答复: [PATCH] modify punitvara's works on BBB i2c, and now can read the eeprom info.
赵 思晨
zsc19940506 at outlook.com
Wed Mar 22 15:16:43 UTC 2017
Hi Gedare Bloom, Hi Ben:
Latest news. I just modify the PV's i2c code these days, and now it can read the EEPROM preliminarily by the interrupt not the polling , it is the different way from my previously submitted work(the diff.patch). Without the read eeprom function and other not standardized funciton i created before.
And i will test and modify the code in the future to make sure it can works more normative.
Best Regards
Sichen Zhao
发自 Outlook<http://aka.ms/weboutlook>
________________________________
发件人: devel <devel-bounces at rtems.org> 代表 Gedare Bloom <gedare at rtems.org>
发送时间: 2017年3月22日 1:36:13
收件人: Ben Gras
抄送: devel at rtems.org
主题: Re: [PATCH] modify punitvara's works on BBB i2c, and now can read the eeprom info.
On Tue, Mar 21, 2017 at 12:12 AM, Ben Gras <beng at shrike-systems.com> wrote:
> Dear all,
> SZ, great initiative. Gedare and Sebastian have commented.
> For my part, can I just check - the implementation is supposed to be
> generic to i2c devices, correct?
> If so, can you explain what read_eeprom is for? Is it just as demo? Is
> the code generic otherwise?
I believe PV used EEPROM to test his i2c implementation.
> Cheers,
> Ben
> On 03/14/2017 10:05 AM, Sichen Zhao wrote:
>> c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c | 684 ++++++++++++++++++++++++++++--
>> c/src/lib/libbsp/arm/beagle/include/i2c.h | 18 +-
>> cpukit/dev/i2c/eeprom.c | 24 +-
>> testsuites/samples/i2c0/init.c | 98 ++++-
>> 4 files changed, 777 insertions(+), 47 deletions(-)
>> diff --git a/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
>> index 6b790e5..6a22125 100644
>> --- a/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
>> +++ b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
>> @@ -21,11 +21,23 @@
>> #include <bsp/bbb-gpio.h>
>> #include <rtems/score/assert.h>
>> +#define u16 unsigned int
>> +static int am335x_i2c_set_clock(i2c_bus *base, unsigned long clock);
>> +static void omap24_i2c_init(i2c_bus *base);
>> +static void flush_fifo(i2c_bus *base);
>> +static int wait_for_bb(i2c_bus *base);
>> +static int omap24_i2c_probe(i2c_bus *base);
>> +static u16 wait_for_event(i2c_bus *base);
>> +static int am335x_i2c_read(i2c_bus *base, unsigned char chip, uint addr, int alen, unsigned char *buffer,
>> + int len);
>> +static int read_eeprom(i2c_bus *base,struct am335x_baseboard_id *header);
>> +static int am335x_i2c_write(i2c_bus *base, unsigned char chip, uint addr,int alen, unsigned char *buffer,
>> + int len);
>> static bool am335x_i2c_pinmux(bbb_i2c_bus *bus)
>> bool status =true;
>> // We will check i2c_bus_id in am335x_i2c_bus_register
>> // Apart from mode and pull_up register what about SCREWCTRL & RXACTIVE ??
>> if (bus->i2c_bus_id == I2C1) {
>> @@ -48,9 +60,7 @@ static bool am335x_i2c_pinmux(bbb_i2c_bus *bus)
>> /* ref. Table 21-4 I2C Clock Signals */
>> For I2C1/2
>> Interface clock - 100MHz - CORE_LKOUTM4 / 2 - pd_per_l4ls_gclk
>> Functional clock - 48MHz - PER_CLKOUTM2 / 4 - pd_per_ic2_fclk
>> @@ -74,7 +84,6 @@ state. Functional clocks are guarantied to stay present. As long as in
>> this configuration, power domain sleep transition cannot happen.*/
>> /* REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKCTRL) |=
>> AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE;
>> while((REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKCTRL) &
>> AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE) != AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE);
>> @@ -86,30 +95,29 @@ this configuration, power domain sleep transition cannot happen.*/
>> REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C1_CLKCTRL) |=
>> AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE_ENABLE;
>> while(REG((AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C1_CLKCTRL) &
>> AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE) != AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE_ENABLE);
>> } else if (bus->i2c_bus_id == I2C2) {
>> REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C2_CLKCTRL) |=
>> AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE_ENABLE;
>> while(REG((AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C2_CLKCTRL) &
>> AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE) != AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE_ENABLE);
>> while(!(REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKSTCTRL) &
>> (AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_L4LS_GCLK |
>> AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_I2C_FCLK)));
>> static void am335x_i2c0_pinmux(bbb_i2c_bus *bus)
>> - REG(bus->regs + AM335X_CONF_I2C0_SDA) =
>> + printf("0x44e10000 + AM335X_CONF_I2C0_SDA:%x\n",0x44e10000 + AM335X_CONF_I2C0_SDA);
>> + printf("bus->regs:%x\n", bus->regs);
>> + REG(0x44e10000 + AM335X_CONF_I2C0_SDA) =
>> (BBB_RXACTIVE | BBB_SLEWCTRL | BBB_PU_EN);
>> - REG(bus->regs + AM335X_CONF_I2C0_SCL) =
>> + REG(0x44e10000 + AM335X_CONF_I2C0_SCL) =
>> @@ -314,14 +322,29 @@ void am335x_i2c_init(bbb_i2c_bus *bus, uint32_t input_clock)
>> static bool am335x_i2c_busbusy(volatile bbb_i2c_regs *regs)
>> bool status;
>> - if (REG(®s->BBB_I2C_IRQSTATUS_RAW) & AM335X_I2C_IRQSTATUS_RAW_BB)
>> + unsigned short stat;
>> + int timeout = I2C_TIMEOUT;
>> + REG(®s->BBB_I2C_IRQSTATUS)=0xffff;
>> + printf("REG(®s->BBB_I2C_IRQSTATUS_RAW):%x\n",REG(®s->BBB_I2C_IRQSTATUS_RAW) );
>> + // printf("%x\n",0x1400 & 0x1000 );
>> + printf("REG(®s->BBB_I2C_IRQSTATUS_RAW) & AM335X_I2C_IRQSTATUS_RAW_BB:%x\n",(REG(®s->BBB_I2C_IRQSTATUS_RAW) & AM335X_I2C_IRQSTATUS_RAW_BB));
>> +while(stat =( REG(®s->BBB_I2C_IRQSTATUS_RAW) & AM335X_I2C_IRQSTATUS_RAW_BB) && timeout--)
>> - status = true;
>> - } else {
>> - status = false;
>> +REG(®s->BBB_I2C_IRQSTATUS)=stat;
>> + udelay(20);
>> + if (timeout <= 0) {
>> + printf("Timed out in wait_for_bb: status=%04x\n",
>> + stat);
>> + return 1;
>> - return status;
>> + REG(®s->BBB_I2C_IRQSTATUS)=0xffff; /* clear delayed stuff*/
>> + return 0;
>> static void am335x_i2c_reset(bbb_i2c_bus *bus)
>> @@ -330,9 +353,27 @@ static void am335x_i2c_reset(bbb_i2c_bus *bus)
>> printk("reset bus->reg is %x \n",bus->regs);
>> /* Disable I2C module at the time of initialization*/
>> /*Should I use write32 ?? I guess mmio_clear is correct choice here*/
>> + REG(®s->BBB_I2C_CON)=0x00;
>> printk("inside BBB_I2C_CON value is %x \n",®s->BBB_I2C_CON);
>> - mmio_clear((®s->BBB_I2C_CON),AM335X_I2C_CON_I2C_EN);
>> - mmio_clear((®s->BBB_I2C_SYSC),AM335X_I2C_SYSC_AUTOIDLE);
>> + REG(®s->BBB_I2C_SYSC)= 0x2;
>> +// mmio_clear((®s->BBB_I2C_CON),AM335X_I2C_CON_I2C_EN);
>> + REG(®s->BBB_I2C_CON)= AM335X_I2C_CON_I2C_EN;
>> + while((REG(®s->BBB_I2C_SYSS) &I2C_SYSS_RDONE)==0) //wait reset done
>> + udelay(100);
>> + am335x_i2c_set_clock(&bus->base, I2C_BUS_CLOCK_DEFAULT);
>> + REG(®s->BBB_I2C_CON)= AM335X_I2C_CON_MST | AM335X_I2C_CON_I2C_EN;
>> +// mmio_clear((®s->BBB_I2C_SYSC),AM335X_I2C_SYSC_AUTOIDLE);
>> //REG(bus->regs + AM335X_I2C_CON) &= ~(AM335X_I2C_CON_I2C_EN);
>> //REG(bus->regs + AM335X_I2C_SYSC) &= ~(AM335X_I2C_SYSC_AUTOIDLE);
>> @@ -385,6 +426,7 @@ static unsigned int am335x_i2c_intrawstatus(volatile bbb_i2c_regs *regs)
>> static void am335x_i2c_masterint_enable(volatile bbb_i2c_regs *regs, unsigned int flag)
>> + printf("am335x_i2c_masterint_enable func\n");
>> REG(®s->BBB_I2C_IRQENABLE_SET) |= flag;
>> @@ -401,6 +443,7 @@ static void am335x_int_clear(volatile bbb_i2c_regs *regs, unsigned int flag)
>> static void am335x_clean_interrupts(volatile bbb_i2c_regs *regs)
>> + printf("am335x_clean_interrupts func\n");
>> am335x_i2c_masterint_enable(regs,0x7FFF);
>> am335x_int_clear(regs,0x7FFF);
>> am335x_i2c_masterint_disable(regs,0x7FFF);
>> @@ -412,30 +455,69 @@ static void am335x_i2c_setup_read_transfer(bbb_i2c_bus *bus, volatile bbb_i2c_re
>> volatile unsigned int no_bytes;
>> //am335x_i2c_masterint_enable(regs, AM335X_I2C_INT_RECV_READY);
