timeouts and failure
Tue Mar 21 00:25:05 UTC 2017
On 20/03/2017 17:20, Sebastian Huber wrote:
> On 18/03/17 21:52, Joel Sherrill wrote:
>> FWIW here are my results for sparc/erc32:
>> Passed:   548
>> Failed:     1
>> Timeouts:   5
>> Invalid:    0
>> Total:    554
>> Failures:
>>  spcontext01.exe
> Yes, this is expected.
>> Timeouts:
>>  fileio.exe
>>  top.exe
>>  termios.exe
>>  capture.exe
>>  monitor.exe
> These tests should terminate after 20 seconds or so without input. A
> timeout should therefore not occur.
That is 20 seconds of target time and not real-time if running on a
heavily loaded machine running simulators in parallel. The test tool's
timeout is real time.
I have created https://devel.rtems.org/ticket/2946 to look into this.
