[PATCH] Use a hash file for GCC only
Wed Mar 8 06:10:28 UTC 2017
On 07/03/17 23:24, Chris Johns wrote:
> On 03/03/2017 02:23, Gedare Bloom wrote:
>> In a way, I do like that this shows the different gcc-newlib versions
>> we use. It might be nice to add a bit of organization to this hashes
>> file and/or documentation of the procedure for adding/removing
>> entries.
>> Maybe it makes more sense to have a separate file for each version
>> being used, e.g. a gcc-4.8.3 hash file, gcc-4.9.3, gcc-6.0.1, etc?
>> That should make it easier to maintain the hashes.
>> I'll leave it to Chris to decide if this is a suitable compromise.
> This seems to have stalled and I have had to push the change to fix
> builds on FreeBSD 11.0 so reverting the change is not possible.
> Please apply this patch. We can look at further improvement as future
> refactoring work.
After the comments in this thread I sent an alternative patch that
removes the hash file:
https://lists.rtems.org/pipermail/devel/2017-March/017102.html
Which one do you like?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
