RISC-V/HiFive memory limitations
Denis Obrezkov
denisobrezkov at gmail.com
Mon Jun 19 22:37:04 UTC 2017
2017-06-20 1:23 GMT+03:00 Hesham Almatary <heshamelmatary at gmail.com>:
> On Tue, Jun 20, 2017 at 7:33 AM, Denis Obrezkov <denisobrezkov at gmail.com>
> wrote:
>> 2017-06-20 0:19 GMT+03:00 Joel Sherrill <joel at rtems.org>:
>>> Check the value in gdb without loading it on a target.
>>> Gdb hello.exe
>>> p symbol
>>> Since it is a constant, it should be as expected. If it is, you have a
>>> code loading issue.
>> Yes, it is 512 in gdb, as expected. So, is the problem with linkcmd file?
>>> Is that value by any chance an instruction?
>> No don't think so.
>> How to check whether it is an instruction or not?
>> You can check if this value might match with any riscv32 instruction
> encodings (I believe it doesn't). See Chapter 19 (RV32/64G Instruction Set
> Listings) user-level riscv-spec 2.3-draft. You can also use
> riscv32-rtems4.12-objdump on your binary and search for this value.
> I was also able to run gdb, connect to the target, change the value of
>> the variable to 512,
>> reconnect to the target, make loading and read the value equal to 512.
>> Regards, Denis Obrezkov
> Hesham
I didn't find this value in objdump
I think that .data section wasn't properly initialized, does it look
reasonable?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170620/d173ea22/attachment-0002.html>
