RISC-V/HiFive memory limitations
Hesham Almatary heshamelmatary at gmail.com
Mon Jun 19 22:23:30 UTC 2017
On Tue, Jun 20, 2017 at 7:33 AM, Denis Obrezkov <denisobrezkov at gmail.com>
wrote:
> 2017-06-20 0:19 GMT+03:00 Joel Sherrill <joel at rtems.org>:
>> Check the value in gdb without loading it on a target.
>> Gdb hello.exe
>> p symbol
>> Since it is a constant, it should be as expected. If it is, you have a
>> code loading issue.
> Yes, it is 512 in gdb, as expected. So, is the problem with linkcmd file?
>> Is that value by any chance an instruction?
> No don't think so.
> How to check whether it is an instruction or not?
> You can check if this value might match with any riscv32 instruction
encodings (I believe it doesn't). See Chapter 19 (RV32/64G Instruction Set
Listings) user-level riscv-spec 2.3-draft. You can also use
riscv32-rtems4.12-objdump on your binary and search for this value.
I was also able to run gdb, connect to the target,  change the value of the
> variable to 512,
> reconnect to the target, make loading and read the value equal to 512.
> Regards, Denis Obrezkov
Hesham
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170620/dec98cd6/attachment-0002.html>
