[PATCH] arm: Remove legacy execption support
Tue Mar 7 21:03:30 UTC 2017
On 08/03/2017 00:33, Sebastian Huber wrote:
>  c/src/lib/libbsp/arm/Makefile.am                 |   3 -
>  c/src/lib/libbsp/arm/csb336/Makefile.am          |   2 -
>  c/src/lib/libbsp/arm/csb336/start/start.S        |  55 ++++----
>  c/src/lib/libbsp/arm/csb336/startup/bspstart.c   |   6 -
>  c/src/lib/libbsp/arm/csb337/Makefile.am          |   2 -
>  c/src/lib/libbsp/arm/csb337/start/start.S        |  55 ++++----
>  c/src/lib/libbsp/arm/csb337/startup/bspstart.c   |   6 -
>  c/src/lib/libbsp/arm/edb7312/Makefile.am         |   2 -
>  c/src/lib/libbsp/arm/edb7312/start/start.S       |  70 +++++-----
>  c/src/lib/libbsp/arm/edb7312/startup/bspstart.c  |   6 -
>  c/src/lib/libbsp/arm/gumstix/Makefile.am         |   2 -
>  c/src/lib/libbsp/arm/gumstix/start/start.S       |  55 ++++----
>  c/src/lib/libbsp/arm/gumstix/startup/bspstart.c  |   2 -
>  c/src/lib/libbsp/arm/rtl22xx/Makefile.am         |   2 -
>  c/src/lib/libbsp/arm/rtl22xx/start/start.S       |  97 ++++---------
>  c/src/lib/libbsp/arm/rtl22xx/startup/bspstart.c  |   6 -
>  c/src/lib/libbsp/arm/shared/abort/abort.c        | 145 --------------------
>  c/src/lib/libbsp/arm/shared/abort/abort.h        |  52 -------
>  c/src/lib/libbsp/arm/shared/abort/simple_abort.c | 146 --------------------
>  c/src/lib/libbsp/arm/smdk2410/Makefile.am        |   2 -
>  c/src/lib/libbsp/arm/smdk2410/start/start.S      |  55 ++++----
>  c/src/lib/libbsp/arm/smdk2410/startup/bspstart.c |   6 -
>  cpukit/score/cpu/arm/Makefile.am                 |   2 -
>  cpukit/score/cpu/arm/arm_exc_handler_high.c      | 127 -----------------
>  cpukit/score/cpu/arm/arm_exc_handler_low.S       | 166 -----------------------
>  cpukit/score/cpu/arm/rtems/score/cpu.h           |   6 -
>  26 files changed, 182 insertions(+), 896 deletions(-)
>  delete mode 100644 c/src/lib/libbsp/arm/shared/abort/abort.c
>  delete mode 100644 c/src/lib/libbsp/arm/shared/abort/abort.h
>  delete mode 100644 c/src/lib/libbsp/arm/shared/abort/simple_abort.c
>  delete mode 100644 cpukit/score/cpu/arm/arm_exc_handler_high.c
>  delete mode 100644 cpukit/score/cpu/arm/arm_exc_handler_low.S
+1
Thank you for doing this. It is always confusing having both in the tree.
