Warnings in xz
Joel Sherrill
joel at rtems.org
Fri Mar 10 15:10:59 UTC 2017
And to pile on... Coverity thinks there is an out of bounds write in
xz_dec_lzma2.c:
https://scan5.coverity.com/reports.htm#v29808/p10069/fileInstanceId=108959059&defectInstanceId=30877313&mergedDefectId=711586
779 * All probabilities are initialized to the same value. This hack
780 * makes the code smaller by avoiding a separate loop for each
781 * probability array.
782 *
783 * This could be optimized so that only that part of literal
784 * probabilities that are actually required. In the common case
785 * we would write 12 KiB less.
786 */
1. alias: Assigning: probs = s->lzma.is_match[0]. probs now points to
element 0 of s->lzma.is_match (which consists of 192 2-byte elements).
787 probs = s->lzma.is_match[0];
2. Condition i < 14134U /* 1846 + (1 << 4) * 768 */, taking true branch.
4. Condition i < 14134U /* 1846 + (1 << 4) * 768 */, taking true branch.
5. cond_at_most: Checking i < 14134U implies that i may be up to 14133
on the true branch.
788 for (i = 0; i < PROBS_TOTAL; ++i)
3. Jumping back to the beginning of the loop.
CID 711586 (#1 of 1): Out-of-bounds write (OVERRUN)
6. overrun-local: Overrunning array of 192 2-byte elements at element index
14133 (byte offset 28266) by dereferencing pointer probs + i.
789 probs[i] = RC_BIT_MODEL_TOTAL / 2;
790
On Fri, Mar 10, 2017 at 3:41 AM, Sebastian Huber <
> Just for reference:
> https://devel.rtems.org/ticket/2909
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170310/4fff4252/attachment.html>