>> // No of data to be transmitted at a time
>> +//bbb_i2c_bus *bus = (bbb_i2c_bus *) base;
>> +// volatile bbb_i2c_regs *regs = bus->regs;
>> + struct am335x_baseboard_id header;
>> + omap24_i2c_probe(&bus->base);
>> + read_eeprom(&bus->base,&header);
>> REG(®s->BBB_I2C_CNT) = 0x02;
>> no_bytes = REG(®s->BBB_I2C_CNT);
>> + // Set Slave address & Master enable, bring out of reset
>> + REG(®s->BBB_I2C_SA) = msgs->addr;
>> + printf("slave address : %x\n",REG(®s->BBB_I2C_SA));
>> // I2C Controller in Master Mode
>> - REG(®s->BBB_I2C_CON) = AM335X_I2C_CFG_MST_TX | AM335X_I2C_CON_I2C_EN | AM335X_I2C_CON_START | AM335X_I2C_CON_MST;
>> + REG(®s->BBB_I2C_CON) = AM335X_I2C_CFG_MST_TX | AM335X_I2C_CON_MST | AM335X_I2C_CON_START | AM335X_I2C_CON_I2C_EN | AM335X_I2C_CON_STOP;
>> printk("set master in transmission mode %x \n",REG(®s->BBB_I2C_CON));
>> - // Set Slave address & Master enable, bring out of reset
>> - REG(®s->BBB_I2C_SA) = msgs->addr;
>> - printf("slave address : %x\n",REG(®s->BBB_I2C_SA));
>> +while(am335x_i2c_busbusy(regs) != 0);
>> + printk("bus is free \n");
>> // clear status of all interrupts
>> am335x_clean_interrupts(regs);
>> printk("\n set memory address to read\n");
>> // transmit interrupt is enabled
>> am335x_i2c_masterint_enable(regs,AM335X_I2C_IRQSTATUS_XRDY);
>> printk("Enable transmit interrupt \n");
>> //start condition
>> - REG(®s->BBB_I2C_CON) |= AM335X_I2C_CON_START;
>> + REG(®s->BBB_I2C_CON) |= AM335X_I2C_CON_START | AM335X_I2C_CON_I2C_EN;
>> printk("start transmission \n");
>> - while(am335x_i2c_busbusy(regs) == 0);
>> - printk("bus is free \n");
>> printk("CNT : %x\n", no_bytes);
>> + printf("BBB_I2C_DATA:%x\n", readb(®s->BBB_I2C_DATA));
>> +writeb(0x5,®s->BBB_I2C_DATA);
>> +printf("(0x50 >> 8)& 0xff:%x\n",(0x50 >> 8)& 0xff);
>> +printf("REG(®s->BBB_I2C_DATA):%x\n",readb(®s->BBB_I2C_DATA) );
>> +printf("®s->BBB_I2C_DATA:%x\n",®s->BBB_I2C_DATA);
>> +//REG(®s->BBB_I2C_IRQSTATUS)=AM335X_I2C_IRQSTATUS_XRDY;
>> +udelay(10);
>> +writeb(0x0,®s->BBB_I2C_DATA);
>> +//REG(®s->BBB_I2C_DATA)= ( (0x50 >> 0)& 0xff);
>> +printf("(0x50 >> 0)& 0xff:%x\n",(0x50 >> 0)& 0xff);
>> +REG(®s->BBB_I2C_IRQSTATUS)=AM335X_I2C_IRQSTATUS_XRDY;
>> + // no_bytes = REG(®s->BBB_I2C_CNT);
>> while(0 != no_bytes);
>> printk("total msg count for tranmission is zero \n");
>> while( !(am335x_i2c_intrawstatus(regs) & (AM335X_I2C_IRQSTATUS_ARDY)));
>> @@ -464,6 +546,7 @@ static void am335x_i2c_setup_read_transfer(bbb_i2c_bus *bus, volatile bbb_i2c_re
>> printk("Exit read transfer\n");
>> @@ -570,11 +653,16 @@ static void am335x_i2c_setup_transfer(bbb_i2c_bus *bus, volatile bbb_i2c_regs *r
>> regs = bus->regs;
>> - REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_TXFIFO_CLR;
>> - REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_RXFIFO_CLR;
>> - am335x_i2c_set_address_size(msgs,regs);
>> - bus->read = ((bus->read == true) ? 0:1);
>> + printf("REG(®s->BBB_I2C_DATA):%x\n",REG(®s->BBB_I2C_DATA) );
>> + // REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_TXFIFO_CLR;
>> + // REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_RXFIFO_CLR;
>> +printf("REG(®s->BBB_I2C_DATA):%x\n",REG(®s->BBB_I2C_DATA) );
>> + // am335x_i2c_set_address_size(msgs,regs);
>> +bus->read = (msgs->flags & I2C_M_RD) != 0;
>> +printf("bus->read:%d\n",bus->read );
>> + //bus->read = ((bus->read == true) ? 0:1);
>> bus->already_transferred = (bus->read == true) ? 0 : 1;
>> if (bus->read) {
>> @@ -652,7 +740,7 @@ static int am335x_i2c_transfer(i2c_bus *base, i2c_msg *msgs, uint32_t msg_count)
>> bbb_i2c_bus *bus = (bbb_i2c_bus *)base;
>> volatile bbb_i2c_regs *regs;
>> uint32_t i;
>> - printk("\n enter transfer ");
>> + printk("\n enter transfer\n ");
>> rtems_task_wake_after(1);
>> @@ -665,20 +753,23 @@ static int am335x_i2c_transfer(i2c_bus *base, i2c_msg *msgs, uint32_t msg_count)
>> return -EINVAL;
>> + printf("bus->regs:%x\n",bus->regs );
>> bus->msgs = &msgs[0];
>> bus->msg_todo = msg_count;
