Hi Sebastian, When i import file from freebsd-org by using ./freebsd-to-rtems.py -R && ./freebsd-to-rtems.py, these files seems has many trailing whitespace. When i try to create the patch then apply it, there are many warning. So should i remove these trailing whitespace handly or just leave it. Best Regards Sichen Zhao
