
- volatile qoriq_pic_src_cfg *src_cfg = get_src_cfg(vector);
- rtems_interrupt_lock_context lock_context;
+ volatile qoriq_pic_src_cfg *src_cfg = get_src_cfg(vector);
+ rtems_interrupt_lock_context lock_context;
- rtems_interrupt_lock_acquire(&lock, &lock_context);
- src_cfg->vpr = (src_cfg->vpr & ~VPR_MSK) | msk;
- rtems_interrupt_lock_release(&lock, &lock_context);
- return sc;
+ rtems_interrupt_lock_acquire(&lock, &lock_context);
+ src_cfg->vpr = (src_cfg->vpr & ~VPR_MSK) | msk;
+ rtems_interrupt_lock_release(&lock, &lock_context);
- return pic_vector_enable(vector, 0);
+ pic_vector_enable(vector, 0);
- return pic_vector_enable(vector, VPR_MSK);
+ pic_vector_enable(vector, VPR_MSK);
static void qoriq_interrupt_dispatch(void)
diff --git a/c/src/lib/libbsp/powerpc/t32mppc/irq/irq.c b/c/src/lib/libbsp/powerpc/t32mppc/irq/irq.c
index 3cabcdef35..0c98c3a27d 100644
--- a/c/src/lib/libbsp/powerpc/t32mppc/irq/irq.c
+++ b/c/src/lib/libbsp/powerpc/t32mppc/irq/irq.c
@@ -14,14 +14,14 @@
#include <bsp/irq-generic.h>
diff --git a/c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c b/c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c
index 8066a7f43b..2a94c27d1b 100644
--- a/c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c
+++ b/c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c
@@ -63,30 +63,26 @@ static rtems_status_code bsp_irq_enable_at_CPM(rtems_vector_number irqnum)
- if (BSP_IS_CPM_IRQ(irqnum)) {
- bsp_irq_enable_at_CPM(irqnum);
- else if (BSP_IS_SIU_IRQ(irqnum)) {
- bsp_irq_enable_at_SIU(irqnum);
+ if (BSP_IS_CPM_IRQ(vector)) {
+ bsp_irq_enable_at_CPM(vector);
+ } else if (BSP_IS_SIU_IRQ(vector)) {
+ bsp_irq_enable_at_SIU(vector);
- bsp_irq_disable_at_CPM(irqnum);
- bsp_irq_disable_at_SIU(irqnum);
+ bsp_irq_disable_at_CPM(vector);
+ bsp_irq_disable_at_SIU(vector);
diff --git a/c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c b/c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c
index a9fe7066bc..55194cb1e6 100644
--- a/c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c
+++ b/c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c
@@ -132,34 +132,22 @@ static void opb_intc_init(void)
(OPB_INTC_MER_HIE | OPB_INTC_MER_ME);
- if (BSP_IS_OPBINTC_IRQ(vector)) {
- BSP_irq_enable_at_opbintc(vector);
- } else {
- return sc;
+ if (BSP_IS_OPBINTC_IRQ(vector)) {
+ BSP_irq_enable_at_opbintc(vector);
- BSP_irq_disable_at_opbintc(vector);
- } else {
- return sc;
+ BSP_irq_disable_at_opbintc(vector);
static int C_dispatch_irq_handler(BSP_Exception_frame *frame, unsigned int excNum)
diff --git a/c/src/lib/libbsp/shared/include/irq-generic.h b/c/src/lib/libbsp/shared/include/irq-generic.h
index 4e89d74ab3..187aea84d1 100644
--- a/c/src/lib/libbsp/shared/include/irq-generic.h
+++ b/c/src/lib/libbsp/shared/include/irq-generic.h
@@ -9,7 +9,7 @@
* Based on concepts of Pavel Pisa, Till Straumann and Eric Valette.
- * Copyright (c) 2008-2014 embedded brains GmbH.
+ * Copyright (c) 2008, 2017 embedded brains GmbH.
