Warnings in xz
Sat Mar 11 01:51:23 UTC 2017
On 11/03/2017 02:10, Joel Sherrill wrote:
> And to pile on... Coverity thinks there is an out of bounds write
> in xz_dec_lzma2.c:
> https://scan5.coverity.com/reports.htm#v29808/p10069/fileInstanceId=108959059&defectInstanceId=30877313&mergedDefectId=711586
> 779         * All probabilities are initialized to the same value. This hack
>  780         * makes the code smaller by avoiding a separate loop for each
>  781         * probability array.
>  782         *
>  783         * This could be optimized so that only that part of literal
>  784         * probabilities that are actually required. In the common case
>  785         * we would write 12 KiB less.
>  786         */
>     1. alias: Assigning: probs = s->lzma.is_match[0]. probs now points
> to element 0 of s->lzma.is_match (which consists of 192 2-byte elements).
>  787        probs = s->lzma.is_match[0];
>     2. Condition i < 14134U /* 1846 + (1 << 4) * 768 */, taking true branch.
>     4. Condition i < 14134U /* 1846 + (1 << 4) * 768 */, taking true branch.
>     5. cond_at_most: Checking i < 14134U implies that i may be up to
> 14133 on the true branch.
>  788        for (i = 0; i < PROBS_TOTAL; ++i)
>     3. Jumping back to the beginning of the loop.
> CID 711586 (#1 of 1): Out-of-bounds write (OVERRUN)
> 6. overrun-local: Overrunning array of 192 2-byte elements at element
> index 14133 (byte offset 28266) by dereferencing pointer probs + i.
>  789                probs[i] = RC_BIT_MODEL_TOTAL / 2;
>  790
I am ok looking into warnings however I suggest you approach upstream
with any issues related to the code. I do not know the code.
