[PATCH] c-user: Document EDF SMP
Fri Jun 30 13:07:13 UTC 2017
Close #3056.
 c-user/configuring_a_system.rst | 27 +++++++++++++++++++++++++++
 c-user/scheduling_concepts.rst  |  7 +++++++
 2 files changed, 34 insertions(+)
diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
index 71c5c71..17c8a85 100644
--- a/c-user/configuring_a_system.rst
+++ b/c-user/configuring_a_system.rst
@@ -3795,6 +3795,33 @@ DESCRIPTION:
 NOTES:
     None.
+.. COMMENT: === CONFIGURE_SCHEDULER_EDF_SMP ===
+.. _Use Earliest Deadline First SMP Scheduler:
+Use Earliest Deadline First Scheduler
+.. index:: CONFIGURE_SCHEDULER_EDF_SMP
+CONSTANT:
+    ``CONFIGURE_SCHEDULER_EDF_SMP``
+DATA TYPE:
+    Boolean feature macro.
+RANGE:
+    Defined or undefined.
+DEFAULT VALUE:
+    This is not defined by default.
+DESCRIPTION:
+    If defined, then the Earliest Deadline First (EDF) SMP Scheduler is
+    selected as the default scheduler.
+NOTES:
+    None.
 .. COMMENT: === CONFIGURE_SCHEDULER_CBS ===
 .. _Use Constant Bandwidth Server Scheduler:
diff --git a/c-user/scheduling_concepts.rst b/c-user/scheduling_concepts.rst
index cea863d..7a77a33 100644
--- a/c-user/scheduling_concepts.rst
+++ b/c-user/scheduling_concepts.rst
@@ -183,6 +183,13 @@ period, it has to be finished until the end of this period. The call of
 deadline. Moreover, the ``rtems_rate_monotonic_cancel`` and
 ``rtems_rate_monotonic_delete`` calls clear the deadlines assigned to the task.
+Earliest Deadline First SMP Scheduler
+An EDF scheduler with SMP support.  The processors managed by this scheduler
+are allocated to the highest priority (earliest deadline) tasks which are ready
+to execute.
 Constant Bandwidth Server Scheduling (CBS)
 .. index:: constant bandwidth server scheduling
2.12.3
