[PATCH 1/5] Adding modified FREEBSD headers to sync RTEMS termios with FREEBSD
Joel Sherrill
joel at rtems.org
Mon Mar 20 17:32:34 UTC 2017
I just built all BSPs and didn't see any failures.
Sebastian.. what was going on with the build you saw fail?
--joel
On Mon, Mar 20, 2017 at 9:19 AM, Joel Sherrill <joel at rtems.org> wrote:
> On Tue, Mar 14, 2017 at 8:54 AM, Kirspel, Kevin <Kevin-Kirspel at idexx.com>
> wrote:
>> I tested it against xilinx_zynq_a9_qemu. I'm not sure it exists, but if
>> there is a way to compile the patch against every (or most) BSP then we
>> could ensure no BSP is broken.
> There are scripts in rtems-testing/rtems to ease testing of a single
> configuation
> on all BSPs. Or a variety of configurations on a single BSP. I use them to
> generate the warnings reports that I periodically announce.
> I am seeing if all BSPs build now. Give me a few hours.
> --joel
>> Kevin Kirspel
>> Electrical Engineer - Sr. Staff
>> Idexx Roswell
>> 235 Hembree Park Drive
>> Roswell GA 30076
>> Tel: (770)-510-4444 ext. 81642
>> Direct: (770)-688-1642
>> Fax: (770)-510-4445
>> -----Original Message-----
>> From: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
>> Sent: Tuesday, March 14, 2017 9:42 AM
>> To: Kirspel, Kevin <Kevin-Kirspel at idexx.com>; devel at rtems.org
>> Subject: Re: [PATCH 1/5] Adding modified FREEBSD headers to sync RTEMS
>> The patch set looks good after a rough review. I will check this in in
>> two or three days if nobody objects.
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone : +49 89 189 47 41-16
>> Fax : +49 89 189 47 41-09
>> E-Mail : sebastian.huber at embedded-brains.de
>> PGP : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170320/bf7c726c/attachment.html>