* embedded brains GmbH
* Dornierstr. 4
@@ -30,6 +30,7 @@
#include <stdbool.h>
#include <rtems/irq-extension.h>
+#include <rtems/score/assert.h>
#ifdef RTEMS_SMP
#include <rtems/score/atomic.h>
@@ -71,6 +72,8 @@ extern "C" {
#define bsp_interrupt_fence(order) do { } while (0)
#endif
+#define bsp_interrupt_assert(e) _Assert(e)
struct bsp_interrupt_handler_entry {
rtems_interrupt_handler handler;
void *arg;
@@ -215,32 +218,33 @@ rtems_status_code bsp_interrupt_facility_initialize(void);
* This function shall enable the vector at the corresponding facility (in most
* cases the interrupt controller). It will be called then the first handler
- * is installed for the vector in bsp_interrupt_handler_install(). It is
- * guaranteed that the vector number is within the BSP_INTERRUPT_VECTOR_MIN and
- * BSP_INTERRUPT_VECTOR_MAX range.
+ * is installed for the vector in bsp_interrupt_handler_install() for example.
+ * @note The implementation should use
+ * bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector)) to valdiate the
+ * vector number.
* @note You must not install or remove an interrupt handler in this function.
* This may result in a deadlock.
- * @return On success RTEMS_SUCCESSFUL shall be returned.
-rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector);
+void bsp_interrupt_vector_enable(rtems_vector_number vector);
* @brief Disables the interrupt vector with number @a vector.
* This function shall disable the vector at the corresponding facility (in
* most cases the interrupt controller). It will be called then the last
- * handler is removed for the vector in bsp_interrupt_handler_remove(). It is
+ * handler is removed for the vector in bsp_interrupt_handler_remove() for
+ * example.
+ * vector number.
-rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector);
+void bsp_interrupt_vector_disable(rtems_vector_number vector);
* @brief Sequencially calls all interrupt handlers for the vector number @a
diff --git a/c/src/lib/libbsp/shared/src/irq-generic.c b/c/src/lib/libbsp/shared/src/irq-generic.c
index b2a7ced64c..7f943d96cb 100755
--- a/c/src/lib/libbsp/shared/src/irq-generic.c
+++ b/c/src/lib/libbsp/shared/src/irq-generic.c
@@ -207,7 +207,6 @@ static rtems_status_code bsp_interrupt_handler_install(
void *arg
rtems_vector_number index = 0;
bsp_interrupt_handler_entry *head = NULL;
@@ -346,11 +345,7 @@ static rtems_status_code bsp_interrupt_handler_install(
/* Enable the vector if necessary */
if (enable_vector) {
- sc = bsp_interrupt_vector_enable(vector);
- if (sc != RTEMS_SUCCESSFUL) {
- bsp_interrupt_unlock();
- return sc;
+ bsp_interrupt_vector_enable(vector);
/* Unlock */
@@ -375,7 +370,6 @@ static rtems_status_code bsp_interrupt_handler_remove(
void *arg
@@ -446,7 +440,7 @@ static rtems_status_code bsp_interrupt_handler_remove(
/* Disable the vector */
- sc = bsp_interrupt_vector_disable(vector);
+ bsp_interrupt_vector_disable(vector);
/* Clear entry */
bsp_interrupt_disable(level);
@@ -458,12 +452,6 @@ static rtems_status_code bsp_interrupt_handler_remove(
/* Allow shared handlers */
bsp_interrupt_set_handler_unique(index, false);
- /* Check status code */
- return sc;
} else {
* The match is the list tail and has a predecessor.