>> printk("total msg = msg_count : %x \n",bus->msg_todo);
>> bus->current_msg_todo = msgs[0].len;// current data size
>> - bus->current_msg_byte = msgs[0].buf;// current data
>> + //bus->current_msg_byte = msgs[0].buf;// current data
>> printk("\n current_msg_todo %x \n ",msgs[0].len);
>> printk("\n current_msg_byte %x \n ",msgs[0].buf);
>> + //printf("8011A5CC:%x\n", *(unsigned int *)(0x8011A5CC) );
>> bus->task_id = rtems_task_self();
>> regs = bus->regs;
>> - am335x_i2c_setup_transfer(bus,regs);
>> - REG(®s->BBB_I2C_IRQENABLE_SET) = BBB_I2C_IRQ_USED;
>> + // REG(®s->BBB_I2C_IRQENABLE_SET) = BBB_I2C_IRQ_USED;
>> + am335x_i2c_setup_transfer(bus,regs);
>> sc = rtems_event_transient_receive(RTEMS_WAIT, bus->base.timeout);
>> // If timeout then return timeout error
>> if (sc != RTEMS_SUCCESSFUL) {
>> @@ -688,7 +779,9 @@ static int am335x_i2c_transfer(i2c_bus *base, i2c_msg *msgs, uint32_t msg_count)
>> return -ETIMEDOUT;
>> printk("exit transfer\n");
>> // return bus->regs->BBB_I2C_IRQSTATUS == 0 ? 0 : -EIO;
>> return 0;
>> @@ -700,19 +793,28 @@ static int am335x_i2c_set_clock(i2c_bus *base, unsigned long clock)
>> uint32_t prescaler,divider;
>> printk("set clock start\n");
>> + REG(®s->BBB_I2C_CON)=0;
>> prescaler = (BBB_I2C_SYSCLK / BBB_I2C_INTERNAL_CLK) -1;
>> + printf("prescaler:%d\n",prescaler );
>> printk("PSC offset %x \n ",®s->BBB_I2C_PSC);
>> printk("PSC offset %x \n", &bus->regs->BBB_I2C_PSC);
>> //mmio_write((®s->BBB_I2C_PSC), prescaler);
>> REG(&bus->regs->BBB_I2C_PSC) = prescaler;
>> divider = BBB_I2C_INTERNAL_CLK/(2*clock);
>> + printf("divider:%d\n", divider);
>> printk("SCLL offset %x \n",&bus->regs->BBB_I2C_SCLL);
>> //mmio_write((®s->BBB_I2C_SCLL), (divider - 7));
>> REG(&bus->regs->BBB_I2C_SCLL) = (divider - 7);
>> //mmio_write((®s->BBB_I2C_SCLH), (divider - 5));
>> printk("SCHL offset %x\n",&bus->regs->BBB_I2C_SCLH);
>> REG(&bus->regs->BBB_I2C_SCLH) = (divider - 5);
>> + REG(®s->BBB_I2C_CON)=I2C_CON_EN;
>> +writew(0xFFFF, &bus->regs->BBB_I2C_IRQSTATUS); /* clear all pending status */
>> printk("set clock end \n");
>> return 0;
>> @@ -729,6 +831,8 @@ static void am335x_i2c_destroy(i2c_bus *base)
>> i2c_bus_destroy_and_free(&bus->base);
>> int am335x_i2c_bus_register(
>> const char *bus_path,
>> uintptr_t register_base,
>> @@ -751,14 +855,15 @@ int am335x_i2c_bus_register(
>> bus->regs = (volatile bbb_i2c_regs *) register_base;
>> // 1. Enable clock for I2CX
>> - I2C0ModuleClkConfig();
>> + I2C0ModuleClkConfig();
>> // 2. pinmux setup
>> am335x_i2c0_pinmux(bus);
>> // 3. RESET : Disable Master, autoideal
>> - am335x_i2c_reset(bus);
>> + // am335x_i2c_reset(bus);
>> // 4. configure bus speed
>> bus->input_clock = input_clock; // By default 100KHz. Normally pass 100KHz as argument
>> printk("Before set clock \n");
>> err = am335x_i2c_set_clock(&bus->base, I2C_BUS_CLOCK_DEFAULT);
>> @@ -768,12 +873,16 @@ int am335x_i2c_bus_register(
>> rtems_set_errno_and_return_minus_one(-err);
>> bus->irq = irq;
>> +omap24_i2c_init(&bus->base);
>> //bring I2C out of reset
>> - REG(&bus->regs->BBB_I2C_CON) |= AM335X_I2C_CON_I2C_EN;
>> +//printf("REG(®s->BBB_I2C_IRQSTATUS):%x\n",REG(&bus->regs->BBB_I2C_IRQSTATUS));
>> + // REG(&bus->regs->BBB_I2C_CON) |= AM335X_I2C_CON_I2C_EN;
>> // 5. Start interrupt service routine & one interrupt at a time
>> sc = rtems_interrupt_handler_install(
>> irq,
>> "BBB I2C",
>> @@ -787,6 +896,7 @@ int am335x_i2c_bus_register(
>> rtems_set_errno_and_return_minus_one(EIO);
>> // 6. start transfer for reading and writing
>> bus->base.transfer = am335x_i2c_transfer;
>> bus->base.set_clock = am335x_i2c_set_clock;
>> @@ -794,3 +904,499 @@ int am335x_i2c_bus_register(
>> printk("exit register\n");
>> return i2c_bus_register(&bus->base,bus_path);
>> + bbb_i2c_bus *bus = (bbb_i2c_bus *) base;
>> + volatile bbb_i2c_regs *regs = bus->regs;
>> + int deblock = 1;
>> +printf("omap24_i2c_init func!!!!!!\n");
>> +retry:
>> + if (readw(&bus->regs->BBB_I2C_CON) & I2C_CON_EN) {
>> + writew(0, &bus->regs->BBB_I2C_CON);
