RTEMS-libbsd copyright question
Sichen Zhao
zsc19940506 at outlook.com
Wed Jun 21 07:16:26 UTC 2017
Ok, i got it. Thanks all.
Best Regards
Sichen Zhao
> Hi Sichen
> On Wed, Jun 21, 2017 at 11:05 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> On 19/06/17 15:45, Sichen Zhao wrote:
>>> Ok, so i think most of my ported file shouldn't add copyright.
>>> But some file in the rtemsbsd folder , i think i modified some new
>>> code. The link is below:
>>> https://github.com/hahchenchen/rtems-libbsd/blob/usb2.0/rtemsbsd/include/bsp/nexus-devices.h#L49
>>> https://github.com/hahchenchen/rtems-libbsd/blob/usb2.0/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h#L260
>> It would be easier to look at patches, so that you can see what is actually
>> changed.
>> In general, changes in the "freebsd" subdirectory should be as small and
>> mechanical as possible. There should be simply nothing to do that deserves a
>> copyright.
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone : +49 89 189 47 41-16
>> Fax : +49 89 189 47 41-09
>> E-Mail : sebastian.huber at embedded-brains.de
>> PGP : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> Don't add copy right as of now. You can always show off your commits
> if someone ask you to show your work. Any way once it is merged with
> rtems , it will be represented as green dot ;)
