timeouts and failure
Sat Mar 18 06:17:53 UTC 2017
On 18/3/17 11:46 am, Gedare Bloom wrote:
> I just ran tests and observe the following on erc32 under gdb, can
> anyone confirm/replicate the timeouts and failure, and know why this
> is happening?
How many cores are you using with rtems-test and so how many tests are
running in parallel? This can effect the time per test and it is
difficult to know the effect this has on the timeout per host machine
being used.
> Passed:   554
> Failed:     1
> Timeouts:   6
> Invalid:    0
> Total:    561
> Result: timeout    Time: 0:03:00.219154 fsdosfsformat01.exe
> Result: timeout    Time: 0:03:00.228353 fsdosfsname01.exe
> Result: timeout    Time: 0:03:00.217955 fsdosfsname02.exe
> Result: timeout    Time: 0:03:00.189769 fsrfsbitmap01.exe
> Result: timeout    Time: 0:03:00.203202 imfs_fserror.exe
> Result: timeout    Time: 0:03:00.207983 crypt01.exe
> Result: failed     Time: 0:00:02.056732 spcontext01.exe
> devel mailing list
> devel at rtems.org