>> + udelay(50000);
>> + writew(0x2, &bus->regs->BBB_I2C_SYSC); /* for ES2 after soft reset */
>> + udelay(1000);
>> + writew(I2C_CON_EN, &bus->regs->BBB_I2C_CON);
>> + while (!(readw(&bus->regs->BBB_I2C_SYSS) & I2C_SYSS_RDONE) && timeout--) {
>> + puts("ERROR: Timeout in soft-reset\n");
>> + return;
>> + udelay(1000);
>> +am335x_i2c_set_clock(&bus->base, I2C_BUS_CLOCK_DEFAULT);
>> + /* own address */
>> + writew(1, &bus->regs->BBB_I2C_OA);
>> +//#if defined(CONFIG_OMAP243X) || defined(CONFIG_OMAP34XX)
>> + * Have to enable interrupts for OMAP2/3, these IPs don't have
>> + * an 'irqstatus_raw' register and we shall have to poll 'stat'
>> + // writew(I2C_IE_XRDY_IE | I2C_IE_RRDY_IE | I2C_IE_ARDY_IE | I2C_IE_NACK_IE | I2C_IE_AL_IE, &i2c_base->ie);
>> +//#endif
>> + udelay(1000);
>> + flush_fifo(&bus->base);
>> + writew(0xFFFF, &bus->regs->BBB_I2C_IRQSTATUS);
>> + /* Handle possible failed I2C state */
>> + if (wait_for_bb(&bus->base))
>> + if (deblock == 1) {
>> + //omap24_i2c_deblock(&bus->base);
>> + printf("deblock\n");
>> + deblock = 0;
>> + goto retry;
>> + // omap24_i2c_probe(&bus->base);
>> + // read_eeprom(&bus->base,&header);
>> + u16 stat;
>> +printf("flush_fifo\n");
>> + * note: if you try and read data when its not there or ready
>> + * you get a bus error
>> + while (1) {
>> + stat = readw(&bus->regs->BBB_I2C_IRQSTATUS);
>> + if (stat == I2C_STAT_RRDY) {
>> + readb(&bus->regs->BBB_I2C_DATA);
>> + writew(I2C_STAT_RRDY, &bus->regs->BBB_I2C_IRQSTATUS);
>> + udelay(1000);
>> + } else
>> + break;
>> + u16 stat;
>> +printf("wait_for_bb\n");
>> + writew(0xFFFF, &bus->regs->BBB_I2C_IRQSTATUS); /* clear current interrupts...*/
>> +//printf("test1\n");
>> + /* Read RAW status */
>> +//printf("%x\n", readw(&bus->regs->BBB_I2C_IRQSTATUS_RAW) & I2C_STAT_BB);
>> + while ((stat = readw(&bus->regs->BBB_I2C_IRQSTATUS_RAW) &
>> + I2C_STAT_BB) && timeout--) {
>> + writew(stat, &bus->regs->BBB_I2C_IRQSTATUS);
>> + udelay(200);
>> + stat);
>> + return 1;
>> + writew(0xFFFF, &bus->regs->BBB_I2C_IRQSTATUS); /* clear delayed stuff*/
>> + return 0;
>> + unsigned char chip = 0x50;
>> + u16 status;
>> + int res = 1; /* default = fail */
>> +printf("omap24_i2c_probe\n");
>> + if (chip == readw(&bus->regs->BBB_I2C_OA))
>> + return res;
>> + /* Wait until bus is free */
>> + return res;
>> + /* No data transfer, slave addr only */
>> + writew(chip, &bus->regs->BBB_I2C_SA);
>> + /* Stop bit needed here */
>> + writew(I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_TRX |
>> + I2C_CON_STP, &bus->regs->BBB_I2C_CON);
>> + status = wait_for_event(&bus->base);
>> + if ((status & ~I2C_STAT_XRDY) == 0 || (status & I2C_STAT_AL)) {
>> + * With current high-level command implementation, notifying
>> + * the user shall flood the console with 127 messages. If
>> + * silent exit is desired upon unconfigured bus, remove the
>> + * following 'if' section:
>> + if (status == I2C_STAT_XRDY)
>> + printf("i2c_probe: pads on bus probably not configured (status=0x%x)\n",status);
>> + goto pr_exit;
>> + /* Check for ACK (!NAK) */
>> + if (!(status & I2C_STAT_NACK)) {
>> + printf("Device found\n");
>> + res = 0; /* Device found */
>> + udelay(200);/* Required by AM335X in SPL */
>> + /* Abort transfer (force idle state) */
>> + writew(I2C_CON_MST | I2C_CON_TRX, &bus->regs->BBB_I2C_CON); /* Reset */
>> + udelay(1000);
>> + writew(I2C_CON_EN | I2C_CON_MST | I2C_CON_TRX |
>> + I2C_CON_STP, &bus->regs->BBB_I2C_CON); /* STP */
>> +pr_exit:
>> + return res;
>> + u16 status;
>> +//printf("wait_for_event \n");
>> + do {
>> + udelay(200);
>> + status = readw(&bus->regs->BBB_I2C_IRQSTATUS_RAW);
>> + } while (!(status &
>> + (I2C_STAT_ROVR | I2C_STAT_XUDF | I2C_STAT_XRDY |
>> + I2C_STAT_RRDY | I2C_STAT_ARDY | I2C_STAT_NACK |
>> + I2C_STAT_AL)) && timeout--);
>> + printf("Timed out in wait_for_event: status=%04x\n",
>> + status);
>> + * If status is still 0 here, probably the bus pads have
>> + * not been configured for I2C, and/or pull-ups are missing.
