timeouts and failure
Joel Sherrill
joel at rtems.org
Sat Mar 18 20:52:27 UTC 2017
On Sat, Mar 18, 2017 at 9:00 AM, Joel Sherrill <joel at rtems.org> wrote:
> These are all long running tests. Gedare is on a new computer which I
> assume is quite fast. So he has fewer timeouts.
> I am out of town but can try to remember to use tsim to get the running
> time for some of these in real CPU time. My recollection is that crypt01
> takes a long time compared to other tests.
FWIW here are my results for sparc/erc32:
Passed: 548
Failed: 1
Timeouts: 5
Invalid: 0
Total: 554
Failures:
spcontext01.exe
Timeouts:
fileio.exe
top.exe
termios.exe
capture.exe
monitor.exe
Average test time: 0:00:01.729638
Testing time : 0:15:58.219870
That is much better than yours and is really only the known spcontext01.exe
failure.
I noticed you have 17 tests more than I do enabled. How did you configure?
This
is mine:
../rtems/configure --target=sparc-rtems4.12 --enable-rtemsbsp=erc32
--prefix=/home/joel/rtems-work/tools/4.12 --disable-networking
--enable-posix --disable-multiprocessing --disable-smp --enable-tests
--enable-cxx --enable-maintainer-mode
--joel
--Joel
> On Mar 18, 2017 4:55 AM, "Tanu Hari Dixit" <tokencolour at gmail.com> wrote:
> Gedare,
> By erc32 under gdb do you mean using --debug-trace=gdb option with
> rtems-test ?
> I ran a normal
> ./rtems-test --log=log_erc32_run_alltest_new --rtems-bsp=erc32-run
> --rtems-tools=$HOME/development/rtems/4.12
> /home/thd/development/rtems/src/builds/b-erc32_allt/sparc-rt
> ems4.12/c/erc32/testsuites
> without the debug trace option and got the following results:
> Passed: 543
> Failed: 6
> Timeouts: 12
> Invalid: 0
> Total: 561
> Failures:
> mdosfs_fsscandir01.exe
> spcontext01.exe
> jffs2_fsscandir01.exe
> mrfs_fsscandir01.exe
> imfs_fsscandir01.exe
> mimfs_fsscandir01.exe
> Timeouts:
> mdosfs_fsrdwr.exe
> mimfs_fserror.exe
> fsdosfsname01.exe
> mimfs_fspatheval.exe
> mouse01.exe
> fsdosfswrite01.exe
> malloctest.exe
> math.exe
> crypt01.exe
> fsdosfsformat01.exe
> mdosfs_fstime.exe
> mimfs_fsrdwr.exe
> Regards,
> Tanu Hari Dixit.
> On Sat, Mar 18, 2017 at 11:47 AM, Chris Johns <chrisj at rtems.org> wrote:
> > On 18/3/17 11:46 am, Gedare Bloom wrote:
> >> I just ran tests and observe the following on erc32 under gdb, can
> >> anyone confirm/replicate the timeouts and failure, and know why this
> >> is happening?
> > How many cores are you using with rtems-test and so how many tests are
> > running in parallel? This can effect the time per test and it is
> > difficult to know the effect this has on the timeout per host machine
> > being used.
> > Chris
> >> Passed: 554
> >> Failed: 1
> >> Timeouts: 6
> >> Invalid: 0
> >> Total: 561
> >> Result: timeout Time: 0:03:00.219154 fsdosfsformat01.exe
> >> Result: timeout Time: 0:03:00.228353 fsdosfsname01.exe
> >> Result: timeout Time: 0:03:00.217955 fsdosfsname02.exe
> >> Result: timeout Time: 0:03:00.189769 fsrfsbitmap01.exe
> >> Result: timeout Time: 0:03:00.203202 imfs_fserror.exe
> >> Result: timeout Time: 0:03:00.207983 crypt01.exe
> >> Result: failed Time: 0:00:02.056732 spcontext01.exe
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/devel
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170318/52b5b4ed/attachment.html>