diff --git a/c/src/lib/libbsp/shared/src/irq-server.c b/c/src/lib/libbsp/shared/src/irq-server.c
index 905c26198b..9a3ca9abf1 100644
--- a/c/src/lib/libbsp/shared/src/irq-server.c
+++ b/c/src/lib/libbsp/shared/src/irq-server.c
@@ -56,7 +56,9 @@ static void bsp_interrupt_server_trigger(void *arg)
rtems_interrupt_server_entry *e = arg;
- bsp_interrupt_vector_disable(e->vector);
+ if (bsp_interrupt_is_valid_vector(e->vector)) {
+ bsp_interrupt_vector_disable(e->vector);
rtems_interrupt_lock_acquire(&bsp_interrupt_server_lock, &lock_context);
@@ -324,7 +326,9 @@ static void bsp_interrupt_server_task(rtems_task_argument arg)
(*current->handler)(current->arg);
} while (action != NULL);
- bsp_interrupt_vector_enable(vector);
diff --git a/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c b/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c
index f219e49f45..344ed71a34 100644
--- a/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c
+++ b/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c
@@ -70,20 +70,18 @@ rtems_status_code bsp_interrupt_facility_initialize(void)
int irq = (int)vector;
BSP_Cpu_Unmask_interrupt(irq, bsp_irq_cpu(irq));
BSP_Cpu_Mask_interrupt(irq, bsp_irq_cpu(irq));
void BSP_shared_interrupt_mask(int irq)
diff --git a/c/src/lib/libcpu/arm/at91rm9200/irq/irq.c b/c/src/lib/libcpu/arm/at91rm9200/irq/irq.c
index 9ecdacfbb7..95e93845b9 100644
--- a/c/src/lib/libcpu/arm/at91rm9200/irq/irq.c
+++ b/c/src/lib/libcpu/arm/at91rm9200/irq/irq.c
@@ -27,18 +27,16 @@ void bsp_interrupt_dispatch(void)
AIC_CTL_REG(AIC_EOICR) = 0;
AIC_CTL_REG(AIC_IECR) = 1 << vector;
AIC_CTL_REG(AIC_IDCR) = 1 << vector;
diff --git a/c/src/lib/libcpu/arm/lpc22xx/irq/irq.c b/c/src/lib/libcpu/arm/lpc22xx/irq/irq.c
index 851705bee2..83e140bd7b 100644
--- a/c/src/lib/libcpu/arm/lpc22xx/irq/irq.c
+++ b/c/src/lib/libcpu/arm/lpc22xx/irq/irq.c
@@ -26,18 +26,16 @@ void bsp_interrupt_dispatch(void)
VICVectAddr = 0;
VICIntEnable |= 1 << vector;
VICIntEnClr = 1 << vector;
diff --git a/c/src/lib/libcpu/arm/mc9328mxl/irq/irq.c b/c/src/lib/libcpu/arm/mc9328mxl/irq/irq.c
index 2d6e34d274..e5887b9717 100644
--- a/c/src/lib/libcpu/arm/mc9328mxl/irq/irq.c
+++ b/c/src/lib/libcpu/arm/mc9328mxl/irq/irq.c
@@ -26,24 +26,20 @@ void bsp_interrupt_dispatch(void)
- if (vector >= MC9328MXL_NUM_INTS)
- MC9328MXL_AITC_INTENNUM = vector;
+ if (vector < MC9328MXL_NUM_INTS)
+ MC9328MXL_AITC_INTENNUM = vector;
- MC9328MXL_AITC_INTDISNUM = vector;
+ MC9328MXL_AITC_INTDISNUM = vector;
diff --git a/c/src/lib/libcpu/arm/pxa255/irq/irq.c b/c/src/lib/libcpu/arm/pxa255/irq/irq.c
index 8b46ce149c..425795b165 100644
--- a/c/src/lib/libcpu/arm/pxa255/irq/irq.c
+++ b/c/src/lib/libcpu/arm/pxa255/irq/irq.c
@@ -24,18 +24,16 @@ void bsp_interrupt_dispatch(void)
XSCALE_INT_ICMR |= 1 << vector;
XSCALE_INT_ICMR &= ~(1 << vector);
diff --git a/c/src/lib/libcpu/arm/s3c24xx/irq/irq.c b/c/src/lib/libcpu/arm/s3c24xx/irq/irq.c
index dce6c383b9..ea8f610353 100644
--- a/c/src/lib/libcpu/arm/s3c24xx/irq/irq.c
+++ b/c/src/lib/libcpu/arm/s3c24xx/irq/irq.c
@@ -27,14 +27,14 @@ void bsp_interrupt_dispatch(void)
diff --git a/c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c b/c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c
index 59b2c39c59..789a19a490 100644
--- a/c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c
+++ b/c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c
@@ -180,20 +180,14 @@ rtems_status_code bsp_interrupt_facility_initialize(void)
-rtems_status_code bsp_interrupt_vector_enable( rtems_vector_number vector)
- if (MPC55XX_IRQ_IS_VALID( vector)) {
- return mpc55xx_intc_set_priority( vector, MPC55XX_INTC_DEFAULT_PRIORITY);
- } else {
+ mpc55xx_intc_set_priority( vector, MPC55XX_INTC_DEFAULT_PRIORITY);
-rtems_status_code bsp_interrupt_vector_disable( rtems_vector_number vector)
- return mpc55xx_intc_set_priority( vector, MPC55XX_INTC_DISABLED_PRIORITY);
- } else {
+ mpc55xx_intc_set_priority( vector, MPC55XX_INTC_DISABLED_PRIORITY);
2.12.3