>> + printf("Check if pads/pull-ups of bus are properly configured\n");
>> + status = 0;
>> + return status;
>> + int len)
>> + int i2c_error = 0;
>> + int i=0;
>> + u16 status;
>> +printf("am335x_i2c_read\n");
>> + if (alen < 0) {
>> + puts("I2C read: addr len < 0\n");
>> + return 1;
>> + if (len < 0) {
>> + puts("I2C read: data len < 0\n");
>> + return 1;
>> + if (buffer == NULL) {
>> + puts("I2C read: NULL pointer passed\n");
>> + return 1;
>> + if (alen > 2) {
>> + printf("I2C read: addr len %d not supported\n", alen);
>> + return 1;
>> + if (addr + len > (1 << 16)) {
>> + puts("I2C read: address out of range\n");
>> + return 1;
>> + /* Wait until bus not busy */
>> + return 1;
>> +//printf("test2\n");
>> + /* Zero, one or two bytes reg address (offset) */
>> + writew(alen, &bus->regs->BBB_I2C_CNT);
>> + /* Set slave address */
>> +//printf("test3\n");
>> + if (alen) {
>> + /* Must write reg offset first */
>> + /* Stop - Start (P-S) */
>> + writew(I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_STP |
>> + I2C_CON_TRX, &bus->regs->BBB_I2C_CON);
>> + /* Send register offset */
>> + while (1) {
>> + printf("status:%x\n",status );
>> + /* Try to identify bus that is not padconf'd for I2C */
>> + if (status == I2C_STAT_XRDY) {
>> + i2c_error = 2;
>> + printf("i2c_read (addr phase): pads on bus probably not configured (status=0x%x)\n",
>> + status);
>> + goto rd_exit;
>> + if (status == 0 || (status & I2C_STAT_NACK)) {
>> + i2c_error = 1;
>> + printf("i2c_read: error waiting for addr ACK (status=0x%x)\n",
>> + status);
>> + goto rd_exit;
>> + if (alen) {
>> + if (status & I2C_STAT_XRDY) {
>> + // printf("alen:%d\n",alen );
>> + alen--;
>> + // printf("addr:%x\n",addr );
>> + // printf("(addr >> (8 * alen)) & 0xff:%x\n",(addr >> (8 * alen)) & 0xff );
>> + /* Do we have to use byte access? */
>> + writeb((addr >> (8 * alen)) & 0xff,
>> + &bus->regs->BBB_I2C_DATA);
>> + writew(I2C_STAT_XRDY, &bus->regs->BBB_I2C_IRQSTATUS);
>> + if (status & I2C_STAT_ARDY) {
>> + writew(I2C_STAT_ARDY, &bus->regs->BBB_I2C_IRQSTATUS);
>> + break;
>> + /* Read len bytes from slave */
>> + writew(len, &bus->regs->BBB_I2C_CNT);
>> + /* Need stop bit here */
>> + I2C_CON_STT | I2C_CON_STP,
>> + &bus->regs->BBB_I2C_CON);
>> +//printf("test4\n");
>> + /* Receive data */
>> + while (1) {
>> + // printf("test 5\n");
>> + * Try to identify bus that is not padconf'd for I2C. This
>> + * state could be left over from previous transactions if
>> + * the address phase is skipped due to alen=0.
>> + i2c_error = 2;
>> + printf("i2c_read (data phase): pads on bus probably not configured (status=0x%x)\n",
>> + status);
>> + goto rd_exit;
>> + // printf("i2c_error = 1\n");
>> + i2c_error = 1;
>> + goto rd_exit;
>> + if (status & I2C_STAT_RRDY) {
>> + char temp;
>> + temp=readb(&bus->regs->BBB_I2C_DATA);
>> + *buffer++ =temp;
>> + *bus->msgs[0].buf++=temp;
>> + // (*(uint8_t *) bus->current_msg_byte[0]) = readb(&bus->regs->BBB_I2C_DATA) & 0xFF;
>> + i++;
>> + break;
>> +rd_exit:
>> +//printf("rd_exit\n");
>> +//printf("i2c_error:%d\n",i2c_error);
>> + return i2c_error;
>> +bbb_i2c_bus *bus = (bbb_i2c_bus *) base;
>> +printf("sizeof(struct am335x_baseboard_id):%d\n",sizeof(struct am335x_baseboard_id) );
>> +//printf("sizeof(struct am335x_baseboard_id):%d\n",sizeof(unsigned int) );
>> + am335x_i2c_read(&bus->base,0x50,0,2,(unsigned char *)header,sizeof(struct am335x_baseboard_id));
>> +printf("am335x_i2c_read end\n");
>> + printf("header->magic:%x\n", header->magic);
>> + printf("header->name[0]:%x\n", header->name[0]);
>> + printf("header->name[1]:%x\n", header->name[1]);
>> + printf("header->name[2]:%x\n", header->name[2]);
>> + printf("header->name[3]:%x\n", header->name[3]);
>> + printf("header->name[4]:%x\n", header->name[4]);
>> + printf("header->name[5]:%x\n", header->name[5]);
>> + printf("header->name[6]:%x\n", header->name[6]);
