Issue with 'rtems_shell_wait_for_input' function
Tue Mar 7 14:51:48 UTC 2017
On 03/03/17 23:50, vivek kukreja wrote:
> Hello all,
> I made few changes to the fileio test to run NFS using libbsd. The test compiles and when i run it on qemu NFS is initialised.
> The test starts with the 'rtems_shell_wait_for_input' function which returns RTEMS_UNSATISFIED so the test quits as soon as it begins. I read this means the terminal related attributes could not be set. When i bypass this function to directly start the test it works fine. Im not sure this is a bug or some problem with my configuration. Any help with this issue is appreciated!
The serial driver doesn't implement the set attributes device handler
properly and returns an error.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
