timeouts and failure
Tanu Hari Dixit tokencolour at gmail.com
Sat Mar 18 08:55:42 UTC 2017
Gedare,
By erc32 under gdb do you mean using --debug-trace=gdb option with rtems-test ?
I ran a normal
 ./rtems-test --log=log_erc32_run_alltest_new --rtems-bsp=erc32-run
--rtems-tools=$HOME/development/rtems/4.12
/home/thd/development/rtems/src/builds/b-erc32_allt/sparc-rtems4.12/c/erc32/testsuites
without the debug trace option and got the following results:
Passed:   543
Failed:     6
Timeouts:  12
Invalid:    0
Total:    561
Failures:
 mdosfs_fsscandir01.exe
 spcontext01.exe
 jffs2_fsscandir01.exe
 mrfs_fsscandir01.exe
 imfs_fsscandir01.exe
 mimfs_fsscandir01.exe
Timeouts:
 mdosfs_fsrdwr.exe
 mimfs_fserror.exe
 fsdosfsname01.exe
 mimfs_fspatheval.exe
 mouse01.exe
 fsdosfswrite01.exe
 malloctest.exe
 math.exe
 crypt01.exe
 fsdosfsformat01.exe
 mdosfs_fstime.exe
 mimfs_fsrdwr.exe
Regards,
Tanu Hari Dixit.
On Sat, Mar 18, 2017 at 11:47 AM, Chris Johns <chrisj at rtems.org> wrote:
> On 18/3/17 11:46 am, Gedare Bloom wrote:
>> I just ran tests and observe the following on erc32 under gdb, can
>> anyone confirm/replicate the timeouts and failure, and know why this
>> is happening?
> How many cores are you using with rtems-test and so how many tests are
> running in parallel? This can effect the time per test and it is
> difficult to know the effect this has on the timeout per host machine
> being used.
> Chris
>> Passed:   554
>> Failed:     1
>> Timeouts:   6
>> Invalid:    0
>> Total:    561
>> Result: timeout    Time: 0:03:00.219154 fsdosfsformat01.exe
>> Result: timeout    Time: 0:03:00.228353 fsdosfsname01.exe
>> Result: timeout    Time: 0:03:00.217955 fsdosfsname02.exe
>> Result: timeout    Time: 0:03:00.189769 fsrfsbitmap01.exe
>> Result: timeout    Time: 0:03:00.203202 imfs_fserror.exe
>> Result: timeout    Time: 0:03:00.207983 crypt01.exe
>> Result: failed     Time: 0:00:02.056732 spcontext01.exe
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
