RTEMS-libbsd copyright question
Sebastian Huber
Mon Jun 19 13:25:26 UTC 2017
On 19/06/17 08:57, Sichen Zhao wrote:
> I have a question about copyright in rtems-libbsd: i ported some usb driver files from FreeBSD, i modified somewhere in these files to suit with rtems-libbsd. Should i add my copyright in these file?
This depends on your modifications. If you put only #ifdef __rtems__
stuff into the drivers, then this is no work with a copyright from my
point of view. If you do more than adding #ifdef __rtems to the driver
files we should first check why this is necessary and if there is a way
to avoid these modifications at all or reduce them.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
