[PATCH] Add rtems_interrupt_server_handler_iterate()
Fri Jun 23 09:54:08 UTC 2017
 c/src/lib/libbsp/shared/src/irq-server.c | 70 ++++++++++++++++++++++++++++++++
 cpukit/include/rtems/irq-extension.h     | 22 ++++++++++
 2 files changed, 92 insertions(+)
diff --git a/c/src/lib/libbsp/shared/src/irq-server.c b/c/src/lib/libbsp/shared/src/irq-server.c
index 9a3ca9abf1..1f9b75ffd9 100644
--- a/c/src/lib/libbsp/shared/src/irq-server.c
+++ b/c/src/lib/libbsp/shared/src/irq-server.c
@@ -389,6 +389,76 @@ rtems_status_code rtems_interrupt_server_handler_remove(
+typedef struct {
+  rtems_interrupt_per_handler_routine routine;
+  void *arg;
+} bsp_interrupt_server_handler_iterate_helper_data;
+static void bsp_interrupt_server_handler_iterate_helper(void *arg)
+  bsp_interrupt_server_helper_data *hd = arg;
+  bsp_interrupt_server_handler_iterate_helper_data *hihd = hd->arg;
+  rtems_status_code sc;
+  rtems_interrupt_server_entry *e;
+  rtems_option trigger_options;
+  bsp_interrupt_lock();
+  e = bsp_interrupt_server_query_entry(hd->vector, &trigger_options);
+  if (e != NULL) {
+    rtems_interrupt_server_action **link = &e->actions;
+    rtems_interrupt_server_action *c;
+    while ((c = *link) != NULL) {
+      (*hihd->routine)(hihd->arg, NULL, trigger_options, c->handler, c->arg);
+      link = &c->next;
+    sc = RTEMS_SUCCESSFUL;
+  } else {
+    sc = RTEMS_UNSATISFIED;
+  bsp_interrupt_unlock();
+  hd->sc = sc;
+  rtems_event_transient_send(hd->task);
+rtems_status_code rtems_interrupt_server_handler_iterate(
+  rtems_id server,
+  rtems_vector_number vector,
+  rtems_interrupt_per_handler_routine routine,
+  void *arg
+  bsp_interrupt_server_handler_iterate_helper_data hihd;
+  sc = bsp_interrupt_server_is_initialized();
+  if (sc != RTEMS_SUCCESSFUL) {
+    return sc;
+  if (server != RTEMS_ID_NONE) {
+    return RTEMS_NOT_IMPLEMENTED;
+  if (!bsp_interrupt_is_valid_vector(vector)) {
+    return RTEMS_INVALID_ID;
+  hihd.routine = routine;
+  hihd.arg = arg;
+  return bsp_interrupt_server_call_helper(
+    vector,
+    0,
+    NULL,
+    &hihd,
 rtems_status_code rtems_interrupt_server_initialize(
   rtems_task_priority priority,
   size_t stack_size,
diff --git a/cpukit/include/rtems/irq-extension.h b/cpukit/include/rtems/irq-extension.h
index 71ff800881..fec07675b8 100644
--- a/cpukit/include/rtems/irq-extension.h
+++ b/cpukit/include/rtems/irq-extension.h
@@ -333,6 +333,28 @@ rtems_status_code rtems_interrupt_server_handler_remove(
+ * @brief Iterates over all interrupt handler of the interrupt vector with
+ * number @a vector which are installed on the interrupt server specified by
+ * @a server.
+ * A server identifier @a server of @c RTEMS_ID_NONE may be used to specify the
+ * default server.
+ * @see rtems_interrupt_handler_iterate()
+ * @retval RTEMS_SUCCESSFUL Shall be returned in case of success.
+ * @retval RTEMS_INCORRECT_STATE If the interrupt handler server is not
+ * initialized this shall be returned.
+ * @retval * For other errors see rtems_interrupt_handler_iterate().
+  rtems_id server,
+  void *arg
  * @brief Initializes the specified interrupt server entry.
  * @param[in] entry The interrupt server entry to initialize.
2.12.3