>> + printf("header->name[7]:%x\n", header->name[7]);
>> + int len)
>> + int i;
>> + u16 status;
>> + if (alen < 0) {
>> + puts("I2C write: addr len < 0\n");
>> + return 1;
>> + if (len < 0) {
>> + puts("I2C write: data len < 0\n");
>> + return 1;
>> + puts("I2C write: NULL pointer passed\n");
>> + return 1;
>> + if (alen > 2) {
>> + printf("I2C write: addr len %d not supported\n", alen);
>> + return 1;
>> + printf("I2C write: address 0x%x + 0x%x out of range\n",
>> + addr, len);
>> + return 1;
>> + return 1;
>> + /* Start address phase - will write regoffset + len bytes data */
>> + writew(alen + len, &bus->regs->BBB_I2C_CNT);
>> + writew(chip,&bus->regs->BBB_I2C_SA);
>> + I2C_CON_STP,&bus->regs->BBB_I2C_CON);
>> + while (alen) {
>> + /* Must write reg offset (one or two bytes) */
>> + i2c_error = 2;
>> + printf("i2c_write: pads on bus probably not configured (status=0x%x)\n",status);
>> + goto wr_exit;
>> + i2c_error = 1;
>> + printf("i2c_write: error waiting for addr ACK (status=0x%x)\n",
>> + status);
>> + goto wr_exit;
>> + alen--;
>> + writeb((addr >> (8 * alen)) & 0xff, &bus->regs->BBB_I2C_DATA);
>> + } else {
>> + i2c_error = 1;
>> + printf("i2c_write: bus not ready for addr Tx (status=0x%x)\n",
>> + status);
>> + goto wr_exit;
>> + /* Address phase is over, now write data */
>> + for (i = 0; i < len; i++) {
>> + i2c_error = 1;
>> + printf("i2c_write: error waiting for data ACK (status=0x%x)\n",
>> + status);
>> + goto wr_exit;
>> + writeb(buffer[i], &bus->regs->BBB_I2C_DATA);
>> + } else {
>> + i2c_error = 1;
>> + printf("i2c_write: bus not ready for data Tx (i=%d)\n",
>> + i);
>> + goto wr_exit;
>> + * poll ARDY bit for making sure that last byte really has been
>> + * transferred on the bus.
>> + do {
>> + } while (!(status & I2C_STAT_ARDY) && timeout--);
>> + if (timeout <= 0)
>> + printf("i2c_write: timed out writig last byte!\n");
>> +wr_exit:
>> + return i2c_error;
>> diff --git a/c/src/lib/libbsp/arm/beagle/include/i2c.h b/c/src/lib/libbsp/arm/beagle/include/i2c.h
>> index d4a9e32..6c924ee 100644
>> --- a/c/src/lib/libbsp/arm/beagle/include/i2c.h
>> +++ b/c/src/lib/libbsp/arm/beagle/include/i2c.h
>> @@ -132,11 +132,11 @@ extern "C" {
>> #define DISP_LINE_LEN 128
>> -#define I2C_TIMEOUT 1000
>> +#define I2C_TIMEOUT 1001
>> #define I2C_BUS_MAX 3
>> -#define I2C_BASE1 (OMAP34XX_CORE_L4_IO_BASE + 0x070000)
>> +#define I2C_BASE1 (OMAP34XX_CORE_L4_IO_BASE + 0x070000) //0x48000000+0x070000
>> #define I2C_DEFAULT_BASE I2C_BASE1
>> @@ -356,7 +356,7 @@ static inline rtems_status_code beagle_i2c_read(
>> | AM335X_I2C_IRQSTATUS_ARDY \
>> | AM335X_I2C_IRQSTATUS_RRDY \
>> | AM335X_I2C_IRQSTATUS_XRDY \
>> - | AM335X_I2C_IRQSTATUS_XUDF)
>> + | AM335X_I2C_IRQSTATUS_XUDF )
>> #define BBB_I2C_IRQ_USED \
>> ( BBB_I2C_IRQ_ERROR \
>> @@ -478,6 +478,18 @@ static inline int bbb_register_i2c_2(void)
>> +struct am335x_baseboard_id {
>> + unsigned int magic;
>> + char name[8];
>> + char version[4];
>> + char serial[12];
>> + char config[32];
>> + char mac_addr[3][6];
>> #ifdef __cplusplus
>> #endif /* __cplusplus */
>> diff --git a/cpukit/dev/i2c/eeprom.c b/cpukit/dev/i2c/eeprom.c
>> index 39cff95..15040af 100644
>> --- a/cpukit/dev/i2c/eeprom.c
>> +++ b/cpukit/dev/i2c/eeprom.c
>> @@ -55,6 +55,7 @@ static ssize_t eeprom_read(
>> off_t offset
>> eeprom *dev = (eeprom *) base;
>> off_t avail = dev->size - offset;
>> uint32_t off = (uint32_t) offset;
>> @@ -86,6 +87,17 @@ static ssize_t eeprom_read(
>> (uint8_t) (off >> 16),
>> (uint8_t) (off >> 24)
>> + i2c_msg msgs[1] = {
>> + .addr = i2c_addr,
>> + .flags = I2C_M_RD,
>> + .buf = in,
>> + .len = cur
>> i2c_msg msgs[2] = {
>> .addr = i2c_addr,
>> @@ -99,14 +111,22 @@ static ssize_t eeprom_read(
>> .len = cur
>> int err;
>> err = i2c_bus_transfer(dev->base.bus, &msgs[0], RTEMS_ARRAY_SIZE(msgs));
>> if (err != 0) {
>> return err;
>> todo -= cur;
>> off += cur;
>> in += cur;
>> @@ -236,7 +256,7 @@ int i2c_dev_register_eeprom(
