[PATCH 1/5] Adding modified FREEBSD headers to sync RTEMS termios with FREEBSD
Joel Sherrill
joel at rtems.org
Mon Mar 20 14:19:32 UTC 2017
On Tue, Mar 14, 2017 at 8:54 AM, Kirspel, Kevin <Kevin-Kirspel at idexx.com>
wrote:
> I tested it against xilinx_zynq_a9_qemu. I'm not sure it exists, but if
> there is a way to compile the patch against every (or most) BSP then we
> could ensure no BSP is broken.
There are scripts in rtems-testing/rtems to ease testing of a single
configuation
on all BSPs. Or a variety of configurations on a single BSP. I use them to
generate the warnings reports that I periodically announce.
I am seeing if all BSPs build now. Give me a few hours.
--joel
> Kevin Kirspel
> Electrical Engineer - Sr. Staff
> Idexx Roswell
> 235 Hembree Park Drive
> Roswell GA 30076
> Tel: (770)-510-4444 ext. 81642
> Direct: (770)-688-1642
> Fax: (770)-510-4445
> -----Original Message-----
> From: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
> Sent: Tuesday, March 14, 2017 9:42 AM
> To: Kirspel, Kevin <Kevin-Kirspel at idexx.com>; devel at rtems.org
> Subject: Re: [PATCH 1/5] Adding modified FREEBSD headers to sync RTEMS
> The patch set looks good after a rough review. I will check this in in two
> or three days if nobody objects.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170320/21eb3e51/attachment.html>