>> if (program_timeout_in_ms == 0) {
>> - program_timeout_in_ms = 1000;
>> + program_timeout_in_ms = 5000;
>> dev = (eeprom *)
>> diff --git a/testsuites/samples/i2c0/init.c b/testsuites/samples/i2c0/init.c
>> index b428216..70bbe12 100644
>> --- a/testsuites/samples/i2c0/init.c
>> +++ b/testsuites/samples/i2c0/init.c
>> @@ -23,10 +23,62 @@
>> #include <dev/i2c/eeprom.h>
>> +#include <rtems/shell.h>
>> +#include <stdio.h>
>> +#include <stdarg.h>
>> +#include <stdlib.h>
>> +#include <string.h>
>> +#include <errno.h>
>> +#include <rtems/userenv.h>
>> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>> +#define CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
>> +#define CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
>> +#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
>> +#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
>> +#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 32
>> +#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 1
>> +#define CONFIGURE_UNLIMITED_ALLOCATION_SIZE 32
>> +#define CONFIGURE_UNLIMITED_OBJECTS
>> +#define CONFIGURE_UNIFIED_WORK_AREAS
>> +#define CONFIGURE_STACK_CHECKER_ENABLED
>> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>> +#define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
>> +#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
>> +#include <rtems/confdefs.h>
>> +#define CONFIGURE_SHELL_COMMAND_CP
>> +#define CONFIGURE_SHELL_COMMAND_PWD
>> +#define CONFIGURE_SHELL_COMMAND_LS
>> +#define CONFIGURE_SHELL_COMMAND_LN
>> +#define CONFIGURE_SHELL_COMMAND_LSOF
>> +#define CONFIGURE_SHELL_COMMAND_CHDIR
>> +#define CONFIGURE_SHELL_COMMAND_CD
>> +#define CONFIGURE_SHELL_COMMAND_MKDIR
>> +#define CONFIGURE_SHELL_COMMAND_RMDIR
>> +#define CONFIGURE_SHELL_COMMAND_CAT
>> +#define CONFIGURE_SHELL_COMMAND_MV
>> +#define CONFIGURE_SHELL_COMMAND_MALLOC_INFO
>> +#include <rtems/shellconfig.h>
>> /* I2C address of CAT24C256 eeprom
>> EEPROM SIZE 32 KB Ref: BBB SRM */
>> #define I2C_SLAVE_ADDR (0x50)
>> -#define EEPROM_SIZE 256
>> +#define EEPROM_SIZE 78
>> #define EEPROM_PATH "/dev/i2c-0.eeprom"
>> /* forward declarations to avoid warnings */
>> @@ -35,16 +87,23 @@ rtems_task Init(rtems_task_argument argument);
>> const char rtems_test_name[] = "GSOC 2016 I2C TESTING";
>> rtems_printer rtems_test_printer;
>> rtems_task Init(
>> rtems_task_argument ignored
>> rtems_test_begin();
>> int i;
>> int rv,fd_bus,fd_in_dev;
>> uint8_t in[EEPROM_SIZE];
>> struct stat st;
>> off_t off;
>> + ssize_t n;
>> + rtems_shell_env_t env;
>> /*bus registration */
>> rv = bbb_register_i2c_0();
>> @@ -64,23 +123,56 @@ rtems_task Init(
>> 256, // size_in_bytes
>> 0 // program time out in ms
>> + _Assert(rv == 0);
>> +// exit( 0 );
>> printf("register EEPROM \n");
>> fd_in_dev = open(EEPROM_PATH, O_RDWR);
>> + printf("fd_in_dev:%d\n", fd_in_dev);
>> _Assert(fd_in_dev >=0);
>> printf("open eeprom \n");
>> rv = fstat(fd_in_dev, &st);
>> _Assert(rv == 0);
>> _Assert(st.st_blksize == 8);
>> _Assert(st.st_size == sizeof(in));
>> +printf("read func\n");
>> + n = read(fd_in_dev, &in[0], sizeof(in));
>> + printf("n:%d\n",n );
>> + printf("0:%x, ",in[0]);
>> + printf("1:%x, ",in[1]);
>> + for(i=0;i<sizeof(in);++i)
>> +printf("%x\n",in[i]);
>> + printf("sizeof(in):%d\n", sizeof(in));
>> + // _Assert(n == -1);
>> +printf("test\n");
>> for ( i = 0; i < sizeof(in); ++i) {
>> + printf("i:%d\n",i);
>> off = lseek(fd_in_dev, 0, SEEK_SET);
>> + printf("lseek func done!\n");
>> rv = read(fd_in_dev,&in[0], sizeof(in));
>> - printf("\n %s \n ",in[i]);
>> + // printf("\n %s \n ",in[i]);
>> printf("EXIT from test case");
>> close(fd_bus);
>> - unlink(BBB_I2C_2_BUS_PATH);
>> + unlink(BBB_I2C_2_BUS_PATH);
>> rtems_test_end();
> devel mailing list
> devel at rtems.org
devel mailing list
devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170322/fe8257b2/attachment-0001.html>
